327 oil pressure drop - Chevelle Tech
 2Likes
  • 1 Post By dozerhand
  • 1 Post By saltygog
post #1 of 5 (permalink) Old Jun 22nd, 19, 10:37 PM Thread Starter
Gary
I posted this in the wrong place so now I may get it right. My 327 started life with 60psi oil pressure and after about 100mile it started to loose pressure every time I drove it. Now I have 20psi at rpm an idle. Could this be the oil pump pressure bypass spring gone bad ?
You can't break it if it's broke to start with
saltygog is offline
post #2 of 5 (permalink) Old Jun 22nd, 19, 11:08 PM
leo
Re: 327 oil pressure drop
How is the oil pressure while driving at speed??
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #3 of 5 (permalink) Old Jun 22nd, 19, 11:26 PM
David
Start with changing the oil and filter, work up from there. Some assembly lubes have molybdenum which will plug a filter. If that isn't the cure make sure the gauge and sending unit are good. Eliminate all the simple external variables before you drop the pan and change the pump. In the long run you may be looking at improper bearing clearance but that would be the last resort. Always work from easiest to most difficult unless the problem is obvious.
later, dozer
LeoP likes this.
"Look Stock and carry a Big Block"
Raube Wan
dozerhand is offline
post #4 of 5 (permalink) Old Jun 23rd, 19, 2:00 AM Thread Starter
Gary
Pressure is constant at speed or idle. Will change the filter first. I hadn't thought of assembly lube being the problem. Pressure went away slowly over hours of run time. All bearings , crank and cam are new and met specs. I really don't want to pull the motor and change the pump.
saltygog is offline
post #5 of 5 (permalink) Old Jun 24th, 19, 2:11 PM Thread Starter
Gary
Thumbs up Re: 327 oil pressure drop
I don't know how you got that assembly lube would plug a filter but you are 100% on the money!!!!! This is in my wife's 2dr 65 Chevelle Wagon and you just made her day. I can't thank you enough for the help.
dozerhand likes this.
saltygog is offline
