What did I screw up??? - Page 2 - Chevelle Tech
 3Likes
post #16 of 21 (permalink) Old May 13th, 19, 7:52 AM
Hank
Re: What did I screw up???
Personally I would just remove the rest of the back drive linkage that is bolted to the frame and the rod that goes up to the lever at the bottom of the column. Why it affects you getting it out of reverse is beyond me because the linkage that runs from the back drive linkage to the transmission is already gone. I would then turn the column sleeve all the way to the left and leave it there. On my car I have a jumper wire running between the connector where the two larger purple wires are on the lower column. You have to be careful to always dump the clutch with that setup because you can start the car in any gear. I would then mount a switch on the transmission linkage for the back-up lights and run wires from the other connector on the lower column to that switch. I would then check all the bushings on the transmission linkage and replace them with the metal ones then check any bolts or nuts on the shifter body itself besides where all the linkage plates that bolt to the transmission for tightness and then check the linkage for neutral alignment at the shifter itself. If you still want to mount your tach on the column you can just make sure the collar is all the way to the left and then tighten the band clamp. Do not overtighten that clamp because you could distort the collar.
HKalin is offline
post #17 of 21 (permalink) Old May 13th, 19, 10:33 AM Thread Starter
Hank, When I was trying to get it to work, I had the backdrive rod from the transmission to the connector in place.
You've answered my next question about wiring the switch which is what I'm going to do.
Sleeper '69 is offline
post #18 of 21 (permalink) Old May 13th, 19, 11:05 AM
Hank
Here's the switch I have on my car. https://www.jegs.com/i/Hurst/530/2480003/10002/-1
HKalin is offline
post #19 of 21 (permalink) Old May 13th, 19, 11:54 AM Thread Starter
Do you think it needs to be waterproof? Website doesn't mention that.
post #20 of 21 (permalink) Old May 13th, 19, 12:06 PM
Hank
I would think they wouldn't make it if it was affected by water but I don't drive my car in the rain either.
HKalin is offline
post #21 of 21 (permalink) Old May 20th, 19, 11:03 PM
Hey, sorry I haven't responded. It looks like your car originally had a Saginaw and since had a Muncie installed, correct? You said that it worked at one point with the Muncie and I can't see how because the lever on the frame is opposed for Saginaw vs. Muncie. You have the Saginaw linkage on your car. If you want an aftermarket switch on the tranny, feel free. It's your car. The muncie linkages are for sale from Ground up or OPG. Beware of the Ground up linkage, I had to modify it to work by shortening and offsetting the rod from the reverse lever to the idler lever on the frame. I also had to shorten the rod from the idler lever to the column about an inch. It works very well now. I see no way of that current setup you have working with that transmission. Hope this helps.
Johnny Bravo is offline
Carpet and console - drill, screw, or cut holes? Skier_Bob Interiors 5 Oct 18th, 16 12:52 AM
Sheet Metal Hole Too Big - Screw Won't Tighten HKalin Chevelle Tech 7 Jun 6th, 14 11:40 PM
Bleeder screw leaking on front caliper El Camino Dan Brakes, Suspension & Steering 2 Feb 26th, 13 11:13 PM
Q-Jet - APT Screw Birddog1970 Engine 38 Jan 12th, 13 3:29 PM
25 min... for one screw... jullsplv Heating & Cooling 1 Dec 10th, 12 7:46 PM
