Back firing through the exhaust-HELP!!! - Chevelle Tech
  • 1 Post By wes-in-nc
post #1 of 6 (permalink) Old Oct 18th, 18, 4:04 PM Thread Starter
Wes
My daily broke down so I had to dig my Nova project out of the garage for a daily for a week or two. I drove it a few days last week to work and it was back firing through the exhaust and just running rough in general. Its a stock bottom end '76 350 with double hump heads, a cam of unknow size and a edelbrock intake with a holley 600dp. Its got a new MSD hei with new plugs and wires. I rebuilt the carb yesterday and replaced all gaskets, pumps and power valve. I took it around the block and it seemed fixed. Well today, I took it on a 25-30 trip to enjoy the car and weather and it ran terrible. Back firing through the exhaust on the slightest load and surging under part throttle. On the way back, I stopped at the local supermarket for some adult beverages and the 4 miles back home, the car ran great!!! What am I missing here???? I know my way around a toolbox but this has me flustered!! Any ideas?? Thanks!
1967 Chevelle SS (2020 Drag week hopeful)
1971 Nova SS
Keep on keeping on
wes-in-nc is offline
post #2 of 6 (permalink) Old Oct 18th, 18, 4:59 PM
Re: Back firing through the exhaust-HELP!!!
Sticking vacuum advance, cracked vacuum line?
Pioneer4x4 is offline
post #3 of 6 (permalink) Old Oct 19th, 18, 3:15 AM
Bad tank of gas?
How long was it parked?
David
davewho1 is offline
post #4 of 6 (permalink) Old Oct 19th, 18, 6:38 AM
Geoff
Backfiring through the exh [ through the intake. different story ] with the slightest load sounds more likely to be electrical.
Check that the HEI is getting 12v or more with the engine running.
Double check initial timing [ with vac adv disconnected ]. If it checks out, do a resistance check on all the leads. Try another set of spark plugs, then another coil/module.
Gtogeoff is offline
post #5 of 6 (permalink) Old Oct 19th, 18, 8:48 AM
Exhaust leak, maybe? A little fresh air getting into your exhaust can complete combustion a little more to give you a backfire.
Sent from my SAMSUNG-SM-N900A using Tapatalk
B52bombardier1 is online now
post #6 of 6 (permalink) Old Oct 19th, 18, 9:48 PM Thread Starter
Wes
Team, Thanks for all the replies!! @Pioneer4x4 , its done this with 2 completely different HEI distributers. @davewho1 , the car sat for 30 plus years but I put in a new tank and its a fresh 10 gallons…..ethanol junk though. I used the AC Delco Green shield hose but I needed gas and couldn't make it to my local "Pure" gas station, lol. @Gtogeoff , that might be something I need to look into. When I switched to HEI, I did not verify that a true 12 volts was coming though the lead that I used. @B52bombardier1 , the exhaust system is a new 2 1/2 system from Summit. It has lots of leaks. The system had terrible fitment issues. I think the kit for a Ford truck got sent to me, lol.
At first, I thought was the Holley carb but now I think its something electrical. I drove the car to work today and not a single issue. The carb is rich but that's a different issue. Thanks again for all the suggestions!!
davewho1 likes this.
1971 Nova SS
Keep on keeping on
This Thread is more than 483 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
