781 head ? - Chevelle Tech
post #1 of 9 (permalink) Old Dec 27th, 14, 3:12 PM Thread Starter
781 head ?
Im planning an 8.5:1 to 9:1 454 with a 5000 to 5500 red line for street only. I will use new springs to match the cam but is there anything to gain with a bigger intake and exhaust valve in the 781's? The calculators say the stock size valves are good to 6000 rpm but thats on paper.
Marty
1980 Camaro Drag Car
1970 Malibu 2dr hardtop cruiser
Dragn70 is offline
post #2 of 9 (permalink) Old Dec 27th, 14, 6:25 PM
TC
Re: 781 head ?
My 781's are stock I gave them a mild port and with my cam it's pulling like bear at 5800 which is were I shift. 1 7/8" headers. I think it'll pull to 6500 easy I'm just don' feel comfortable going there.
1970 Chevelle Malibu 400
25 Astro Blue w/med blue interior
454 w/781's (NOM
+.030 10:1 compression
Lunati 60204
Holley Strip Dom. w/800 DP
M-22W 3.31's 12 bolt
Fun but ole girl likes to drink....a lot
TCSS1970 is offline
post #3 of 9 (permalink) Old Dec 27th, 14, 7:54 PM
Chevelle Doctor
Re: 781 head ?
If you cut the seats and put 2.19's in, cut the throats out, and blend the short side radius, there's a bunch of power to be gained here. Most builders don't see much improvements by going 1.88 on the exhaust however.
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #4 of 9 (permalink) Old Dec 27th, 14, 8:14 PM
Jason
Re: 781 head ?
For such a mild engine the stock size valves will work fine.
I have bone stock 781s on my 10.4:1 454, with the exception of cutting down the valve guides for more lift, and they flow good enough to get me 11.9s in the 1/4.
However, you can do whatever your budget allows for upgrades beyond a basic rebuild with new springs.
My .02˘
69 Chevelle SS
Budget 454, 10.4:1, small valve 781's, Engle hyd cam 244/260 @ .050, .560/.570 lift ICL/LSA 108/108, Performer RPM w/ 750DP
1.75 Dynomax coated headers, Full 3" exhaust with 17665 Super Turbos
700R4 w/10" 3500, 12 Bolt 3.73's, 275/60-15 DOT Hoosiers, 3650lbs without me
Best time: 11.96 @ 111, 60' 1.65 (6-20-2014)
JB SS 396 is offline
post #5 of 9 (permalink) Old Dec 27th, 14, 9:16 PM
Re: 781 head ?
2.19"/1.88" is the standard prescription.
The large exh valve matters ALWAYS, in a BIG way, because that's the weak side to begin with. The weeeeeeeeker the rest of the exh side is (cam, manifolds/headers, head pipes, and so on) the more difference the larger valve makes. Then, once the rest of the system is improved to the point that the valve becomes The Bottleneck, .... you do the math.
In short, ALWAYS upgrade the exh valve. It's the single biggest bang for the buck you can do. Bigger even than the intake most of the time.
RB69SS396Conv is offline
post #6 of 9 (permalink) Old Dec 28th, 14, 5:41 PM Thread Starter
Re: 781 head ?
Thanks for the info. Can this mild combo make use of an RPM intake down low? I plan to use the stock cast iron intake and and buy an SMI qjet or use the 650 vac Holley I have and get an RPM intake if the RPM is a match.
Marty
Dragn70 is offline
post #7 of 9 (permalink) Old Dec 28th, 14, 8:03 PM
MARK
Re: 781 head ?
Every time I install 1.88/2.190 valves I notice back flow before .500 lift in most cases, and that can't be good, be careful. Gotago brought his 2.07/1.720 valved heads in for flow testing the other day, with porting they went 300 CFM on the intake and 215 on the exhaust, and no back flow.
Machined GM production heads
Oil pan modifications
VORTECPRO is offline
post #8 of 9 (permalink) Old Dec 28th, 14, 11:18 PM
Re: 781 head ?
Mark
have you tried doing the 2.19" and leaving the 1.72"
67 camaro:
420 - 641hp HRcam 1.39, 9.79 @ 137.5
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
69 chevelle 350, 200-4R 411s [email protected] (sold)
67RS502 is offline
post #9 of 9 (permalink) Old Dec 29th, 14, 7:35 AM
MARK
Re: 781 head ?
Originally Posted by 67RS502 View Post
Mark
Yes on a towing application.
This Thread is more than 1730 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
