Sway bars are heavy - new corner weights - Chevelle Tech
 4Likes
post #1 of 27 (permalink) Old Jul 3rd, 17, 12:13 PM Thread Starter
I weighed my 71 Chevelle yesterday and was disappointed to see how much fatter she got.
What I weighed before
3756 lbs with a full tank (~20 gallons stock tank)
1075/1088
802/791
57.59/42.41%
Changes since then:
Rick's stainless steel tank with in tank pump.
PTFE -6 feed/return lines
FiTech EFI
some bigger electrical wires
ProCar Rally seats
Removed some heater hoses
1 3/8 Hotchkis hollow front sway bar
1 1/8 Hellwig rear sway bar
Custom rear weight jacks
3801 with a full tank (~22 gallons)
1040/1094
865/802
56.14/43.86%
The good news is my front/rear weight distribution is improved.
I may need to really start looking at buying lighter parts, and I want carbon fiber so $$$$$$
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #2 of 27 (permalink) Old Jul 3rd, 17, 1:23 PM
Re: Sway bars are heavy - new corner weights
Is that with or without you in the car?
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #3 of 27 (permalink) Old Jul 3rd, 17, 1:32 PM Thread Starter
Without me. Just 135-140 lbs of fuel onboard.
Youtube Channel.
Instagram:
Twitter:
post #4 of 27 (permalink) Old Jul 3rd, 17, 1:41 PM
What are "rear weight jacks". Sounds heavy
'72, 385 sbc, Voodoo roller, 219/227; .515/,530 lift; AFR 180cc Eliminators, RPM Air-Gap, 770 Avenger, TH350 trans, 12 bolt 3.42's, Eaton Posi, TCI 2000 stall, Pypes 2 1/2" X-pipe system w/Race Pro's
Vehicle weight: 3390 lbs
Autoengineer_ is online now
post #5 of 27 (permalink) Old Jul 3rd, 17, 1:59 PM Thread Starter
https://www.chevelles.com/forums/8922353-post40.html
Aside from the big bolt, the weight jacks didn't add any extra weight over the raised spring jacks that were there.
Youtube Channel.
Instagram:
Twitter:
post #6 of 27 (permalink) Old Jul 3rd, 17, 2:10 PM
Question Re: Sway bars are heavy - new corner weights
What does your battery weigh? Front or rear mount?
Rex Auftinn is offline
post #7 of 27 (permalink) Old Jul 3rd, 17, 2:37 PM Thread Starter
Full size battery, mounted in the front. Probably 30 lbs.
Youtube Channel.
Instagram:
Twitter:
post #8 of 27 (permalink) Old Jul 3rd, 17, 3:55 PM
Gotta be that fuel tank then if I'm reading your numbers right. Looks like the weight gain was mostly all in the rear drivers side? Besides 2 more gallons of gas, must be heavier gauge of steel? Heavy fuel pump now in tank?
post #9 of 27 (permalink) Old Jul 3rd, 17, 4:09 PM
Lew
Question in general on car. Aluminum heads (y/n), aluminum wheels (y/n).
Lew540 is online now
post #10 of 27 (permalink) Old Jul 3rd, 17, 4:16 PM Thread Starter
The stainless steel tank with fuel pump was over 50 lbs dry, much heavier than the stock tank.
Rear sway bar was 18 lbs
II Much vent and line was probably 5 lbs
Wire and nuts and bolts were probably 10 lbs total.
Front sway bar is 5 lbs heavier than stock bar.
probably 20 lbs more fuel than the last time.
It all adds up.
Youtube Channel.
Instagram:
Twitter:
post #11 of 27 (permalink) Old Jul 3rd, 17, 6:00 PM Thread Starter
All steel car. Full interior.
Iron headed LS5 BBC. Aluminum radiator
Has Cragar Keystone Klassic wheels. When I put my drag wheel/tires on I drop about 69 lbs.
Youtube Channel.
Instagram:
Twitter:
post #12 of 27 (permalink) Old Jul 3rd, 17, 6:06 PM
put a set of Al heads on that thing. drops a bunch of weight all off the front and runs better.
post #13 of 27 (permalink) Old Jul 3rd, 17, 6:30 PM
Ultra-Carbon will be taking orders again if interested.
Ultra-Carbon | Custom Carbon Fiber Race Parts & Accessories
Rex Auftinn and USMC_Spike like this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #14 of 27 (permalink) Old Jul 3rd, 17, 8:46 PM
jackie
It usually surprises most car owners when they finally weigh their car.
I also have a Ricks Stainless Steel Tank with the one gallon Sump. True, it weighs 50 lbs. but the stock tank will bump 30, so it's only 20 more. And, it's 20 more where you need it.
Finest full size Tank made.
https://www.chevelles.com/forums/atta...1&d=1499129144
jackie schmidt is offline
post #15 of 27 (permalink) Old Jul 3rd, 17, 9:01 PM Thread Starter
I'd rather not put money into the 454 as I'd rather build a 509 with all new goodies. Though a the best way to lose weight and gain power.
It appears they are taking orders again. My dream has always been a bunch of carbon fiber parts, so I may have to think of doing this sooner than later. Lots of $$$ and I'd need to think of where I could put the original doors/fenders, etc.
Youtube Channel.
Instagram:
Twitter:
This Thread is more than 997 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
