fuel gauge not working - Chevelle Tech
post #1 of 3 (permalink) Old May 30th, 18, 8:19 AM Thread Starter
RT
Rich
After an engine swap, I added some under dash gauges which meant I had to move some wires around under the dash. I thought that I might have disturbed something going to the fuel gauge, because it's not reading properly. It stays around the 1/4 mark even though there is a full tank. Checking around, the connections to the back of the gauge are tight. Anyone have any ideas about what could be causing this condition? It seems like quite a coincidence that a perfectly working fuel gauge (up until now) should go out at the same time I did the engine swap and gauge cluster installation.
Thanks,
Rich
Rich
'69 Malibu hardtop
'69 Malibu convertible
RT is offline
post #2 of 3 (permalink) Old May 30th, 18, 9:54 AM
Re: fuel gauge not working
You need to check everything you did, it probably is related. make sure you have power to the gauge.
oldcutlass is offline
post #3 of 3 (permalink) Old Aug 27th, 18, 11:15 PM Thread Starter
RT
Rich
I just realized I never followed up on this. I ended up dropping the tank and replacing the sending unit. Problem solved.
Rich
Rich
'69 Malibu hardtop
RT is offline
This Thread is more than 541 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
