Crank and Rod choice - Page 3 - Chevelle Tech
 50Likes
post #31 of 43 (permalink) Old Jul 1st, 17, 2:11 PM
Smile Re: Crank and Rod choice
My final BBC build will be 4.600 block, 3.76 crank with 10:1 comp. pistons.
Just a lil' ol "bored-out" 427, eh?
supersport6667 likes this.
Rex Auftinn is offline
post #32 of 43 (permalink) Old Jul 1st, 17, 8:26 PM
It seems a waste to have a block capable of big cubes and not take advantage of it.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #33 of 43 (permalink) Old Jul 1st, 17, 10:32 PM
Lightbulb Re: Crank and Rod choice
"Different strokes for different folks", eh?
Beyond a certain point on the street, what does *more* hp and/or tq matter?
Could some say what you can't/won't be capable of using is wasteful? Like a 10-bed/bath home?
I'm not building it to compete in the TDRL... The "Dyno-Results" League.
Even a "mere" 500-cube BBC will do all that can be done on street tires.
post #34 of 43 (permalink) Old Jul 1st, 17, 11:00 PM
^^^^^^ I'm certainly not opposed to 500 inches. The right pair of heads and the right induction and it could work out quite well.
Rex Auftinn likes this.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is online now
post #35 of 43 (permalink) Old Jul 2nd, 17, 7:00 AM
^ and the shorter stroke engine will recover from the shift faster and have less issues with windage.
Mine is 3.766" x 4.630". Scat started making a 4340 crank with 3.766" stroke, full counterweighted including center throws. Mine is ready for balancing, just gotta decide on rods. Pistons will be custom, but that comes with the territory.
There's no use making a long stroke tow truck engine with unusable torque in a lot of rides...unless bragging rights is part of the equation. The Oklahoma Boys - even with drag race optimized cars - all have about twice the power that they can get to the ground, even on an often-raced concrete street with more rubber on the starting line than many tracks I've been to.
Gary Adrian
Busted Knuckles is offline
post #36 of 43 (permalink) Old Jul 2nd, 17, 1:31 PM
I like tow truck engines too.
'66 SS Chevelle
91 octane special
first day out
[email protected]
post #37 of 43 (permalink) Old Jul 3rd, 17, 7:31 AM
jackie
USA Race Engines, (The Wop Shop in Houston), built my 540 with a Scat 4340 crank and Calles Rods. He used Calles based on his own experience. He builds a lot of 9.90 index cars, and those guys put a lot of runs on engines with the expectation of long life.
The choice of heads and cam is extremely important when building a real street engine. That being, and engine that runs what's in the pump at the corner station, runs at the correct temperature, and makes that 600+ HP and Torque at a reasonable RPM.
Too much cam and too large of ports in relation to their true flow capabilities can be a big pain. That is why choosing a head with proven flow numbers is so important. Just because an ad says "380 CFM Ports" doesn't mean the ports will actually flow that. I have always liked AFR, but one of the great things about today's Hot Rodding is we do have so many choices.
For a real street engine, not scrimping on the little things can make a big difference. Pass on the cheap Chinese Rocker Arms. The same can be said for the Lifters. Going with the best here can insure hassle free street service.
A 650 HP big inch Big Block is, in today's street car world, is not a radical engine. If built correctly, it will make that or more torque down low in the RPM range. It will idle smooth at 800, and cruise at 2000 RPM at 70 mph on the freeway. And when you decide to put the hammer down, will get your attention.
70CHEVELLE396 likes this.
jackie schmidt is offline
post #38 of 43 (permalink) Old Jul 31st, 17, 9:55 PM Thread Starter
You mention the Callies rods. Do you know if they were the Compstar line or the twice as expensive Ultra line? I'm just curious, and was thinking more about lately. If I did want to spend more money than I probably need on a set of rods or a crankshaft, what would be the better choice to throw the money at, the crank or rods?
70CHEVELLE396 is offline
post #39 of 43 (permalink) Old Aug 1st, 17, 3:15 AM
I went with the Dragon Slayer, and Ultras from Mike on mine.....
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #40 of 43 (permalink) Old Aug 1st, 17, 5:46 AM
The Dragon Slayer cranks have been discontinued for quite some time.
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is offline
post #41 of 43 (permalink) Old Aug 1st, 17, 5:51 AM
I have used a lot of the Callies Compstar cranks and rods in BBC's for street and strip engines and some marine builds with zero problems.
Jack Sparks who worked for Carillo for years designing rods is the guy who has designed the rods for Callies.
Machine shop tour
Monthly Specials
post #42 of 43 (permalink) Old Aug 1st, 17, 5:03 PM Thread Starter
Thanks. I PM'd you awhile back, but never got a response.
post #43 of 43 (permalink) Old Aug 1st, 17, 9:47 PM
I just looked at your PM back on 12/12/2016 I guess I missed that for some reason. I sent you back a PM if interested let me know.
Carl
Machine shop tour
Monthly Specials
This Thread is more than 970 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
