GM HEI discovery-Whaaaat? - Chevelle Tech
 9Likes
  • 1 Post By Tommy the Cat
  • 1 Post By JKK
  • 1 Post By Schwany
  • 1 Post By engineguy
  • 2 Post By gnicholson
  • 1 Post By Hotwire
  • 1 Post By Schwany
  • 1 Post By mr 4 speed
post #1 of 14 (permalink) Old Feb 7th, 17, 10:10 PM Thread Starter
David
While nosing around under the hood of my recently acquired '69 SS w/ "454" today, I found another PO surprise. When I removed the dizzy cap and rotor to see what's what, I saw the PO had removed the mechanical advance weight springs and wired together the spring posts with some steel wire. So instead of springs to control the weights, they're now totally prevented from moving outward at any RPM(!) Why would anyone do this? (I'm using the dizzy's vacuum adv. can for idle quality btw) I don't know much about these HEIs, so any help is appreciated!
Brownd3max is offline
post #2 of 14 (permalink) Old Feb 8th, 17, 12:24 AM
Re: GM HEI discovery-Whaaaat?
It's a cheesey but easily reversed way to lock out the timing. It was probably set at around 36 degrees.
Brownd3max likes this.
70 Camino...Roller
Tommy the Cat is offline
post #3 of 14 (permalink) Old Feb 8th, 17, 9:46 AM
JKK
JK
2xx
67 El Camino ZZ 383 > FI-Tech F.I. / 700R4 /12 Bolt Posi 3.73s / P/S P/B A/C
" Rancheros the Other Short Bus"
JKK is offline
post #4 of 14 (permalink) Old Feb 8th, 17, 11:33 AM Thread Starter
David
OK guys, thanks for the info. I don't really understand the benefit of "locking out" the dizzy advance weights for normal street driving. Assuming that I should go back to springs, where can I source these? And how do I pick the right ones? Stock?
post #5 of 14 (permalink) Old Feb 8th, 17, 11:37 AM
You can get "timing curve" spring kits from Summit, Jegs and so on and so forth. One of the spring pairs in the kit will be stock, or close enough to it.
'65 Chev El Camino
350/400+HP, 700R4
Edelbrock Pro-Flo 4 MPFI
'68 P-11 Norton
Schwany is offline
post #6 of 14 (permalink) Old Feb 8th, 17, 11:54 AM
Bill R
You are correct, the vacuum advance should be functioning for street use. Replace the springs.
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (25+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
engineguy is offline
post #7 of 14 (permalink) Old Feb 8th, 17, 11:00 PM
You need to do that with a long duration cam with low idle vacuum.. Lock the distributor, make a mark on the balancer at 30 BTDC and use that mark to time the motor..
On points distributors, we used to just remove the springs and let the weights move out once the motor would start, the points spring would push them back when the motor was shut off and act as a start retard... It worked well..
hydro462 is offline
post #8 of 14 (permalink) Old Feb 9th, 17, 12:57 AM
\ dizzy cap, I'm using the dizzy's vacuum adv.
Are you trying to say DISTRIBUTOR?
dell72 is offline
post #9 of 14 (permalink) Old Feb 9th, 17, 2:19 AM Thread Starter
David
Yes, I am. The term "dizzy" is just a quick lazy way to spell "distributor". Another forum I've been a member of, (IH8MUD), uses that term frequently. You see, we off-roaders like short words. LOL!
post #10 of 14 (permalink) Old Feb 9th, 17, 8:27 AM
Gary
how bout just use the abbreviation? in this case dist. ive seen people lock the advance when the weights and shaft pins wear out.
langss and lucifershammer like this.
gnicholson is online now
post #11 of 14 (permalink) Old Feb 9th, 17, 8:32 AM
Is there any type of adjustable ignition on the car? He could have the spark curve programmed into it instead of relying on centrifugal advance from the springs.
hydro462 likes this.
Hotwire is offline
post #12 of 14 (permalink) Old Feb 9th, 17, 11:05 AM Thread Starter
David
Hotwire & Gary- there's no added module/ box anywhere that i've found. And I've ordered a spring/weight/bushing kit to renew all that. I'm looking to go back to a "semi-standard" setup, with full manifold vac. advance for idle,(it was found plugged by PO), mech. advance using "stock" springs, and need to find a good static adv. setting starting point. How's 12* sound? More? Please advise!
post #13 of 14 (permalink) Old Feb 9th, 17, 11:37 AM
That'll work. You may have to turn the idle screw way up though if that thing was locked out a 36*
'65 Chev El Camino
350/400+HP, 700R4
'68 P-11 Norton
Schwany is offline
post #14 of 14 (permalink) Old Feb 10th, 17, 2:49 PM
Find out how much timing you are getting from the weights/springs before you settle on 12* starting point.
If you have 20* of mechanical advance,12* at idle/initial will not be enough.
Example: my car has 10* of mechanical advance and 25* initial for 35* total.
mr 4 speed is offline
This Thread is more than 978 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
