'66 El Camino Motor Mount Problem - Chevelle Tech
post #1 of 4 (permalink) Old Apr 1st, 18, 8:18 AM Thread Starter
Clyde
I have a '66 El Camino with a ZZ4 Crate engine and Sanderson cast iron headers. I recently had the motor mounts changed at a shop. I now find that there is contact between the drivers side header and the frame. (cross member) I had clearence here before the motor mount change. I'm wondering if there are different heigth motor mounts available and that the shop could have used some that allowed the engine to sit lower. Possibly different heigth for different applications. Maybe one of you guys out there would have a part number for correct mounts. Any input will be greatly appreciated. Thanks
w7qhhcf is offline
post #2 of 4 (permalink) Old Apr 1st, 18, 4:52 PM
Clint
Re: '66 El Camino Motor Mount Problem
Any chance you could have gotten 307 motor mounts? IIRC, those are shorter.
Clint Hooper
Sold
Sold
Clint44 is offline
post #3 of 4 (permalink) Old Apr 12th, 18, 9:26 AM
T_R
It's a 50 year old car with aftermarket parts. Things just aren't going to fit perfectly. My 66 I had to put a few washers under the mounts for oil pan clearance. If you want the engine lower you can slot the holes in brackets also.
66 Chevelle crew cab 454 FiTech TKO 600 5 speed
T_R is offline
post #4 of 4 (permalink) Old Apr 12th, 18, 10:35 AM
1964-67 SB/BB mounts have the same width between the mounting ears 2-5/8" and the same height 1-3/4" as 68-72 307's fwiw. BB's were 2-3/8"Wide x 2-3/16"Tall so they would not even fit over the 1964-67 frame brackets. So, that mount would be correct for the early A-Body fwiw.
My 1965 El Camino with a later model 454 with an early OEM GM A-Body oil pan (with tie rod dimples) had a minimum of 1" between the bottom of the pan and the front of the cross member and 5/8" at the rear edge of the cross member. This was using Energy Suspension 3-1114G poly mounts.
USAF Retired (1968-1988)
David Bates is offline
This Thread is more than 718 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
