new best with turbo ls nova. - Page 2 - Chevelle Tech
 3Likes
post #16 of 29 (permalink) Old Jun 7th, 16, 5:14 PM
Re: new best with turbo ls nova.
any more progress?
78 Malibu, 402, eddy heads, 174 B&M blower, th350, holley sniper EFI, 9" 3:70, 26X8.50-15 slicks.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
04 scion XB daily driver.
Jebchevelle is offline
post #17 of 29 (permalink) Old Jun 8th, 16, 7:39 AM Thread Starter
mike
here is an old pic. the car has been running turbo ls for 3 years now. and I have changed a few things.
yenkomike is offline
post #18 of 29 (permalink) Old Jun 8th, 16, 7:47 AM Thread Starter
mike
and here is the car.
the only draw back to the e85 is the fuel system but efi pumps are fairly cheap for e85. I run a single aem 380 and it works great for $135.00.
post #19 of 29 (permalink) Old Jun 8th, 16, 8:09 AM
very nice mike.
03 yz85 fun bike.
post #20 of 29 (permalink) Old Jun 8th, 16, 11:04 AM
Ron
Love it! What electric fan set up do run?? How is cooling it/underhood temps??
69 Camaro
491/AFR 315/Straub hyd roller/pump 91
TH400/GV OD/9" 3.50's/ 255/60/15 DR
10.86 at 124.8
3670 with driver
dirtlips408 is offline
post #21 of 29 (permalink) Old Jun 8th, 16, 11:29 AM Thread Starter
mike
I have a single 15" black magic fan and sence that pic I swapped to a aluminum radiator. unless I sit in traffic it never even needs the fan on. with the smooth idle cam at 700 rpm the tight 3000 stall and 3.23 gears it really drives like a stock 307 powerglide nova. im only 2400 rpm at 60 mph or so. with the e85 I still run the 190 t-state to keep any moisture out of the oil and that is where it seems to stay.
the drivability of it is so much better than my old 406 solid lifter ,4000 stall,3.73 combo its hard to believe it runs more than a second faster.
post #22 of 29 (permalink) Old Jun 8th, 16, 2:13 PM
Did you ever run the LS N/A ?
WHT/73 is offline
post #23 of 29 (permalink) Old Jun 8th, 16, 2:38 PM
Big Al
Originally Posted by 69-CHVL View Post
I'd like to try e85 as there is a station down the road from me that carries it. But, you need about 30% more fuel volume using it compared to straight gasoline and I have a small tank to begin with. You also need more fuel system to handle the extra volume. But there's no denying the benefits of it.
Supposedly you only need up to e50 to get 90% of the benefits e85 provides so that is nice in the sense you don't need as much fuel system and probably better mileage. Gotta tune for it though! Tuning window is large with this e85 which I really like.
Do it. E85 is expanding (at least in my area) and you are correct about the 50% blend to get most of the benefit. It's rare to see it that low around here but it exists (Speedway is the lowest). There are plenty of carb builders that can get you a close baseline on E85. A lot of blow through guys are using it. Another bonus is it smells way better than the typical pump gas.
1968 Impala Turbo 6.0 798 RWHP
72' 5 speed LY6 Malibu-Sold
SleeperBBC is offline
post #24 of 29 (permalink) Old Jun 8th, 16, 3:16 PM
Vince
Fortunately I'm running EFI and all I need to do is by a ethanol sensor and the efi should adjust accordingly. Just a little more reading up to do. Probably could just fill up with e85 for race day and run regular fuel the rest of the time!!!
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is online now
post #25 of 29 (permalink) Old Jun 8th, 16, 3:23 PM Thread Starter
mike
you can set up two tunes and switch that way. but I just changed my required fuel from 14.7 to 9.8 in my tunerstudio and pour in the e85.it is the closest gas station to me so I will just run it all the time. so far I have been happy with the change over.
post #26 of 29 (permalink) Old Jun 8th, 16, 3:53 PM
Congratulations Mike on the great runs, your car is a true sleeper. It would be fun to get it to a better track someday and see just how fast it really could be.
How much better did the Pro`s drive on the big end ?
Congrats again,
66 chevelle
New Combo
555
10.2 comp
Straub ProMaxx heads
Straub solid roller
TH400/373
3815lbs
1.31 60'
[email protected]
[email protected]
B433 is offline
post #27 of 29 (permalink) Old Jun 8th, 16, 4:46 PM Thread Starter
mike
thanks.
the pro's are nice and stable on the big end but im still working on the launch. where my old bias were like a controlled spin at launch the pro's are ether dead hooked or spinning. but I was a bit surprised at how well they worked with my suspension. I did a shock change and a slapper bar adjustment and I think it will get a 10.0 or very high 9 if I can get a good launch.
the pro's feel better as far as rolling resistance enuff that you can feel it .
you get everything working good on the chevelle? haven't heard from you guys in a while.
post #28 of 29 (permalink) Old Jun 8th, 16, 5:37 PM
Ron
Man that is really cool. Been tempted for years to do it. MY drivetrain is already built for it....TH400/GV OD...tight 10" converter....3.50 gear. Main thing is time and the car being down. Plus I really like the looks of the BBC under the hood. Its a tough choice no doubt.
69 Camaro
10.86 at 124.8
3670 with driver
post #29 of 29 (permalink) Old Jun 8th, 16, 7:56 PM
That looks awesome!
That's huge!
Don't get your hands anywhere near it!
I have Turbo envy!
WHT/73 is offline
This Thread is more than 1357 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
