How do you block the oil filter bypass? - Page 6 - Chevelle Tech
 53Likes
post #76 of 92 (permalink) Old Aug 17th, 16, 9:57 AM
Scott Foxwell
Re: How do you block the oil filter bypass?
Freinds don't let friends run Fram filters.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
post #77 of 92 (permalink) Old Aug 17th, 16, 9:57 AM
Whaaaaaaaat. AC Delco filters are fram? Please someone tell me different. I have a Ac Delco on my brand new 496. If its junk its coming off. I hope not.
64 Chevelle 496
StevenS is offline
post #78 of 92 (permalink) Old Aug 17th, 16, 11:45 AM
AC Delco filters use to be a good filter years ago but have been cheapened up and the quality is gone.
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is online now
post #79 of 92 (permalink) Old Aug 18th, 16, 2:42 AM
Well, I'm just going to politely say I won't run one in any engine I have. Some other filters I won't run are SuperTech and Fram.
thrasher is offline
post #80 of 92 (permalink) Old Aug 18th, 16, 3:13 AM
ACDelco of today is not the AC-Delco of yesteryear (note the missing hyphen). It was pretty much sold off after the bankruptcy and many parts are low bid Asian imports, like oil filters.
This doesn't mean all ACDelco parts are bad. ACDelco "professional" is assembly line OEM grade. If you need an AC condenser, ACDelco units will have the correct number of tubes, the aftermarket is usually less tubes which means less cooling efficiency.
Pass on their oil filters. Reach for a known good brand name. Hastings, Wix, Mobil1, K&N... If you have piston rings from ANYBODY, chances are good Hastings made them.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
post #81 of 92 (permalink) Old Aug 18th, 16, 11:03 PM
Also, pass on any/all ACDelco ignition parts - all chinese made and to incorrect tolerances across the board!
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #82 of 92 (permalink) Old Aug 20th, 16, 5:56 AM
Jack
Only thing else I want to add is that once you do this it is imperative that you use a good quality racing type filter, especially if you are ever going to run the engine when cold. Also you need to warm the engine up so the oil temperature gets normalized before you start "leaning" on it.
Yup I couldn't agree more... Blocking the bypass and running a cheap filter on a circle track engine is asking for trouble. Guys are always having to jump on the track with a cold engine. It's going to happen.... Either don't block it or run a racing filter. You could make a case for it both ways. I've ran it both ways and don't have engine failures.
Importtech is offline
post #83 of 92 (permalink) Old Aug 20th, 16, 6:53 PM
Never had to run a Racing filter to date on my circle track engines, And there are a lot of engines that never get any oil temp and no problems more so the cars that have to be push started with 3 or 4 laps they are racing.
Wolfplace and StevenS like this.
Machine shop tour
Monthly Specials
post #84 of 92 (permalink) Old Aug 20th, 16, 8:40 PM
Never thought a 1/4 inch pipe plug would get to 6 pages.
paul bell and porky70 like this.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #85 of 92 (permalink) Old Aug 21st, 16, 1:40 AM
Jack
I see what you did there..You mean specifically a Racing filter like 51060R which is what I generally run. I was thinking more along the lines of not running a cheap filter. I can't say a 51060 wouldn't work because I've never tried it but I know a fram won't. I get nervous when i don't see oil pressure. I know the "R" filter is a little more free flowing.
post #86 of 92 (permalink) Old Aug 21st, 16, 2:42 AM
Wix filters are good, I personally will not run a Racing Wix when I can get the flow with better filtration from another brand. This is just my opinion. There was a discussion earlier about it.
https://www.chevelles.com/forums/13-p...l-filters.html
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #87 of 92 (permalink) Old Aug 21st, 16, 12:05 PM
George
After reading all this, still have no idea what is the correct oil filter to run. ZZ4 roller block 383, melling hv standard pressure pump, 8 quart oil pan. Builder recommended the blocked bypass and an HP4 filter. Sounds like it's not liked here. I've always run Napa filters and never had anything bypassed before.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #88 of 92 (permalink) Old Aug 21st, 16, 1:59 PM
Not following what you mean by "never had anything bypassed before"??
In stock form you had a bypass in the filter mount & this is what we usually plug so all oil goes through the filter 100% of the time
I would for sure not do this with a Fram filter but I do not use Fram so for me this is moot
For a filter I would stick with your NAPA Gold, it is a Wix
IE
1061 NAPA = 51061 Wix
Importtech and paul bell like this.
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #89 of 92 (permalink) Old Aug 21st, 16, 3:39 PM
There has been some changes, I don't think Wix is making for NAPA anymore. Just to be sure, you should be looking for the actual Wix version.
Step up to the XP version (51960XP), it has that better synthetic media backed by a wire mesh.
Part Details
Wix 51060XP Case of 6
How may I help you?
1999 Trans Am-500hp
post #90 of 92 (permalink) Old Aug 21st, 16, 4:13 PM
The only difference between the 51060 & 61 is the 60 has the "anti drain back valve which is totally unnecessary in any Chevrolet V8 application with the filter upright as oil rarely drains uphill
As far as the XP series, I agree, it is an excellent filter but I have had zero issues with the cellulose line so I see no reason to change considering the first two I use get tossed usually on the first or second day
Interesting on the Napa filters,,, I have cut open a couple of customer supplied Napa 1061's within the last month or two & they certainly look to be the Wix but for me this is a non issue as all I normally use is genuine Wix
More info for those that care
Wix Filters - Product Catalog search results
WIX Filters - Racing Catalog
Mike (Wolfplace)
VISIT US AT
----John Wayne----
This Thread is more than 1252 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
