AFR 265- What Bore/stroke would be best for a 500" - Chevelle Tech
 12Likes
post #1 of 19 (permalink) Old Jul 11th, 17, 12:32 AM Thread Starter
Andy
OK so let me state this, I have a set of CNC AFR 265's on my 408" BBC .... Thinking about throwing a few more cubes under them.
From what I can tell these heads could support upwards of high 600 HP to possibly 700, Thinking of maybe a 670 ish build. So thinking 496 in to 509 ish.... which might be a tad big for these heads?
That being said, also what Bore Stroke combo would be best fit with these heads? Would it make any noticeable difference between a 4.25 stroke and 4.310 bore over 4.0 stroke and 4.56" bore for these heads?
Or when looking at airflow, is Cubic inches all that matters? Since HP is directly related to the amount of flow available? It seems to me that velocity plays a part of how these heads flow well to about 6,000 rpms.... does that change with a short stroke larger Bore, or is it all relative to cubic inch?
I am leaning on a short stroke larger bore, for less torque (light car 3000#) but still hit the HP numbers I am looking for. But can easily swayed into a 496" for lower revving easy on parts and the pocketbook build.
Thanks for any help.
Ialone is offline
post #2 of 19 (permalink) Old Jul 11th, 17, 2:52 AM
Devin
Re: AFR 265- What Bore/stroke would be best for a 500"
Somebody will argue with this, but without racing intent stated, I would stay with a simple 454. Those heads will work well. No need to overthink or spend cubic dollars without a goal to win.
Steve R and Ialone like this.
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #3 of 19 (permalink) Old Jul 11th, 17, 4:53 AM
pretty much same here, but I'd do a 4.310 x 4.25 496. stock block easy to get parts, lot's of choices available for crank/rods/pistons. If you buy decent stuff like a internal balance 4340 Scat crank and Scat 6.385 rods you'll be able to re-use the stuff in a Dart 4.5" or 4.6 block later.
Ialone likes this.
post #4 of 19 (permalink) Old Jul 11th, 17, 6:56 AM
Basically you run into 2 issues. Long stroke cranks use up more head than a large bore motor. But on the flip side, a 509 will need a 4.5 bore block, and you are not doing that without a special block. If it was me, I would look at just building a 468. Put a stock steel crank in it and go.
Ialone likes this.
bracketchev1221 is offline
post #5 of 19 (permalink) Old Jul 11th, 17, 7:09 AM
As stated above, if you are not racing and you are keeping an eye on your pocket book, why spend the extra money that may only give you marginal improvement. Spend the extra money on other items that may need upgrading.
Steve R
blue_69_malibu likes this.
Steve R is offline
post #6 of 19 (permalink) Old Jul 11th, 17, 9:08 AM
While the combos weren't optimized, a rag did a story several years ago comparing all 3 - short stroke/big bore, medium both ways and long stroke/small bore. All made within a few ft lbs and hp of each other.
Least expensive is 496, the others require either a 502 or aftermarket block.
blue_69_malibu and Ialone like this.
Gary Adrian
Busted Knuckles is offline
post #7 of 19 (permalink) Old Jul 11th, 17, 10:33 AM Thread Starter
Andy
Appreciate all the advice... My issue is finding a good block anyway that I wont have near $1500 in just to buy and machine... almost the cost of a good aftermarket 4.5" block... so the extra $600-700 really isn't that much more.
Unless any of you know where I can get a good 60 over 4 bolt GM block with good lifter bores for cheap? Everything I have come across lately is around $1,000..... without any machine work.
The goal is to get my 3000# car into the 9's... no power adders
Ialone is offline
post #8 of 19 (permalink) Old Jul 11th, 17, 11:25 AM Thread Starter
Andy
Originally Posted by EZ Nova View Post
Andy, WHAT DO YOU HAVE NOW??????
9 seconds at 3000 lbs is a fairly easy job to do. Just let us know what you have and "we" as a group and help with the results.
But might be the best "band-for-the-buck" to call Mark Jones and get him to work with you!!!!
I have a small 408" never dyno'd most likely 500 HP ish... It takes more cubes to make the HP I need without having to spin it over 7000...
Mark is on my list to call.... thought about sending him my heads and intake and see what he can do.
Ialone is offline
post #9 of 19 (permalink) Old Jul 11th, 17, 12:31 PM
The heads out of the box will support 712HP with no mods. It will take a max effort cam. I have shelf semi customs in a 496 pump gas with the 265's that have made over 625HP.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #10 of 19 (permalink) Old Jul 11th, 17, 1:51 PM
George
How far from Ohio are you? Lots of 454 blocks around here. Proabably not 4 bolt, but 2 bolts are about everywhere...
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #11 of 19 (permalink) Old Jul 11th, 17, 3:49 PM
Don't be afraid to spin it. My 540 was shifted at 7400 and crossed as high as 7800. My 565 now made peak power at 7200 and will be shifted at 74-7500. Big engines can rpm just fine.
post #12 of 19 (permalink) Old Jul 11th, 17, 4:10 PM
Marcus
See if you can send your heads to Mark Jones and he can build you a nice 496 with them.
https://www.chevelles.com/forums/13-p...ne-intake.html
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
57 3/4Ē wide 12 bolt: Eaton posi, Us gear 3.31, Toms KA 33 splines axles
Malibu ss 64 is offline
post #13 of 19 (permalink) Old Jul 12th, 17, 7:02 AM
FWIW, my 4200 lb truck ran a best of 11.09 with a 1.50 60 ft, 496 with the same AFR 265's, 10.0 CR and a Straub solid roller
Ialone likes this.
90 454SS
92 454SS
va454ss is offline
post #14 of 19 (permalink) Old Jul 12th, 17, 8:50 AM
Jarad
That is impressive.
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
post #15 of 19 (permalink) Old Jul 12th, 17, 9:15 AM
Scott Foxwell
Those heads on a 496 will work very well.
Ialone likes this.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
This Thread is more than 961 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
