Header Fitment Doesn't Look Right - Chevelle Tech
post #1 of 25 (permalink) Old Dec 26th, 14, 8:24 AM Thread Starter
Photo (1) is the right (passenger side) header. Photo (2) is the left (driver side) header. Notice the distance from the upper control arm cross-shaft bolts. The left side has plenty of clearance. The right side is extremely close. The right, rear bolt had to be shortened about 1/4" just to get the header installed.
These are Hedman HTC 68198. Hedman tech line tells me they have never heard of any clearance problems in this area. I think this is too close. Maybe a defect in how the tubes for this particular header were bent, or the wrong header slipped in along the way? Any other opinions?
When I compare this to my 1971, with Hooker Competition headers, the number 4 and 6 pipes are tucked closer to the block, allowing about the same clearance as on the left side.
ID:	226402   Click image for larger version
RickH is offline
post #2 of 25 (permalink) Old Dec 26th, 14, 8:59 AM
Re: Header Fitment Doesn't Look Right
Is the motor centered between the frame rails? May have to loosen frame stands and slide everything as far as possible to side with lots of clearance.
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
post #3 of 25 (permalink) Old Dec 26th, 14, 10:48 AM
Mine is very similar - had to shorten that bolt too to clear.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #4 of 25 (permalink) Old Dec 26th, 14, 10:49 AM
X2. It certainly looks offset to the passenger side.
USAF Retired (1968-1988)
David Bates is offline
post #5 of 25 (permalink) Old Dec 26th, 14, 11:50 AM
As long as the motor is centered I wouldn't worry about it. Take measurements from the frame rails to the center of both the trans and crank. The dimensions won't be exactly the same. You're looking to compare an offset measurement if not completely centered.
The biggest problem facing America today is that lies are so widely accepted as truths.
Alan F is offline
post #6 of 25 (permalink) Old Dec 26th, 14, 12:13 PM
jimmyradford
I have the same headers on my '67 with stock height heads and mine are centered. Something looks shifted to the right in yours.
TC Member # 4431
'67 Chevrolet Biscayne- SS427 L-36/TH400 (Hers)
'67 Hell Camino-BB 427/TH400 (His)
'66 300 Deluxe 2 door-230/PG
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people and they're generally more useful.
badrad is offline
post #7 of 25 (permalink) Old Dec 26th, 14, 1:02 PM
Rod
What year Chevelle are we talking about?
Interesting that some have suggested that the engine is not centered. Would be great to see some comparison measurements and/or pics. Would measure my '70 but it's apart right now.
Rmchevelle is offline
post #8 of 25 (permalink) Old Dec 26th, 14, 2:14 PM Thread Starter
It's a '69.
I'll take measurements when I get home, tonight; however, I don't remember anywhere to make adjustments on the frame towers or engine mounts. The frame towers bolted straight to the frame, with no slots for movement. The engine mounts the same way - no way to adjust.
RickH is offline
post #9 of 25 (permalink) Old Dec 26th, 14, 2:34 PM
Originally Posted by RickH View Post
It's a '69.
Friend worked in a frame shop. Chevelle # 1 rear ended another car striking the rear with its driver front. This caused massive damage naturally but not damage that couldn't be repaired supposedly back to factory tolerance specs. It was discovered after straightening that the frontal collision had moved the engine towards and down lower on the passenger side about a 1/4 of an inch via an almost unnoticeable buckled cross member engine frame mount area on one side and raised frame mount on the other of the cross member at the driver side.
Doubt this is your issue but just wanted to offer it up.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
Strange 12bolt w/4.10
1971ss454Elco is offline
post #10 of 25 (permalink) Old Dec 26th, 14, 3:38 PM
Levon
Factory big block car or were the engine mounts changed ?
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #11 of 25 (permalink) Old Dec 26th, 14, 4:10 PM
I don't see the steering column in the picture, do you have it installed?
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
post #12 of 25 (permalink) Old Dec 27th, 14, 9:14 AM Thread Starter
No steering column. The body is not yet installed. I'd like to get this issue ironed out, before I install the body.
It's hard to get precise points to measure, but the best I can see is the engine is centered in the frame, within 1/4" or less.
RickH is offline
post #13 of 25 (permalink) Old Dec 27th, 14, 9:20 AM
Check out the other thread about custom exhaust.
It may be cheaper for you to return those headers and find someone who can build a set of headers for you.
You will just have to check into that.
Aaron is offline
post #14 of 25 (permalink) Old Dec 27th, 14, 10:02 AM
I think the lack of a steering column & shaft is exaggerating the view of the engine offset. Once the steering shaft & column are in place, I think it will look normal. I had 2" Hedman headers on my 71 and passenger side was close to the A arm bolt also.
dell72 is offline
post #15 of 25 (permalink) Old Dec 27th, 14, 10:21 AM
Dave 383 now
Looks normal to me
Dave427 is offline
This Thread is more than 2017 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
