Drag Only Chevelle Build - Page 8 - Chevelle Tech
 160Likes
post #106 of 282 (permalink) Old Dec 5th, 16, 7:35 AM
Re: Drag Only Chevelle Build
Nothing wrong with the engine being level in a tube chassis car. And yes, sometimes the crank centerline is lower than the pinion. Even my backhalf car, the trans points down and the driveshaft runs upward to the pinion.
Used to be bracketchev1221 until my account was lost
70 Chevelle 540, t-400. 9.03 at 148 1.24 60' and still 3200 lbs.
Ray
bracketchev70 is offline
post #107 of 282 (permalink) Old Dec 5th, 16, 7:06 PM
Jarad
That is coming along nicely.
Sent from my LGMS428 using Tapatalk
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
post #108 of 282 (permalink) Old Dec 5th, 16, 7:41 PM
MARK
My car was setup with a tube in my main saddles to align with the differential. Not many people would take on a project like that, good progress.
Machined GM production heads
Oil pan modifications
Red Line Camshaft
VORTECPRO is offline
post #109 of 282 (permalink) Old Dec 5th, 16, 8:18 PM Thread Starter
Mac
Thanks for the replies fellas, got engine sitting level in car at ride height, center of trans tail is 12.75" from ground, and dig this, with pinion level to 1 degree down from level, center of pinion is 12.75" from ground, don't know how that happened but that's where it's at . I aligned engine and trans with a string, in one of the pics you can see a wood block in the front main that I cut with a hole saw, tied string to a small stick to hold it on that end, ran string through engine and trans,( trans has another block of wood in the tail housing where the yoke seal goes), moved engine around till string did not touch hole in block of wood in tail housing with other end of string at center of pinion, looks and measures to be true. working on engine limiters and trans cross member and mount and driveshaft loops next, Its comin' along just a little slow.
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #110 of 282 (permalink) Old Dec 21st, 16, 9:59 PM Thread Starter
Mac
Got a little bit more done, limiters , mount and loops. Trans cross member and front driveshaft loop are bolted in, rear loop is welded solid, still lack a couple of braces on that one. Probably in the nest week we are going to assemble engine to the point of measuring and ordering the pushrods, also going to take the glide to shop to be gone through, don't know if we want to go with a super bell and trans shield or just go with a super case, any one with thoughts on this ?
By the way, it's not an optical elusion, the loops are not "perfectly" round, the more I tried the worse it seemed to get and I was almost out of acetalene . They will do what they were designed to do
ID:	409082   Click image for larger version
ID:	409090   Click image for larger version
ID:	409098   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #111 of 282 (permalink) Old Dec 21st, 16, 10:06 PM Thread Starter
Mac
And it was also kind of cool in the shop this weekend, but these helped me get through it all just fine
ID:	409138   Click image for larger version
ID:	409146   Click image for larger version
aukai and Ants68 like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #112 of 282 (permalink) Old Dec 24th, 16, 11:26 AM
Jon
When is the christening? When is it going down the track? Lot of work there Mac.
72BBMonte is offline
post #113 of 282 (permalink) Old Dec 30th, 16, 9:51 AM Thread Starter
Mac
Yeah lot of work, and a lot left to do, lots of little things, hopefully it get christened this next year and makes passes, we have a couple sponsors lined up but nothing finalized yet, if that gets done in January it will go a little quicker , but, I could spend the amount we "agreed" on tomorrow and still not have all the parts, next major purchase will be the fiberglass parts, cant turn lose of the funds just now as it is the slow time of year, It will go down the track in '17, even if we have to push it
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #114 of 282 (permalink) Old Jan 2nd, 17, 10:03 PM Thread Starter
Mac
A little metal work in the trunk area, not perfect but not bad for first timers
ID:	411217   Click image for larger version
ID:	411225   Click image for larger version
Wolfplace and Ants68 like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #115 of 282 (permalink) Old Jan 3rd, 17, 1:17 AM
Very impressive to me.....
Wolfplace likes this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #116 of 282 (permalink) Old Jan 3rd, 17, 1:39 AM
A formidable task to say the least. Hat off to you for the effort.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is offline
post #117 of 282 (permalink) Old Jan 3rd, 17, 11:28 PM Thread Starter
Mac
Thanks for the compliments fellas, between the measuring, lots of measuring, cutting and trimming patterns again and again, cutting and bead rolling and braking and trimming again and again, plus one ruined piece, (cut it to narrow) crew chief and I have about 12 hours in just those three pieces . I like the forming, bending, bead rolling and stuff but the "fitting" is for the birds, put it in, does not fit, take it out, trim it, put it back in,............................................... .................................................. .................................................. .................................................. ....rivet it together
Door panels and inside latch releases are next, I think
cozmacozmy likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #118 of 282 (permalink) Old Jan 4th, 17, 1:11 AM
You have a rare but awesome Crew Chief.
'66 SS Chevelle
91 octane special
first day out
[email protected]
post #119 of 282 (permalink) Old Jan 4th, 17, 9:36 PM Thread Starter
Mac
Yes I do, thank you sir !
Don't know how a southern outspoken, stubborn, opinionated, cussin', dippin', drinkin', hell raisin', fast drivin', (the list goes on), good ole country boy like me wound up with her, she's been puttin' up with me for 28 years, hope she keeps me around for 28 more
kettbo and Blown1932 like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #120 of 282 (permalink) Old Jan 11th, 17, 9:13 PM Thread Starter
Mac
A little more progress, door panel and inside latch, had to build the top inside of door as the previous owners had cut it out, not a problem, couple of pieces of 2" 14 ga angle, welded to the door and a piece of aluminum angle and a piece of square alum tubing behind latch for a little support, it's not perfect either but............
bead roller we are using is a home made piece that my buddy made years ago, has a little play in it
ID:	413378   Click image for larger version
ID:	413386   Click image for larger version
ID:	413394   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
