Ran A New Best Last Night.... - Page 2 - Chevelle Tech
 5Likes
post #16 of 28 (permalink) Old Jan 29th, 17, 3:56 PM
Jon
Re: Ran A New Best Last Night....
The youtube one says it is a private video Steve.
72BBMonte is offline
post #17 of 28 (permalink) Old Jan 29th, 17, 4:02 PM Thread Starter
Ok, Thanks Jon..I`ll see if I can fix that.
68 BISCAYNE 4060lb
468-9.4:1
1.76 60FT Drag Radials
11.69 [email protected] 116.30 MPH
BigRed-L72 is offline
post #18 of 28 (permalink) Old Jan 29th, 17, 4:12 PM Thread Starter
Hey guys does the video work now ??
68 BISCAYNE 4060lb
468-9.4:1
post #19 of 28 (permalink) Old Jan 29th, 17, 4:25 PM
Jon
Works good now!
post #20 of 28 (permalink) Old Jan 29th, 17, 4:30 PM
Nice run!! Good looking car too.
Bowtie for Life is offline
post #21 of 28 (permalink) Old Jan 29th, 17, 4:45 PM
Jarad
It leaves really nice! Looks like the 275 Pro's are working.
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
post #22 of 28 (permalink) Old Jan 29th, 17, 5:37 PM Thread Starter
Works good now!
Thanks..has a few scars and is time to freshen it up. Jesse has been holding off till the racing is done with.
Thanks...the car leaves just above idle @ 1100 RPM and then pulls that MASSIVE 4" wheelie
The 275`s actually work better for us than the radial slicks we use to run.
Plus, it`s SO much easier to drive on down with the tires you run on vs having to change over to slicks and then doing it all over again for the drive back home after a long night of racing
68 BISCAYNE 4060lb
468-9.4:1
post #23 of 28 (permalink) Old Jan 29th, 17, 7:05 PM
JIM
NICE!!!
That dude is scootin' drama free!
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
Best ET
Best MPH
200 MPH at TX Mile
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
post #24 of 28 (permalink) Old Jan 29th, 17, 9:24 PM
Very nice
67 Chevelle SS Marina Blue
66 Malibu (soon to be SS 375HP clone)
67SS Royal Plum original paint
supersport6667 is offline
post #25 of 28 (permalink) Old Jan 29th, 17, 10:16 PM
Nice. How about a current combo refresh.
71 Camaro pump gas 515 afr 300
1.24 5.95 114.3 3500#
scutumcrux is offline
post #26 of 28 (permalink) Old Jan 30th, 17, 9:17 AM Thread Starter
Originally Posted by 540Hotrod View Post
NICE!!!
JIM
Thanks Jim..it is relatively docile all things considered
Originally Posted by supersport6667 View Post
Very nice
Thanks !
Tubular A-arms to help with geometry and all that stuff..not really a weight savings thing at all.
Jesse did a rear disc conversion primarily for axle retention, and of course better braking.
Motor still has all the wrong parts in it no changes there except for a fresh set of plugs. Same goes for the rest of the car.
Thanks !
68 BISCAYNE 4060lb
468-9.4:1
post #27 of 28 (permalink) Old Feb 1st, 17, 10:30 AM
Davey
nice job to both of you.....using the computer is great plus it holds so much info on each run....we also add notes about the run for future use or if someone like your converter guy wants to see what it's doing...I love it...don't understand it all yet but I couldn't launch without it.....
Chevelle
SloMo...
'67 Chevelle 516 hyd roller
4.11's
9.06 best mph 147.75
5.73 best mph 119.98
3520 lbs to 3570 depending on fuel
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
crazydavey is offline
post #28 of 28 (permalink) Old Feb 2nd, 17, 6:56 PM
Thanks davey,
Not sure my box can data log would be nice if it could.
I was hoping for a 9.3X
we had higher mph last time out in much worse air .Were thinking that we should have went up a jet are 2.
I starting setting up the vacuum pump tonight,that will be an interesting test.
Hopefully we will have some results to post in the next couple weeks.
There is not much left in the combo other then changing out the mild 10inch converter
I can not get a better 60 then a 1.34 It needs more converter.
crazydavey and JBoggs like this.
78 Camaro,3495,Driven to the track.
UD Harold hydraulic roller
REC90/112
1.27
5.87 @116.76
9.24 @141.64
vp 109
1.35
[email protected]
[email protected]
Jesse 496 is offline
This Thread is more than 1217 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
