69 Chevelle wiper/washer loose part - Chevelle Tech
post #1 of 3 (permalink) Old Jun 12th, 19, 9:13 PM Thread Starter
Where should this loose part be attached (see pics)? Itís function? Found it in top section of wiper motor. Also wipers will not stop with wiper switch and ignition both OFF; troubleshooting steps would be appreciated.
ID:	595564   Click image for larger version
ID:	595566   Click image for larger version
spiirriit is offline
post #2 of 3 (permalink) Old Jun 12th, 19, 10:03 PM
Bruce
Re: 69 Chevelle wiper/washer loose part
The part is, I believe, part of the Pump and shouldn't have anything to do with your Motor not shutting off. With all respect: your WSW Motor is probably not worth messing around with. Auto Zone sells both styles of the correct motor (one new the other rebuilt).
https://www.autozone.com/electrical-...9_18183_0_1525
https://www.autozone.com/electrical-...56_887065_6207
Also your Pump's going to need a new nozzle piece. https://www.autozone.com/electrical-...4261_6211_5809
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 3 (permalink) Old Jun 14th, 19, 12:55 PM Thread Starter
Thanks for the part numbers! Thatís the plan...a new one after testing the original that had glitches here and there.
