Holley 600 Issues - Chevelle Tech
 2Likes
  • 2 Post By Jimmy Allen
post #1 of 8 (permalink) Old Oct 21st, 18, 11:09 PM Thread Starter
Jimmy
Holley 600 Issues
Okay hang on with me if this has been brought up already. I'm new to this. I have basic mechanical sense.
First issue: My car has a Holley Classic 600, and I've been experiencing leaks that appear to be coming from the choke shaft after I turn the motor off. Today I rebuilt the carburetor. while I had it apart, I discovered the inside of my carburetor appears to be"flaking" and a Google search showed that this was a common problem with a bunch of Holleys probably made sometime between 2001 and 2002. Is this carburetor still usable?
Second issue: I have not been able to stop the leak coming from what appears to be the choke shaft. I have already gone through the carb and the floats are not stuck. My buddy says its the shaft and the carb is done for. At this point is it even worth it to try and salvage this carburetor with these two issues or should I just replace it?
Thanks,
Jimmy
Jimmy Allen is offline
post #2 of 8 (permalink) Old Oct 21st, 18, 11:31 PM
Re: Holley 600 Issues
That area circled is a throttle shaft, but from that angle looks to be the secondary side. Do you have a picture of the flaking. Can you show a picture of the air horn, it will show the part number as well as the date manufactured. If there is lateral movement in the throttle shafts itís probably not worth fixing.
Steve R
Steve R is offline
post #3 of 8 (permalink) Old Oct 22nd, 18, 6:14 AM
Geoff
Put an Edelbrock on it...
Gtogeoff is offline
post #4 of 8 (permalink) Old Oct 22nd, 18, 9:42 AM
Check your float levels for the leaking problem.
oldcutlass is offline
post #5 of 8 (permalink) Old Oct 22nd, 18, 1:47 PM
tom
call Holley and tell them you may have one of those defective carbs. They may send you a new or refurbished one. that's how I got mine.
tm
tm66 is offline
post #6 of 8 (permalink) Old Oct 22nd, 18, 2:38 PM
tm
Itís nearly 20 years old, itís out of warranty. Besides he wasnít the original purchaser. How old was your when they replaced it?
Steve R
Steve R is offline
post #7 of 8 (permalink) Old Oct 23rd, 18, 1:34 PM
tom
Bought a refurbished one from a speed shop about 10 years ago. Car ran worse so started investigating and saw the flakes. Called Holley to see what they thought and after giving them the numbers (don't remember which ones) they came back and just said "We're sending you a new one. Please end this one back to us."
You can't strike out if you don't go to bat.
tm
tm66 is offline
post #8 of 8 (permalink) Old Oct 27th, 18, 3:06 AM Thread Starter
Jimmy
Yeah all kinds of lateral play so I picked up a new one and everything is solved.
Steve R and LeoP like this.
This Thread is more than 479 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
