Some more questions - Chevelle Tech
 7Likes
  • 2 Post By Saltherring
  • 5 Post By DUTCH MAX HEADWORK
post #1 of 12 (permalink) Old Jun 25th, 18, 2:34 PM Thread Starter
Some more questions
Hi guys,
Getting used to the car a bit; switched tires on sunday, checking lights and stuff i found 2 parts im not sure what they do. Beneath the lights switch, is that the choke?
And left to the emergency brake, those 2 handles? Front seat passenger has the same handles.
ID:	567641   Click image for larger version
Cheers
stagedriver is online now
post #2 of 12 (permalink) Old Jun 25th, 18, 2:50 PM
Re: Some more questions
Knobs, 2 for each side are your vents. Pull to open, push to close.
The problem with designing something completely foolproof, is you underestimate the ingenuity of complete fools. - Douglas Adams
db11020 is offline
post #3 of 12 (permalink) Old Jun 25th, 18, 4:10 PM Thread Starter
I guess im rather save than sorry
And about choke? Car runs a 750 dp 4779-2 carb. Google said all of those come with a manual choke.
Cheers
post #4 of 12 (permalink) Old Jun 25th, 18, 4:35 PM
My 72 doesn’t have that. Not sure what that is.
db11020 is offline
post #5 of 12 (permalink) Old Jun 25th, 18, 10:47 PM
Ole
I've never needed or used a choke on a double pumper...or any other Holley. I simply pump the gas pedal twice and turn the key. And if it doesn't start, repeat the process. If you have a choke butterfly plate, wire it open.
Saltherring is offline
post #6 of 12 (permalink) Old Jun 25th, 18, 11:25 PM
Your first picture, that does not look like a pull lever for a manual choke. A choke pull lever should / would look like a headlight knob or like your vent knobs in picture #2, but it would be an aftermarket part (Generic looking, maybe on a sheetmetal bracket.) Picture #1 looks like an AC vent.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
zeke67 is offline
post #7 of 12 (permalink) Old Jun 26th, 18, 12:04 AM
Al
From the top of picture 1, 1st square sliding knob is windshields wipers, 2nd round shiny knob is headlight switch. 3rd bid round thing is the Astro air vent or a/c vent if you had a/c. I see no choke controls in either of your photos. If you can pull the air cleaner off and snap some pictures of the right side of the carb, we can tell what type of choke you have. Some carbs have no choke, some have a cable activated choke, and some are electrically operated.
The second picture shows what is called the Astro ventilation controls. They open the foot air vent and the other makes the air come from the dash vent. The air you get through the vents comes from the cowl area in front of the windshield when you car is moving. When you drive the car, pull or push on them and you will get the idea.
This statement was not made towards you or in response to your post. "The problem with designing something completely foolproof, is you underestimate the ingenuity of complete fools. - Douglas Adams" It's Dan's signature line and appears in all of his posts.
LeoP, RealRed70, Blown1932 and 2 others like this.
DUTCH MAX HEADWORK is offline
post #8 of 12 (permalink) Old Jun 26th, 18, 12:41 AM
Al
You'll need to check to see if this is hooked up. It maybe wired open or held open in some way.
Here's a list of various choke cables so you can see what they look like. If you don't have one you can install one. But many of us don't use the choke cable, we sit in the seat and keep the car running with our foot until it warms up. In cooler temperatures, a choke may do you some good.https://www.summitracing.com/search/...e/choke-cables
post #9 of 12 (permalink) Old Jun 26th, 18, 10:37 AM Thread Starter
My bad, but i guess its related to my job. If you learn something in the military its "Dont push buttons you dont know"
Made some pictures of the carb
Btw thanks guys for your help
ID:	567921   Click image for larger version
ID:	567929   Click image for larger version
ID:	567937   Click image for larger version
Cheers
post #10 of 12 (permalink) Old Jun 26th, 18, 12:41 PM
blm
I have the same carb on my 69 with a 396 engine. You can put an.electric choke on that carb. It is what I would recommend and then it is automatic. Don't have to think about it. It is an easy install. Many moons ago when I bought my car it did not have a choke on my 750 double pumper. Can't remember where I bought it but most likely Summit Racing. Will just have to run a wire to a 12 volt source that is key activated.
blm is offline
post #11 of 12 (permalink) Old Jun 26th, 18, 2:18 PM
Al, in post #7 has it all sorted out for you. Great job Al.
RealRed70 is offline
post #12 of 12 (permalink) Old Jun 26th, 18, 2:33 PM
. Too many years as an engineer. No offense intended with my signature.
db11020 is offline
This Thread is more than 645 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
