396 New engine start up issue. - Chevelle Tech
 6Likes
  • 2 Post By Jim's69Ragtop
  • 1 Post By 68SuperSport*
  • 2 Post By Robinls5
post #1 of 6 (permalink) Old Apr 12th, 19, 7:07 PM Thread Starter
Ok. So my 396 engine is new, the engine harness is new, and of course all the accessories are new as well. Here's the issue- when I start the motor,I get the temp idiot light coming on within 2 minutes of it running. I have another temp switch for the Holley Sniper kit in the manifold and it's only reading about 150-160. . Also here's a pic of the header on the side.driver's side. Note the rear header discoloration, is that from coolant leaking in or just the paint burning off?. If I put the infrared gun on the heads what should the normal temps be? Also, could it be an air bubble? I forgot to drill a hole in the tstat when I installed it.
I just don't want to run it too long at this point till I know if there's an issue or not
68SuperSport* is offline
post #2 of 6 (permalink) Old Apr 12th, 19, 7:36 PM
Re: 396 New engine start up issue.
Hi -
Are you sure your temperature sensor is for an idiot light and not a gauge? If it's for a gauge, then the brightness of the light would change as the resistance changes vs. on/off.
jim
Pioneer4x4 and 68SuperSport* like this.
Jim's69Ragtop is offline
post #3 of 6 (permalink) Old Apr 12th, 19, 8:28 PM
Ole
I was going to suggest a small hole in your thermostat. That tip works wonders.
I have aimed my laser at several engines, although (for some reason) never the 396 in my '69 Chevelle. The 350 in my '76 Chex PU reads between 180* and 190* when aimed at the head near the spark plugs.
Saltherring is offline
post #4 of 6 (permalink) Old Apr 12th, 19, 8:38 PM Thread Starter
Originally Posted by Jim's69Ragtop View Post
Hi -
jim
You know what, you may be on to something as it kinda starts out dim and then gets brighter.. Maybe it is for a guage... I'll have to recheck it.
Pioneer4x4 likes this.
post #5 of 6 (permalink) Old Apr 13th, 19, 1:09 AM
Just so you know. The " TEMP" sender I have in my LS-5 Trl. Queen is for a 1970 with gauges. When I start the 454 all is well as the engine comes up to operating temp, GEE,,, Guess What.
As the water temp goes up, The bulb gets a bit brighter & brighter. Then another GEE ! When the water gets real warm the light gets real bright.
Just goes to show you, The sender is wrong and the lite is bright, Then again the light is bright BUT the owner " ME "....... Aint to bright.
Time for an ELVIS tune.......... " RETURN THAT SENDER".
VinceS427bb and 68SuperSport* like this.
Robinls5 is offline
post #6 of 6 (permalink) Old Apr 16th, 19, 8:55 PM Thread Starter
Thanks guys, that was the issue.. I'm starting to find that it's better to look up my own parts before going to my local parts store. On a side note- I remember it doesn't seem to long ago I could walk in to any parts house and get things like PCV valves, temp and oil senders, etc... Now it's all ordered in.
I ran the car today long enough for the motor to get warmed up and to discover the heater core didn't survive the time this car has been sitting..
Oh well, drained the coolant and plugged it off for another day. Texas summer is coming and I'm not really worried about the heater for now. Hopefully it will time for a test drive by this weekend.
davewho1 likes this.
Switching from 5w30 to heavier oil in high mileage engine crazychevelle Engine 8 Apr 19th, 16 6:34 PM
67 Chevelle 396 Cam and Lifter Swap Engine in car Doug1953 Engine 9 Oct 27th, 15 8:59 PM
396 engine 325 hp or 360 hp impala6379 Engine 10 Apr 1st, 14 1:09 AM
First Start of a Cold Engine? RLM66SS Performance 10 Feb 13th, 14 10:30 AM
1969 396 complete engine sparks What's it worth? 15 Sep 24th, 13 8:53 AM
