Accelerator pedal resistance - 70 SS - Page 2 - Chevelle Tech
 25Likes
post #16 of 23 (permalink) Old May 17th, 19, 3:00 PM Thread Starter
Duane
Re: Accelerator pedal resistance - 70 SS
Originally Posted by LKN BCK View Post
When you can start it...open the hood, put in gear and give it some gas with brake on a bit more at a time and see if the motor mount or week motor mount is lifting on the drivers side.
Had a bad mount in a 69 impala back in the day and had similar issues as you until it finally broke...then while giving it gas going around a corner in would damn near give it full throttle= not good!
Yikes! I think the motor mounts are solid but now that makes me want to check again!
duanec is offline
post #17 of 23 (permalink) Old May 17th, 19, 10:02 PM
Levon
After you have done all of the items above, try loosening the 4 bolts attaching the carb to the manifold. After they are loosened, retighten lightly. Often an overtightened set of bolts will warp the base and make the throttle shaft, or butterflies bind.
LKN BCK, duanec, boyd66k20 and 1 others like this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #18 of 23 (permalink) Old Jul 5th, 19, 9:43 AM
Harry
I had a Camaro that had a bad motor mount. The accelerator cable would work great at all times except WOT. When you went WOT, the engine rose up and the accelerator cable would get stuck. The only way to slow down or stop the car was to turn off the ignition. It was a scary situation and it took a while for my brother and I to figure it out.
duanec likes this.
Harry
hjdca is offline
post #19 of 23 (permalink) Old Oct 24th, 19, 1:29 PM
Originally Posted by duanec View Post
The motor mounts are solid. I should be able to get it out of the paint shop in about a month to try some of the other suggestions. Thanks!
It's been well over a month. Have you figured out what was causing the resistance?
duanec likes this.
1775SS is offline
post #20 of 23 (permalink) Old Oct 24th, 19, 10:19 PM
Levon
FWIW look closely at the firewall area where the pedal mounts to the floor. Could be in the kickdown switch or a broken plastic pedal mount.
duanec likes this.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #21 of 23 (permalink) Old Nov 27th, 19, 2:44 PM Thread Starter
Duane
Unfortunately, no. The car was held up in the paint shop until just a couple of weeks ago. Finally finished the job that was supposed to be done in June. Then he wanted it out ASAP. Then I had to drive it straight to winter storage. This is her right after I parked it. It'll have to wait until spring because the place I store it doesn't want me doing repairs and stuff while it's in their garage.
Name:	1970 Chevelle Storage.jpg
ID:	609362   Click image for larger version
Name:	70 paint 2.jpg
1775SS likes this.
duanec is offline
post #22 of 23 (permalink) Old Nov 27th, 19, 5:55 PM
Nice looking car. Too bad about the storage facility rules. Winter time is when I do most of my repairs and upgrading. Working on my car is the therapy I need to get me through the winter.
LKN BCK, duanec and flht01 like this.
1775SS is offline
post #23 of 23 (permalink) Old Nov 30th, 19, 5:25 PM Thread Starter
Duane
If I could "love" that comment, I would. Same here. I won't be able to work on my 70 but I have a 69 SS that needs some "therapy". I'll be restoring the core support and putting in a "new" Muncie. The car and I will both benefit from winter therapy
LeoP and 1775SS like this.
duanec is offline
How much resistance is too much? 1966_L78 Electrical & Wiring 7 Sep 13th, 17 11:36 AM
wire for the resistance wire to the coil..69 chevelle cardoc76 Electrical & Wiring 1 Nov 26th, 15 6:43 AM
High resistance at fuse panel Tegguy Electrical & Wiring 28 Sep 28th, 15 5:47 PM
Ignition Wires Truths & Myths WRT Resistance SeventyOneLS5 Performance 5 Jan 17th, 15 2:16 PM
Points Type Ignition Resistance Question. rocks66ss Electrical & Wiring 12 Nov 11th, 12 9:26 PM
