Can you make an OEM looking fuel line? - Page 2 - Chevelle Tech
 8Likes
post #16 of 26 (permalink) Old Dec 19th, 17, 2:48 PM
Re: Can you make an OEM looking fuel line?
Jegs...
Front to Rear Fuel Line 1964-1967 Chevy Chevelle, 3/8 | JEGS
Gulf Coast Chevy is offline
post #17 of 26 (permalink) Old Dec 19th, 17, 6:27 PM
Craig
James,
FWIW - I bought my 66 fuel line from Inline Tube and the fit was just like factory. I bought the stainless version because I was concerned about what might change in fuel specs (i.e. Alcohol content, etc.) in the future. The only comment I'd make is to be sure of your application. My car is a factory SS car and the factory fuel line runs up over the frame spring perch at the right rear, and stays outside the body mounts along the frame until it makes a 90 degree bend (see below). The AIM shows a line routing that bends inward around the inside of the frame's upper spring perch, which is clipped to the frame. I'm 100% positive that the outer routing is correct for an SS car, but make sure of what you have before ordering, because return would be a pain. My Inline Tube line had the barbed ends.
Craig
craigs66 is offline
post #18 of 26 (permalink) Old Dec 19th, 17, 7:16 PM
buy the premade if you have to tweak it some so be it
Dont even bother with stainless it doesnt want to bend at all. Ordered one in stainless long story short spent way too much doing one out of 1/2 in had body fit issues not worth it!
cuisinartvette is offline
post #19 of 26 (permalink) Old Dec 19th, 17, 8:03 PM
Banned
Cory
Originally Posted by james a larson View Post
Hi Cory, did the OEM lines have the end barbed, I think my line is OEM where there is just spring clamps that holds the rubber hose to the fuel line; but who knows, maybe it was replaced before.
A bubble style barb at each end - yes on my OEM 66 SS
dream66 is online now
post #20 of 26 (permalink) Old Dec 20th, 17, 2:04 PM Thread Starter
I guess mine may have been replaced or there were different suppliers as I am almost positive it does not have the barbed end at the rear. Not able to get at the car for a few days to make sure.
Mine looks like Craig’s as it goes over the top off the frame above the spring,except there is a wire spring over the line where it could contact the frame in front of the rear wheel.
Jim_66SS is offline
post #21 of 26 (permalink) Old Dec 20th, 17, 3:16 PM
Craig
James,
FWIW - The picture I posted was not my car. I just posted the picture to show the outside line routing. My original line, and the Inline Tube line both had barbs at both ends and the spring guarding you described. My stainless line fit very well and didn't need to be tweaked to fit, but I do live in SE Michigan, so I picked it up at Inline Tube with no shipping involved. I'm a little anal, so I went with stainless because the newer fuels can be very corrosive and I didn't want to gamble moving forward. I also used a stainless tank and sender for the same reason. Good luck with your project and let me know if you need any other info.
Craig
BTW - a photo of my car with the Inline Tube line is included below
LeoP likes this.
craigs66 is offline
post #22 of 26 (permalink) Old Dec 20th, 17, 3:56 PM
Banned
Cory
FWIW - I replaced a 66 3/8" fuel line for a friend with Nickel/Copper bulk line while the car was on the frame and the bushing bolts loosened to give us an inch or so extra room. Wasn't easy but was doable. Over the axle was the hardest area.
No springs but used clear plastic hose as a protective cover in the critical rub areas.
Another thing. In the pic from the previous post notice how the fuel line has a protective black rubber sleeve as it enters the frame horn in the front.
In the pics below I show a couple of chaffed areas on a different car due to worn body bushings. On that car I located the springs in those two chaffed areas when installing a new line. Not sure if that is OEM correct but it made sense to me. I also used rubber sleeved tubing clamps with self tapping screws to secure the line to frame in several areas. The original style clamps are probably adequate but I used what I had on hand.
Name:	Aztec Fuel Line - 1.jpg
ID:	504474   Click image for larger version
Name:	Aztec Fuel Line - 2.jpg
post #23 of 26 (permalink) Old Dec 21st, 17, 11:13 AM
If you dont mind cutting and putting a union partway makes it much easier
x2 on using anything to keep the lines from rubbing. Noones going to see it anyways.
post #24 of 26 (permalink) Old Dec 21st, 17, 2:37 PM
Jon
I used inline tube and I thought they were great. One if my lines was too short and I asked them to make me a longer one. They overnighted it to me and then called a few days later just to make sure it fit. I would use them again and the lines look great.
1972 Chevelle SS 454 "W" code
JChilders is offline
post #25 of 26 (permalink) Old Dec 22nd, 17, 12:37 PM Thread Starter
Well I decided on the Right Stuff’s OEM steel line from JEGS, it is suppose to be seamless,barbed ends, correct guards and shape for the 66 SS cars. Free shipping since I ordered some additional things, so cost turned out to be about $61. A friend suggested a clear lacquer finish.
Jim_66SS is offline
post #26 of 26 (permalink) Old Dec 22nd, 17, 1:43 PM
Cant beat the price on that one! Most clears yellow over time maybe theres stuff out now that doesnt.
If its new it will look good for a long time
This Thread is more than 793 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
