Intake Swap - Page 3 - Chevelle Tech
 7Likes
post #31 of 41 (permalink) Old May 9th, 16, 9:36 AM
billy
Re: Intake Swap
[quote=VORTECPRO;8854657]
Originally Posted by bigmachd View Post
I would need to see pictures of your car, and under the hood to say what I would do. I had 2 cars I drove and never saw a trailer with 8 inch converters, car 1 4030 pound 427 1969 Caprice 3.42 gear dailey driver, Car 2 1968 4.10 gear Chevelle. The Caprice used the factory radiator cooler, the Chevelle used a cooler in front of the radiator. Both car typically ran @ 160 degrees. A typical every week drive was a 200 miles round trip to LA county drag strip through the San Fernando valley, 118 freeway to the 36 freeway which is a 38 mile 6% up hill grade in stop and go traffic in sometimes 105 degree heat, I can remember one time my Chevelle got to 188 degrees in this heat in stop and go traffic. Never did I have any trans or converter problems, my fluid always looked great. My Converters at the time were 8 inch Munsingers designed for low RPM stockers, Buick, Olds, Pontiac, the Caprice would flash 4800 355 small block, the Chevelle would flash 5500. My transmissions were both well built strait cut Turbo 400s. The Caprice best was 11.80s the Chevelle best was 9.86 in 108 degree heat. The Caprice probably saw 9000 miles a year for probably 3-4 years, the Chevelle probably 4000 miles a year. My Caprice could have been much faster with a few changes, wheels, tires, converter, gears.
san fernando valley gets really hot , where the track was even hotter ! the traffic is horrible and you were able to maintain 160 degrees drag race on top of all that and drive home !!! that is amazing ! were those engines you built ?
b&b's69 is offline
post #32 of 41 (permalink) Old May 9th, 16, 1:15 PM Thread Starter
Mac
Re: Intake Swap
Thanks mark, I'll try and get that information to you as soon as possible
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #33 of 41 (permalink) Old May 9th, 16, 11:09 PM Thread Starter
Mac
Re: Intake Swap
Hey mark, here's a couple pics under hood, no pics of car as there are to many thunderboomers, and 'naders around and it is in the trailer, its just a 70 ss, stock suspension and 12 bolt with 4.10's, home built th400 no brake and a 3200 10"
And I threw one in of the "other" chevelle
ID:	357649   Click image for larger version
ID:	357657   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #34 of 41 (permalink) Old Jun 12th, 16, 11:06 PM Thread Starter
Mac
Re: Intake Swap
The stealth is back on after heli coil all the intake bolt holes
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #35 of 41 (permalink) Old Jun 12th, 16, 11:19 PM
Re: Intake Swap
If you remove that air spoiler on top of the air cleaner your engine will be happier. Put a factory type lid on there.
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
4.11 12 bolt
Best e.t. to date [email protected] @115.31
1.315 60'
Stokerboats is offline
post #36 of 41 (permalink) Old Jun 15th, 16, 8:07 PM Thread Starter
Mac
Re: Intake Swap
Sooooo a solid lid would work better...... smoother air flow?
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #37 of 41 (permalink) Old Jun 15th, 16, 9:28 PM
Re: Intake Swap
Air enters the carb from the sides not the top. That lid disrupts flow.
'66 SS Chevelle
4.11 12 bolt
1.315 60'
post #38 of 41 (permalink) Old Jun 16th, 16, 8:25 AM
Re: Intake Swap
Hmm... I thought air was like electricity and takes the path of least resistance.
bradley67 likes this.
Name=Rich
Car=67 Chevelle Convertible
Color=Butternut Yellow
Engine=540 FAST XFI,1200 cfm
AFR 325cc CNC, Lunati 242/250 .601/.601/
Trans.=4L80E,TCU, 2700 stall
Diff.=Strange S60 3.54
67 velle is offline
post #39 of 41 (permalink) Old Jun 16th, 16, 10:45 PM Thread Starter
Mac
Re: Intake Swap
Old slightly rusted edlebrock chrome cover is back on, will see what happens next weekend, two day sportsman shootout at Ardmore dragway.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #40 of 41 (permalink) Old Jun 20th, 16, 5:44 PM Thread Starter
Mac
Re: Intake Swap
whoops!, that is wrong, Saturday only and is beat the heat and bracket race
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #41 of 41 (permalink) Old Jun 26th, 16, 10:10 AM Thread Starter
Mac
Re: Intake Swap
Made it to track yesterday, car ran pretty good considering the heat and humidity, was 97* and 55-75 % humidity, DA was around 4300-4600, ran 7-20, 21, 22, 22, 22, 24,(on a dump) 21, 19, a little tire spin on all runs except the 19 and I broke out by .02 on that one, all in all a good day, won the dash for cash ($100.00) and didn't tear anything up , all 60' were 1.64-66, car just doesn't like the heat.
Likes the dual plane a lot better than the single
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
This Thread is more than 1210 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
