69 350 Running rough in gear - Chevelle Tech
 3Likes
  • 1 Post By LeoP
  • 1 Post By Diggerdan11
post #1 of 13 (permalink) Old May 30th, 19, 8:36 PM Thread Starter
Daniel
So I have 69 Malibu 350 2 Barrel that Iím
Having issues with. It runs just fine in park but when I put it into gear it runs terrible and dies sometimes. Iíve had to turn the idle up to keep it from dying immediately in gear.
It has new wires and plugs, rotor and cap though itís been a few years since they were actually installed (the car is never driven). The fuel filter is new and the carburetor is also a new.
When in park the vacuum pressure reads just fine but drops in gear.
I am still fairly new to older engines and I have exhausted all of my knowledge. Anyone know whatís going on or what to try?
I have a video but it wonít t let me upload it for some reason
1969 Chevelle Malibu, Frost Green, Dark Green Vinyl Top, Green Interior. 255hp 350. Father Was Original Owner.
Diggerdan11 is offline
post #2 of 13 (permalink) Old May 30th, 19, 8:37 PM Thread Starter
Daniel
Nn
post #3 of 13 (permalink) Old May 30th, 19, 8:47 PM
Re: 69 350 Running rough in gear
Does it still have points? Have you gone over your tune settings.
oldcutlass is offline
post #4 of 13 (permalink) Old May 30th, 19, 8:49 PM Thread Starter
Daniel
Yea it still has points
post #5 of 13 (permalink) Old May 31st, 19, 12:09 AM
leo
How old is the gasoline??
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #6 of 13 (permalink) Old May 31st, 19, 12:15 AM Thread Starter
Daniel
Itís from October. I know that could be an issue but it was running bad before and itís just getting worse
post #7 of 13 (permalink) Old May 31st, 19, 11:53 PM
leo
Gasoline loses about 1 octane point per month after dispensing into a gas tank, try some Sta-Bil in the tank!
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #8 of 13 (permalink) Old Jun 2nd, 19, 9:54 AM
Try plugging the vacuum advance hose into manifold vacuum if it's not already connected to that. (Of course, cap off any hose nipple left unused when doing this.) Also, check carefully for vacuum leaks. Check all hoses, make sure the carburetor baseplate gasket is not leaking, etc. A good way to do this is to spray carburetor cleaner around the base of the carburetor while the engine is running. Try to ensure the spray doesn't get sucked into the air intake snorkel on the air cleaner housing, and see if the engine speed changes when you spray. If it does, you've found a vacuum leak.
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #9 of 13 (permalink) Old Jun 3rd, 19, 1:44 PM
tom
it's too late for the Stabil to work. Stabil keeps new gas fresh longer than it's shelf life (60-90 days). It does not make "stale" gas fresh or usable.
tm66 is offline
post #10 of 13 (permalink) Old Jun 3rd, 19, 11:54 PM
leo
I disagree, I was fixing up an S-10 truck for a neighbor with at least two year old gas in it, it would idle ok, but driving is just putted along, poured some Sta-Bil in the tank and took it for a drive and it was fine, your mileage/results may vary!!
b&b's69 likes this.
Leo Paugh
A.C.E.S.#3731
LeoP is offline
post #11 of 13 (permalink) Old Jun 12th, 19, 1:20 PM Thread Starter
Daniel
Well after working on the car for days and days and not being able to figure it out, I ended up taking it to a mechanic.
Turns out it was some pretty simple things. The points were bad (did not look like it to me), and the condenser in the distributor was bad. They replaced those and tuned the carb a little bit, timed it and it purrs like a kitten
blue_69_malibu likes this.
post #12 of 13 (permalink) Old Jun 12th, 19, 3:03 PM
In the future you are going to need a tool called a Tach & Dwell meter if you are going to keep using your points distributor.A basic dwell meter will read the dwell reading plus High & Low RPM.
OR you can replace your points with an electronic set that converts your points distributor into an electronic ignition.
https://www.summitracing.com/parts/pnx-91284/overview/
and The Pertronics conversiion comes in three (I - II & III) versions
https://www.summitracing.com/parts/f...1720/overview/
I think the Fast used to be the Crane Electronic conversion kit but I'm not sure about that.The search feature is your friend on this subject.Whatever you choose you will still need a Tach for tune-up purposes.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #13 of 13 (permalink) Old Jun 12th, 19, 3:30 PM Thread Starter
Daniel
I do have a Tach and Dwell meter. I have also been researching the Pertronics conversions. I want to keep the Chevelle to as close to original as possible so it look like that might not be a bad option
71350SS likes this.
