I've been posting pics and such in other threads so I thought I'd start one and not pollute others..
New to the site, no really new to drag racing.. BUT I will be the first to say there's always something to learn..
After owning a fox chassis mustang 13 years, and getting VERY tire of it.. I sold it to a friend of mine,and have decided to do another car..
I had a buddy who street raced a 65 El Co many many years ago.. and I've always loved the front ends, but wasn't too into the truck thing.. SO I went out a found a good base to start another build.
I guess I'll keep this running as I progress through its stages.
current config:
136 car, nothing overly special.But had a solid frame underneath it, and was a race car that hadn't been hack up with some backyard 4 link or ladder bar..
Fiber glass:
Fenders
Doors
Hood
Bumpers
Windows:
All Lexan
Front suspension:
All stock with a manual disk conversion
Rear suspension:
Jegs non adjustable control arms
Air bag
Unknown type shocks
Looks like you have a very decent base to start with. Of course there are some things that should be changed (like the brake lines), but the body looks good and you can now make it yours.
And a thank you to you as well! The body was "ok" but there was some filler in there.. I didn't even make it home with the car. I bought the car from a guy in TN, and the guy that painted my mustang is between home and where the guy was in TN. So once I had given the guy a deposit, I went and bought all brand new rear sheet metal for the car, and dropped the car off to get it all hung on the car on my way home. I've only had the car in my presence for like 4 hours... lol
The suspension is something that's going to be gone through first (onc I ge tit back) There are things I can buy that I can use for the long run. I've actually already bought most of the stuff I'll be running from TRZ, a-arms, rear upper and lowers, aftermarket column, stange hub for the wheel. My buddy picked them up while he was at SGMP for the race this past weekend.
A Chevelle, since it has a factory frame is required to have the rollbar attached to the frame. Unfortunately we can't attach plates to the sheetmetal with bolts as can be done with non framed cars.:frown2:
BTW, nice car!!!
Yes, I know the cage needs to be on the frame itself, and the main bars do actually go through the floor to the frame, but I don't know what's going with those inner ones?? But since all that is going to cut out anyway, I'm not going to worry too much about it. About the only real issue will be putting in a window net for now.
Hell it isn't even bolted to sheet metal.. that's all alum!! lol
When the time comes, all those bars will come out, and I'll have the body taken off so the frame can be blasted and painted, then I'll have the cage done..
BTW, nice car!!!
I have the Viking DA rears. I haven't installed them yet as I've other rear suspension parts to install as well. I'm not sure how the Viking shocks will compare to their vastly more expensive competitors.
I also have vikings DA rear shocks, so far only used them on the street at street settings. Replaced summit 3 ways and at least it rides much nicer. Couldnt relly find any bad about Vikings before I bought them?
I would be buying the vikings as a stop gap.. They are inexpensive, and I would imagine offer more control than what's already on the car. I have a set of menscer nitrogen mono-tubes I pulled off the mustang, but I don't want to put in a cross bar to run them right now.
I TOTALLY wish I did... I have zero clue what she weighs at the moment. When I get it back, that's one of the first things I do is going to be get it on a set of scales.
As a little history of the path that brought me to where I sit at this point.. I've done a long build thread in the past when it came to my old mustang.. IF anyone here is bored.. here's the thread..
No sidetracking at all!! I mean, hell, it's through the build process that I learn, and documenting it helps give ideas to others.. at least that how I get some of mine!! lol
But as far as the racepak goes, I HIGHLY recommend getting a datalogger on any race car. I don't know how I raced without it now that I have it. I don't just have the dash though, I have a V300SD, and the dash is only a display. Racepak does make a logger dash, but I don't think it has a g-meter in it, and really, that's 33% of what I look at after a run.. At the track, what I pay most attention to are:
1: Engine RPM
2: Driveshaft RPM
3: G-meter
BUT with all that said.. I think you'd be very happy with it
Call it having walked the path once already, I had a REALLY good idea of what I was looking for this time around! lol
The green car was the end result of a 13 year trek with that car.. I also kept 70% from the car when I sold it, so I have a huge head start as far as projects go. So I kind of "cheated" on this one!
Those grommets are made by Seals-it. Both Summit and Jegs carry them.
Related Threads
Team Chevelle
5.1M posts
115.6K members
Since 1998
