El Camino - strip car build :) - Page 30 - Chevelle Tech
 575Likes
post #436 of 456 (permalink) Old May 18th, 19, 1:30 PM
Greg.
Re: El Camino - strip car build :)
If you left in 2nd Gear there is no Shift from 1st to 2nd as you are already in 2nd Gear
Why not Leaving/Launching in 1st ?
Why is the Tach Light on at the End of the 1/4 ? set to low ?? What Rear Gears ???
OR your Engine's Max RPM in Top Gear is reached to soon just before the End of the 1/4
and thus to much Gearing for it
OR you just taking it easy this First Time out with the Car ?
You have a TH400 ? Did you have it Built with a good Shift Kit & Adjusted so you can feel the Change in Gears when you shift it ??
Is there a Trans brake in the Trany ?
if not, and just FootBraking try leaving/Launching off Idle and push your Foot into it slowly to the Floor
then each next time you go up increase the speed of your Foot going to the Floor a little Faster
each time and see what works the Best
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #437 of 456 (permalink) Old May 19th, 19, 4:15 AM Thread Starter
OLIVER
The th400 was built in the US by Marks guy , Its full automatic and can be also manually shifted , its a standard fw pattern , if i leave in 2 the 1-2 shift is done by the tranny then i just to shift it i 3rd .
The shift light is set a 6600 so naturally it come on again in high gear , i cross the line at 6900 - 4.10 and 28 tires
Converter is ATI 8inch 5000 stall specific for footbrake.
Definately in the next race i m going to shift it myself Cant wait !!!
Steve R and Kirk's67SS like this.
Oliver
Milano , ITALY
468 Vortecpro 585 HP back to street cruiser
M20 4 speed - 3.31
Prosystems 1000
BEST ET 11.62 (with 4.10)
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
1969 El Camino Street Strip
467 Vortecpro Tunnel ram 730+ hp TH400
BEST ET 10.67 @ 127 1.56 60FT
oliver69 is offline
post #438 of 456 (permalink) Old May 19th, 19, 11:37 AM
Greg.
Is the BBC built to safely Rev Higher than 6,600 RPM all the time every Shift ?
Post # 191 shows your Engine Dyno #s as
700 HP @ 5,900 RPMs
729 HP @ 6,700 RPMs the last/Highest Reading on the Dyno Sheet
So is it okay with Mark that you will be Hitting the 6,900 RPM everytime you Shift/go down the Track ??
My BBC rarely sees 6,000 RPMs and I never see the Tach Light come on at the End of the 1/4
as it is set for 5,800-5,900 RPMs
I guess your Engine is setup for the 800-1,000 RPMs higher Revving
Born 283 / PG / A51
60' = 1.664
60' = 1.561
post #439 of 456 (permalink) Old May 20th, 19, 3:43 PM
You will be much happier shifting it manually, make the combination work for you. Your going to be burning up parts otherwise. I have heard, and you should check that the turbo 400 combinations like to be short shifted a little bit 1-2 then your normal shift RPM to 3rd.
Oliver learn you procedures, and practice, practice, practice. Start with going through the water box, burn out, stage, launch, shift, shut down. Sit in the car, and visualize, and practice it in your mind, then on the track. It will become 2nd nature/natural to you.
oliver69 likes this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #440 of 456 (permalink) Old May 20th, 19, 4:36 PM
What was the 60' leaving in 2nd?
Was it slower?
WHT/73 is offline
post #441 of 456 (permalink) Old May 21st, 19, 5:25 AM
Larry
I played around with the governor on my t400 , got it shifting right around 6500 , did a [email protected] in "drive" , also adjusted the vacuum modulator so it wouldn't shift too early when cruising, otherwise you end up stop/go driving around town in top gear on the converter
Cowfarmer is offline
post #442 of 456 (permalink) Old May 21st, 19, 1:39 PM Thread Starter
OLIVER
Was it slower?
in 8 runs all my 60 ft were between 1.56 to 1.58 , there was no difference in leaving in D or 2 gear , probably the tans was shifting in the same point
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #443 of 456 (permalink) Old May 21st, 19, 11:37 PM
Doesn't the TH 400 leave in 2nd if manually put there?
WHT/73 is offline
post #444 of 456 (permalink) Old May 22nd, 19, 1:14 AM
Converter flashing past 1st gear shift in drive? I'm not up on automatics....
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #445 of 456 (permalink) Old May 22nd, 19, 3:56 AM Thread Starter
OLIVER
i think only if is full manual
my trans is automatic so i believe if you leave in
3 (D ) starts in 1 shifts to 2 then to 3 , this i can confirm because on the return road i can hear all shifts
if you leave in 2 should start in 1 shift to 2 and stay in 2
leave in 1 stay in 1
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #446 of 456 (permalink) Old May 22nd, 19, 7:27 AM
You are correct. A manual valvebody will pick each gear. If you leave in 2 with an automatic valvebody it will start in 1 and shift to 2 and stay there. Do you know what it is automatically shifting at?
Ray
bracketchev1221 is online now
post #447 of 456 (permalink) Old Jun 22nd, 19, 5:47 AM Thread Starter
OLIVER
Inviato dal mio iPhone utilizzando Tapatalk
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #448 of 456 (permalink) Old Jun 22nd, 19, 6:01 PM
Greg.
WOW Oliver that looks great
My Young Son 2 and I are going up Racing tomorrow/Sunday here to see how the Rebuilt TH400
with the Reverse Manual VB plus New Shifter and New Higher Stall Converter will do
I plan on doing a Thread on it, so watch out for it
Born 283 / PG / A51
60' = 1.664
60' = 1.561
post #449 of 456 (permalink) Old Aug 4th, 19, 10:14 AM Thread Starter
OLIVER
The next big race is coming up at the end of August ...only a few weekends to prepare the car and check everthing. I did not drive the car on the street yet as it has the race seat and harness and open headers and that s a big no no if i get stopped by police
We wanted to hook up the 2step rev limiter and wire it to the brakes . Also i wanted to see what rpm the brakes will hold against the converter. We did also back street test and burnout . Definately fun to hear the car , its a beast ))
https://youtu.be/mUEvG-koU70
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #450 of 456 (permalink) Old Aug 5th, 19, 2:12 AM Thread Starter
OLIVER
So we have a problem with the 2step rev limiter ; it does not limit the rpms !!!
Everything is wired correctly ; arming switch + switch on the roll control and when you press the brakes it should limit the rpm ...the check light on the box works perfectly but it does not limit !! We moved around the dials but nothing .. i dont know why ? It was wired the same way in the chevelle but only to the clutch ... it worked perfect ! Any ideas ? Maybe the box went bad i have the call msd tech line for any troubleshooting
I can hold the car with the brakes to 2000 rpm tops, here the vids
2 step
https://youtu.be/VCYb0e6xVRE
And footbrake
https://youtu.be/Tn9TKZIFXKQ
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
