El Camino - strip car build :) - Page 28 - Chevelle Tech
 575Likes
post #406 of 456 (permalink) Old May 13th, 19, 9:29 AM
gary
Re: El Camino - strip car build :)
Thatís great for the first time out! How often are the drag races held?
oliver69 likes this.
post #407 of 456 (permalink) Old May 13th, 19, 9:47 AM Thread Starter
OLIVER
At the moment 2 long weekends per year one in May and one in September ... 2 passes friday , 4 or 5 on saturday , sunday eliminations ... definitely not enough
Kirk's67SS and Blown1932 like this.
Oliver
Milano , ITALY
468 Vortecpro 585 HP back to street cruiser
M20 4 speed - 3.31
Prosystems 1000
BEST ET 11.62 (with 4.10)
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
1969 El Camino Street Strip
467 Vortecpro Tunnel ram 730+ hp TH400
BEST ET 10.67 @ 127 1.56 60FT
oliver69 is offline
post #408 of 456 (permalink) Old May 13th, 19, 10:58 AM
Nice job, great pic!
WHT/73 is online now
post #409 of 456 (permalink) Old May 13th, 19, 1:05 PM
Greg.
Damn Oliver that is Great winning 2nd on your first time out with the new car & Engine
Were you ahead of him at the End of the 1/4 ?
So that it was only the reason you lost was the Breakout ??
Love the way the Bias-Ply Tires Wrinkle on Launch
So does your Tach not have a Shift Light ???
so all you have to do is see it Flash/come ON then you Shift !!
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #410 of 456 (permalink) Old May 13th, 19, 1:25 PM
[QUOTE=1967 chevelle malibu;11077958]Thatís great for the first time out!
Awesome Job Oliver,
To completely build the car from scratch and go out and not only not have any gremlins but bring home some hardware shows real attention to detail and a little bit of luck LOL
mr 4 speed and Blown1932 like this.
66 chevelle
New Combo
555
10.2 comp
Straub ProMaxx heads
Straub solid roller
TH400/373
3815lbs
1.31 60'
[email protected]
[email protected]
B433 is offline
post #411 of 456 (permalink) Old May 13th, 19, 2:15 PM
nice job oliver. glad you got her running so good.
78 Malibu, 402, th350, holley sniper EFI, 9" 3:70, Hoosier 26X8.50-15 slicks.
69 VW baja 1600cc.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
Jebchevelle is offline
post #412 of 456 (permalink) Old May 13th, 19, 2:48 PM Thread Starter
OLIVER
Thank you Greg !!!
yes i was ahead of him , he had very consistent low 9sec car so i was expecting to pass me anytime , he dialed in a 9.4 and ran a 9.7 ... so my mistake for loosing the final first for adjusting the rev limiter , second for changing the dial in and third not breaking on the finish line
i have the shift light and tried on my runs but everything happened so fast in first gear i short shifted like below 5k .. having only a few runs i concentrated more on the launch and thats it for now
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #413 of 456 (permalink) Old May 13th, 19, 3:00 PM Thread Starter
OLIVER
[quote=B433;11078092]
Awesome Job Oliver,
Brian thanks !!! i never drove the car not even in the yard let alone the street... we went from the garage to the strip , only gremlin we had was the tunnel ram throttle linkage got a little loose and the idle went crazy so we had to tighten down that and the fuel pump an hose inlet ..
as far as the race the car was vey consistent in eliminations running from 10.72 to 10.75 always , the problem is the driver hahaha
we were very lucky to bring home a 2place and the cup
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #414 of 456 (permalink) Old May 13th, 19, 10:05 PM
Kerry
Good job Oliver! It shows that making a plan for a combo, following it, and attention to detail pays off.
Did you have anyone videoing the launch in slow mo to see what the suspension is doing?
If you are planning to run the trans in D, get a BM governor kit, you can lighten the weights to have the full throttle shift where you want.
pockets is offline
post #415 of 456 (permalink) Old May 14th, 19, 5:20 AM Thread Starter
OLIVER
Thank you
Next race in september i want to start shifting myself and also using the 2step rev limiter on the launch
any good tips on braket racing ?
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #416 of 456 (permalink) Old May 14th, 19, 8:29 AM
Oliver, what were your rear suspension and body mount choices?
Anything you would do different?
mrpaticular is online now
post #417 of 456 (permalink) Old May 14th, 19, 8:59 AM Thread Starter
OLIVER
Rear suspension is UMI lower and adjustable upper arms , with Viking Double Adjustable shocks , which i had on the Chevelle , the rear stays planted to mid track with the nose up , i tried to stiffen the compression a couple of clicks but i think it blew the tires , maybe i also left at a higher rpm, i did such a few runs i can't really tell what works and what does not yet. My best 60ft were in the 1.55 range so i diald back the compression and left at idle .. this was the most consistent.
we did swap body mounts from stock rubber to energy suspension
mrpaticular likes this.
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
post #418 of 456 (permalink) Old May 14th, 19, 9:20 AM
Kerry
Thank you <img src="https://www.chevelles.com/forums/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
any good tips on braket racing ? <img src="https://www.chevelles.com/forums/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
Have a routine starting in the staging lanes. Engine at the same temp in the lanes. Routine for turning the fan on and off, which for me once I finish my burn out and come up to stage I turn my fan off.
Do your burn out at the same rpm and for the same amount of time every time.
You wil get your 60’ down, but will need time to play with that. Tire air pressure, and shock settings. I haven’t worked with a rear suspension like yours, just leaf spring car, but Mark and others can help you with that.
oliver69 and Kirk's67SS like this.
pockets is offline
post #419 of 456 (permalink) Old May 14th, 19, 9:55 AM
Greg.
Thank you Greg !!!
I have done this many Times against the Faster Car Guys as they seem to forget
us Slower Runners are just Racing against ourselves / trying to run our Dialin Time
Lost one against a good Race Buddy who Runs in the the hi 10s by Breaking Out by .00012 of a Second
while he was a car Behind me and I should have let off to take the Win in the Semi Finals last year
And I have won a few by hitting the Brakes just before the Finish Line because I was going to Fast vs my Dialin Time
I usually Do Not change my Dialin Time once I start the Elimins unless something changes to the Track Prep
and Never change the Tach Shift Light RPM and I change Gears when it Lights up
this way the old girl gets use to it and of course it also becomes Automatic to me to
I am sure you will get use to the Auto very quickly and will be dropping those 60' Fts down to what you think they should be
Ciaooo
Born 283 / PG / A51
60' = 1.664
60' = 1.561
post #420 of 456 (permalink) Old May 14th, 19, 11:15 AM Thread Starter
OLIVER
Here is the timeslip of the final , i though i left it in the car but i had it with me
6.866 @102 mph 1/8
10.677 @127 mph 1/4
Inviato dal mio iPhone utilizzando Tapatalk
ShouldntBeHere and pockets like this.
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
oliver69 is offline
