Intake Swap - Chevelle Tech
 7Likes
post #1 of 41 (permalink) Old Apr 24th, 16, 10:58 PM Thread Starter
Mac
Intake Swap
replacing the stealth with the old holley strip dominator, ran 7.12-7.20 two weeks ago, last weekend rain out is re scheduled for this weekend, both days, gonna see what happens
ID:	353185   Click image for larger version
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #2 of 41 (permalink) Old Apr 25th, 16, 2:01 AM
Re: Intake Swap
Keep us posted!
How does it "feel" to you?
Can you keep the spacer?
When the Hurricane was on the 355 in my Nova it had the same 60' as the AG, but the AG was almost 2 mph slower and almost a 10th slower in the 1/4.
Both combo's gained et and slowed down without the 1" open spacer.
WHT/73 is offline
post #3 of 41 (permalink) Old Apr 25th, 16, 8:05 AM
Re: Intake Swap
Curious to see how it does.
I have a Weiand Team G that "may" replace my Stealth soon.
When I yanked the transmission out last weekend, I saw a decent oil leak at rear of intake manifold, so if it has to come off anyway.......
2000 Pontiac Trans Am WS6
6.0, 4L80e, 3.73's = [email protected], 1.49
rel3rd is offline
post #4 of 41 (permalink) Old Apr 27th, 16, 11:54 AM
Gerry
Re: Intake Swap
I think your really gonna like the Team G. it's a great manifold.
67 SS BBC
4.11's
bradley67 is offline
post #5 of 41 (permalink) Old Apr 27th, 16, 12:05 PM Thread Starter
Mac
Re: Intake Swap
Originally Posted by WHT/73 View Post
Keep us posted!
Chris, don't know how it feels, late when we got finished, loaded it in trailer because of foul weather coming in, starts ALOT easier and sounds a little snappier , I had it on there befor it dropped a vlave couple years ago and put the stealth on after rebuild , just to see, but rebuilt engine with more compression this time so no REAL comparison there, next race will tell.
Did not install the spacer on the holley intake, didn't even give it a thought, but I don't think it will alow enough hood clearance, just have to measure, its close, when I look in there and close the hood the round cowl induction piece on the bottom of the hood is just above the bottom of my filter base, then hood goes down about one more inch and latches !
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #6 of 41 (permalink) Old Apr 27th, 16, 12:15 PM Thread Starter
Mac
Re: Intake Swap
Whatchyawaitinfor, that team g will look "cooler" in there anyway
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #7 of 41 (permalink) Old Apr 27th, 16, 12:29 PM
Thumbs up Re: Intake Swap
Yessir. Plus give me a place to stuff all the EFI wiring into.
rel3rd is offline
post #8 of 41 (permalink) Old Apr 27th, 16, 4:39 PM
Darren
Re: Intake Swap
Mac,
A couple of years ago I swapped a fully ported (by Bryce Mulvey of Dr J's Performance) RPM AirGap for a mildly ported (plenium work and gasket matched) Victor Jr. On top of the dual plane was a 1 inch open spacer along with a 1/2 nitrous plate. The Vic Jr has a 1 inch tapered spacer with the N2O plate.
No track times between the two or any dyno testing before and after. I just want to say, this is all seat-of-the pants results, but the low rpms are JUST as responsive than the dual plane and above about 5500 or so there is no comparison. This thing just keeps pulling. It was bouncing off the 7k rev limiter before I knew what was happening. Replaced the chip to abit higher one and this thing pulls hard to 7200. I'm just strictly going by seat-of-the pants results here.
rel3rd likes this.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems Venom VX 1050
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Moser axles
30x12.5 ET Street Radial
525++ rwhp
71454Chevelle is offline
post #9 of 41 (permalink) Old Apr 27th, 16, 10:49 PM Thread Starter
Mac
Re: Intake Swap
Darren I had the holley on there before the rebuild, was at 10.2-1 compression, it ran pretty good and like yours would keep pulling past 7200, but, cant keep the belts on it past 7 so that is where I have my limiter set, and I try to shift just before it hits the limiter, I have a stock ss dash and no shift lite and hit the limiter on occasion, after rebuild it now has 11.5-1 compression, it pulls very well it just take a little bit to get moving, a higher stall converter, probably 4500-5000 and it would leave a lot better, but then it would be a pain on the street, and we drive this thing !!
Oh yeah, and just blippin the throttle it seems to rev quicker, almost instantly, if you will.
71454Chevelle likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #10 of 41 (permalink) Old Apr 27th, 16, 11:11 PM
Re: Intake Swap
Don't be afraid of a 5k converter.
Just get a GOOD one! i have a 8" ATI treemaster and it drives totally normal till you mash it!
This is with the correct rear gears of course.
3.08's and 28"+ tires and a 5k converter"s not going to work.
WHT/73 is offline
post #11 of 41 (permalink) Old Apr 28th, 16, 7:00 AM
Re: Intake Swap
It worked off and on for two years for me...lol.
I think Mac has 4.10's though anyway.
69-CHVL likes this.
rel3rd is offline
post #12 of 41 (permalink) Old Apr 28th, 16, 9:01 AM
Re: Intake Swap
The strip dominators I have used like the 1" open spacer on them. One strip dominator intake I had years ago had the runner dividers extended to under the carb.
Ray
bracketchev1221 is offline
post #13 of 41 (permalink) Old Apr 28th, 16, 4:35 PM Thread Starter
Mac
Re: Intake Swap
[QUOTE=WHT/73;8819921]Don't be afraid of a 5k converter.
3.08's and 28"+ tires and a 5k converter"s not going to work.[/Q UOTE]
What kind of heat is that thing gonna make on say a 500 mile road trip, the coan I have in it now drives around like grandma's station wagon, mash it and get 1500 or so more rpm, runs very cool, but I also have the cooler in the radiator then a 6 pass then a bigger 6 pass, all that is still in there from when I had the 700r4.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #14 of 41 (permalink) Old Apr 28th, 16, 5:31 PM
Re: Intake Swap
[quote=bigmachd;8821897]
I never took my car a 500 mile trip...but I do beat on it all the time and it has been in there for almost 4 years now and drives like the day I put it in there.
I only have a summit alum rad with NO cooler.
I use 2 cheap Hayden stacked coolers in series in front of my radiator.
My buddy almost has me talked into a 4l80e....but I'm really at attached to passing people like there standing still with no kickdown hooked up.
That and I'm not sure if a converter is available with that stall yet.
I've got to cat ATI and see.
WHT/73 is offline
post #15 of 41 (permalink) Old May 7th, 16, 8:46 AM Thread Starter
Mac
Re: Intake Swap
Well we got rained out again, BUT, today is another story, looks to be in the hi 70 to low 80's today and a little windy, time trials start at 14:00, gotta get stuff hooked up and loaded and will leave home around 11:00, get there around noon and get set up, we''ll see what happens !
If I can 'member I'll try to take some pics of some stuff
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
This Thread is more than 1211 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
