1969 L78 aftermarket head choice? - Chevelle Tech
 2Likes
  • 1 Post By Busted Knuckles
  • 1 Post By blue_69_malibu
post #1 of 11 (permalink) Old May 21st, 17, 10:32 PM Thread Starter
Johnny
Hey All!
Need some help on this.
Just finished up the L78 short block for my 69 and the square port heads I had lined up turned out to be junk! (cracks)
Until I can find another set of stock square port heads I thought I would bolt on a pair of alloy aftermarket heads. Must be 119 cc or bigger to keep the compression numbers in check.
Any feedback on what works and what is not junk would be greatly appreciated!
Raised ports may mess with header placement and as this is a street /strip fun car with a Comp Cams 286H cam I need to make a good choice.
Thanks!
Johnny
1971 Chevelle SS
454 4 speed
Original Nevada Silver D88 black stripe car
(GM documented by George Zappora from vintage services)
1969 Chevelle SS
396 / 4 spd
L-78 / M-22
(GM documented)
67johnny is offline
post #2 of 11 (permalink) Old May 22nd, 17, 12:51 AM
Marcus
Re: 1969 L78 aftermarket head choice?
Only aftermarket heads without raised exhaust ports that I know of are some of edelbrocks heads, some of chevrolet performance and Brodix race rites.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #3 of 11 (permalink) Old May 22nd, 17, 2:31 AM
Brodix Race Rites, are a good choice, eddy heads can be good as well, The GM heads are just re badged eddy heads.
78 Malibu, 402, eddy heads, 174 B&M blower, th350, holley sniper EFI, 9" 3:70, 26X8.50-15 slicks.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
04 scion XB daily driver.
Jebchevelle is offline
post #4 of 11 (permalink) Old May 22nd, 17, 7:32 AM
The Edelbrock E-CNC 355 heads do reasonably well and are available with a 118cc chamber.
The exhaust ports have been raised but only 1/8" which I doubt would be noticed.
Big-Block Heads Shootout - The Big O Vs. The Big R - Super Chevy Magazine
Post pictures.. -or it never happened!
BlackoutSteve is offline
post #5 of 11 (permalink) Old May 22nd, 17, 7:39 AM
I'd think RaceRites would get you the best bang for your buck. You might forget about iron heads once you try 'em.
And I think that the E-355's are a lot too big for a 454, they belong on a 565.
blue_69_malibu likes this.
Gary Adrian
Busted Knuckles is offline
post #6 of 11 (permalink) Old May 22nd, 17, 7:46 AM
Is it worth the cost of purchasing aftermarket heads, then taking the loss if you sell them once you find the correct heads for your engine. Are you looking for date codes heads? Is what you are looking for that hard to find?
Steve R
Steve R is online now
post #7 of 11 (permalink) Old May 22nd, 17, 7:52 AM
Not sure about that. AFRs 300 rectovals out flow them, and those AFRs are right at home on my 454.
post #8 of 11 (permalink) Old May 22nd, 17, 11:56 AM Thread Starter
Johnny
Thanks for all the replies.
BlackoutSteve- great article on the rect-ovals from that super chevy article that you linked.
402 cubes would work well with an rect-oval design I would bet!
Maybe others can weigh in on this ?
Thanks!
Johnny
1971 Chevelle SS
454 4 speed
1969 Chevelle SS
396 / 4 spd
L-78 / M-22
(GM documented)
67johnny is offline
post #9 of 11 (permalink) Old May 22nd, 17, 1:32 PM
It's been said before when it comes to Cylinder Heads....."MAXIMUM FLOW THROUGH THE SMALLEST PORT SIZE POSSIBLE."
Given how well AFR 265s work on 454/468 and 496s, I can't imagine those 355 ports being anything but lazy on a street 396/402.
Simply my opinion......
badrad likes this.
blue_69_malibu is offline
post #10 of 11 (permalink) Old May 22nd, 17, 6:00 PM
You could be quite right. I wouldn't be suggesting any rectangle port at all for that engine anyway. I only did because it was asked for.
AFR 265 or 290 rectovals any day.
post #11 of 11 (permalink) Old May 22nd, 17, 6:49 PM
the afr 265 290 or the oval 300's are all good heads. The brodix RR-0 270's are good heads too for a 396/402 you want the best small port you can get. Yes I have a set of brodix and I can say some very pretty heads lol also I went with them because of price at the time also I had planed on going with a roots style super charger so I wanted good flow and port size. I ended up keeping the engine N/A so with that in mind I picked up another set of heads with a smaller chamber to keep the current n/a compression ratio on my 402. Hence why I am selling my Brodix heads. if you have any question about any of these heads, personally I would contact Mike Lewis AKA Wolfplace here on this site. below is his contact information.
Lewis Racing Engines
03 yz85 fun bike.
This Thread is more than 1054 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
