Finally got to a 1/4 track with the procharger - Chevelle Tech
post #1 of 25 (permalink) Old May 23rd, 13, 10:52 AM Thread Starter
Ross
Went to Gateway last night with the Oldsmobile. Was a nice night and it was the first time getting it out to 1/4 track with the new valve train and freshening. Had a great time.
Best pass was
1.54 60'
6.51/108
10.17/133
Overall pretty happy. Several things that I took from the night is the 60' wasn't as good as it was when I went to the 1/8th mile track earlier this year, I am sure track played a key role. I pulled a 1.42 (6.40 1/8th) at the other track, if I can get back there then I think that would be my 9.99 pass but who knows. I added some timing and it slowed down so I believe that it still wants more fuel but I want to creep up on this thing without adding to much. Going to do some logging and try to add some more fuel and timing and try it again before drag week. Best part of it the night was the drive home from the track.
Set up is
383
cast steel crank and 5.7 rod
trw flat top piston
comp hydraulic roller cam
ls7 lifters
afr 190 heads (yes these are really old)
victor jr
750 blow thru
D1 procharger
8 lbs of boost 4.25 upper pulley
e85 no cooler
350 turbo ptc converter
3.90 gear with 275s 8" rim
Full exhaust, filter, just like I drive it all the time on the street
30* timing
-9ngk's at .028
83 Monte Carlo SS e85 bbc
1.41 9.47/145.6
82 Cutlass procharged 383 e85 street car
10.17/133
cherp22 is offline
post #2 of 25 (permalink) Old May 23rd, 13, 10:56 AM Thread Starter
Ross
Re: Finally got to a 1/4 track with the procharger
Here is the car
ID:	85266   Click image for larger version
1.41 9.47/145.6
10.17/133
cherp22 is offline
post #3 of 25 (permalink) Old May 23rd, 13, 11:07 AM
Davey
great job Ross...that's flying! nice car and I'm sure you'll get that 9.99 with a little more playing...
Chevelle
SloMo...
'67 Chevelle 516 hyd roller
4.11's
9.06 best mph 147.75
5.73 best mph 119.98
3520 lbs to 3570 depending on fuel
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
crazydavey is offline
post #4 of 25 (permalink) Old May 23rd, 13, 11:23 AM
Yeah nice looking G-body to boot
TX71SS is offline
post #5 of 25 (permalink) Old May 23rd, 13, 11:33 AM
What did the static compression work out to? What would be the most boost you could run with 92 octane pump gas on the street?
Status: Car-Less
GRN69CHV is offline
post #6 of 25 (permalink) Old May 23rd, 13, 11:35 AM Thread Starter
Ross
Im on pump e85 (test 80% last night out of the bowl), its readily available here and just over $3 a gallon so I love it. Not sure on static compression this is just a hack around car so i am tickled that it goes this fast. I know it is decked, flat top piston, 64cc head and comectic head gaskets I believe .041 thick? So in the 10-10.5:1 range is my best guess. I would guess with an intercooler it would be ok on pump I just never felt the need to try it.
1.41 9.47/145.6
10.17/133
cherp22 is offline
post #7 of 25 (permalink) Old May 23rd, 13, 2:23 PM
Jon
That is nice performance for a drive around small block. I have watched your gains on the other car so I am guessing this will do even better yet over time.
72BBMonte is offline
post #8 of 25 (permalink) Old May 24th, 13, 12:19 AM
JIM
That's cool. Neat car and a good night at the track! Congratulations! 9's aren't far away!
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
Best ET
Best MPH
200 MPH at TX Mile
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
post #9 of 25 (permalink) Old May 24th, 13, 3:02 PM
Best pass was
1.54 60'
6.51/108
10.17/133
Set up is
383
trw flat top piston
ls7 lifters
victor jr
750 blow thru
D1 procharger
e85 no cooler
30* timing
-9ngk's at .028
AFR 190's? Have a pair of "them old" heads on my 385, which is currently sitting
"dry docked", under the work bench.
Work in progress:
1970 Chevelle
- 540 /325 AFR's / HR cam
- 4L80E
- 9" 3.89's/ Detroit Locker w/35 spline axles
brimac is offline
post #10 of 25 (permalink) Old May 24th, 13, 4:07 PM Thread Starter
Ross
Yep they are old, probably atleast 8 yrs....lol Seem to be working ok though.
1.41 9.47/145.6
10.17/133
cherp22 is offline
post #11 of 25 (permalink) Old May 24th, 13, 5:39 PM
Best pass was
1.54 60'
6.51/108
10.17/133
Set up is
383
trw flat top piston
ls7 lifters
victor jr
750 blow thru
D1 procharger
e85 no cooler
30* timing
-9ngk's at .028
What are the cam specs have same blower on 350 and whats the difference between the ls7 lifters and the GM stock roller lifters. Did you do the carb or have someone build it for you.
FRANKC is offline
post #12 of 25 (permalink) Old May 24th, 13, 5:59 PM Thread Starter
Ross
The gm ls7 lifters are actually a direct replacement for the l98 lifter through gm. There have been discussion on here about them lasting on a camshaft like this but the old l98 lifters lasted several years for me. They definitely have a better rpm capability as I was running in the upper 6's through the traps, although i feel it would be better suited with less gear. However, my block is a late model hydraulic roller block so thats why they work with it vs. running a retro fit. Of course I would love to run a set of Morel lifters but the budget was a limiting factor for me and I get good prices on GM parts because I work at a dealership.
The carb was worked by my friend Tim at Ultimate Speed and Machine.
I'll pm you the cam specs
1.41 9.47/145.6
10.17/133
cherp22 is offline
post #13 of 25 (permalink) Old May 25th, 13, 4:37 AM
Ron
Sweet set up! Killer times
69 Camaro
491/AFR 315/Straub hyd roller/pump 91
TH400/GV OD/9" 3.50's/ 255/60/15 DR
10.86 at 124.8
3670 with driver
dirtlips408 is offline
post #14 of 25 (permalink) Old May 25th, 13, 5:35 AM
nice setup.
78 Malibu, 402, eddy heads, 174 B&M blower, th350, holley sniper EFI, 9" 3:70, 26X8.50-15 slicks.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
04 scion XB daily driver.
Jebchevelle is offline
post #15 of 25 (permalink) Old May 25th, 13, 9:39 AM
Nate
What type front springs do you run on your cutty Ross. I need some on mine and don't no where to start.. I got trick springs and I hate the fronts and want to go a inch lower than the trick rear springs.. The fronts sag way to much..
If losing didn't hurt so bad, then winning wouldn't feel so good. NastyNate
nastynate is offline
This Thread is more than 2427 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
