467 Edelbrock Head Build - Chevelle Tech
 12Likes
post #1 of 27 (permalink) Old Dec 23rd, 16, 10:45 PM Thread Starter
MARK
Recently I built a 467 with Edelbrock heads, I know some of you like these builds with dyno tests.
4.310 X 4.00 467 CU IN, I used a Icon piston with 1/16/1/16/3/16 ring pack, compression was 10.7. A hyd roller was used, 240 @ .050/.610/110/106, with a Morel lifter, Rollmaster timing chain, Straub supplied, Edelbrock 6045 RPM heads were used 100 CC chambers, although the chambers ended up at 114 CC after work, Pac 1.550 dual spring was used with 175/420 pressures, with Scorpion rocker arms. Performer RPM air gap intake with a 1000 CFM AED carb, 1 inch open spacer. I used a Moroso oil pan with a M 77 oil pump, 6 quarts of 10/30 Penzoil, Wix 51061 filter. Total timing was around 38 degrees, 91 octane Shell gas was used.
https://youtu.be/NtHXUaCtJw0
ID:	409537   Click image for larger version
Machined GM production heads
Oil pan modifications
Red Line Camshaft
VORTECPRO is offline
post #2 of 27 (permalink) Old Dec 23rd, 16, 11:06 PM
JIM
Re: 467 Edelbrock Head Build
That's a stout mo-fo!! There was a time when it took a 496 to make 650 HP!!
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
Best ET
Best MPH
200 MPH at TX Mile
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
post #3 of 27 (permalink) Old Dec 23rd, 16, 11:18 PM
That's a stunning combination. Thanks for sharing. What's the story behind using the Edelbrock heads?
The biggest problem facing America today is that lies are so widely accepted as truths.
Alan F is offline
post #4 of 27 (permalink) Old Dec 23rd, 16, 11:32 PM Thread Starter
MARK
Thanks. The person I built the engine for supplied the heads.
Red Line Camshaft
post #5 of 27 (permalink) Old Dec 24th, 16, 5:51 AM
jimmyradford
Awesome! That's a lot of power.
TC Member # 4431
'67 Chevrolet Biscayne- SS427 L-36/TH400 (Hers)
'67 Hell Camino-BB 427/TH400 (His)
'66 300 Deluxe 2 door-230/PG
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people and they're generally more useful.
badrad is offline
post #6 of 27 (permalink) Old Dec 24th, 16, 10:08 AM
Jon
Broad powerband with an impressive peak. 1.39 hp/ci
72BBMonte is offline
post #7 of 27 (permalink) Old Dec 24th, 16, 10:17 AM
Jarad
I see them needing tires in the future. 650hp on what looks like a pretty mild 467 is awesome.
Sent from my LGMS428 using Tapatalk
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
post #8 of 27 (permalink) Old Dec 24th, 16, 12:38 PM
Simply amazing, Mark.....yet again!! No matter how many of these builds you post, I never get tired of them.
Should you feel so inclined, you could even go two sizes down on the cam to improve idle/vacuum....and still make killer power.
Wow.......and Merry Christmas everyone!!
blue_69_malibu is offline
post #9 of 27 (permalink) Old Dec 24th, 16, 3:28 PM
Nice combination Mark
CDN SS is offline
post #10 of 27 (permalink) Old Dec 24th, 16, 3:53 PM
Thanks for the reply. How cost effective were using those heads versus the cost of you prepping a set of 049/781s? Any other advantage to using one route or the other?
Alan F is offline
post #11 of 27 (permalink) Old Dec 24th, 16, 5:22 PM Thread Starter
MARK
I would have been better off with GM heads, but the Edelbrock heads will make it very pump gas friendly. The amount off work that went into the heads was ridiculous for the power out put.
Red Line Camshaft
post #12 of 27 (permalink) Old Dec 24th, 16, 5:37 PM
I'll be calling you after the Holiday.....
70CHEVELLE396 is offline
post #13 of 27 (permalink) Old Dec 24th, 16, 8:19 PM
Gary
what gm heads would you have used? dont the old 049s need a ton of work to make that much power? if you could pick the absolute best heads for the application cost no issue what would it be?
gnicholson is offline
post #14 of 27 (permalink) Old Dec 24th, 16, 8:37 PM Thread Starter
MARK
Those Edelbrock heads were worked hard, consider the chambers went from 100 cc to 114 cc alone. The iron heads require a lot of work as well, but would have no problem making that kind of HP. Best head hmm, symetrical port 12 degree, second best, worked AFR 265, the cam was the cork, but this was a street driver, I'm sure theres 660 HP there with more tuning, infact with exotic oil and gas it surely would go over 680, but still it should run 10.00 @ 3500 pounds.
Red Line Camshaft
post #15 of 27 (permalink) Old Dec 24th, 16, 9:37 PM
Great job as usual Mark,
Makes me wonder how those heads compare to the GM/Eddy ZZ502 heads as mine also ended up at about 113/114cc chambers also. I am running same bore with shorter stroke,same intake.carb etc yours makes way more power.Great job again 👍
B433 is offline
This Thread is more than 1294 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
