Anyone Using The Light-Wt Mopar Master Cylinder? - Chevelle Tech
 5Likes
  • 1 Post By davewho1
  • 1 Post By 67Mike
  • 1 Post By Tom Mobley
  • 1 Post By ChevelleFan70
  • 1 Post By Calculated Risk
post #1 of 9 (permalink) Old Jun 27th, 17, 9:55 PM Thread Starter
Question Anyone Using The Light-Wt Mopar Master Cylinder?
Is any one running the Mopar-style light-weight aluminum dual master cylinder?
Experience, tips...?? Thank you
Rex Auftinn is offline
post #2 of 9 (permalink) Old Jun 27th, 17, 10:03 PM
Bruce
Re: Anyone Using The Light-Wt Mopar Master Cylinder?
What's a "Mopar?"
Sorry, I couldn't resist...
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 9 (permalink) Old Jun 27th, 17, 10:06 PM Thread Starter
Probably should have asked in the Performance section.
post #4 of 9 (permalink) Old Jun 27th, 17, 10:57 PM
I'll move it there.
Rex Auftinn likes this.
David
davewho1 is offline
post #5 of 9 (permalink) Old Jun 28th, 17, 3:08 AM
Yes, used in my car for 20 years. Works fine but the caps always leak a little fluid. Common problem with this style m/c.
67Mike is offline
post #6 of 9 (permalink) Old Jun 28th, 17, 2:57 PM
save yourself time and fabbing of parts needed.
Aluminum Master Cylinder
They had/have this same part with stainless steel bore sleeve. I have one of those but they're claiming to be out of stock now.
post #7 of 9 (permalink) Old Jul 1st, 17, 1:09 PM
They are. SSBCbrakes imports them I beleive.,. Listed as a Corvette disc.drum master in aluminum, Like $80. They told me a month out a few weeks back. I bought the heavy weight as its correct for my Chevelle.
SSBC Performance Brake Systems
post #8 of 9 (permalink) Old Jul 1st, 17, 2:23 PM
Not sure how a Corvette M/C can be disc/drum, because there has never been a disc/drum Vette. '53-'64 was drum/drum, '65-up disc/disc.
-Dave
'70 Chevelle ZZ383/700r4/3.73, [email protected] -- MS3X efi / Hotchkis A-arms & Springs / B-body 12" brakes / 1.25" F-body swaybar / UMI rears & swaybar / JGC PwrStrUpg
ChevelleFan70 is offline
post #9 of 9 (permalink) Old Jul 2nd, 17, 10:15 PM
I use the Strange Engineering version on my Chevelle, and Wife's Mustang, an 86 Plymouth Horizon M/C on my Monte Carlo and an unknown Mopar on the Nova (which is a chassis car with the m/c mounted under the floor).
I like the Mopar master cylinders. They are lite, many bore sizes to help get the pedal feel you like, and they are cheap.
Only problem is they are not a direct bolt in. On my Chevelle i had to remove the studs in the pedal assembly and weld in new studs slightly wider. Not hard to do if you can weld and fabricate.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
This Thread is more than 1012 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
