Drag Only Chevelle Build - Page 7 - Chevelle Tech
 160Likes
post #91 of 282 (permalink) Old Nov 8th, 16, 8:33 AM
MARK
Re: Drag Only Chevelle Build
Excellent work ethic!
Machined GM production heads
Oil pan modifications
Red Line Camshaft
VORTECPRO is offline
post #92 of 282 (permalink) Old Nov 9th, 16, 4:31 PM Thread Starter
Mac
wheel tubs suck worse than hangin' sheetrock
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #93 of 282 (permalink) Old Nov 9th, 16, 4:34 PM Thread Starter
Mac
Originally Posted by 72BBMonte View Post
Truly from the ground up....
yes sir from front to back and the sides too also
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #94 of 282 (permalink) Old Nov 9th, 16, 4:37 PM Thread Starter
Mac
Originally Posted by Stokerboats View Post
Now that's a project.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #95 of 282 (permalink) Old Nov 9th, 16, 4:40 PM Thread Starter
Mac
Thank You, we're doin' the work, hopin' for the results !
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #96 of 282 (permalink) Old Nov 9th, 16, 7:27 PM
Ron
Did you have 2 bodys? The copper one and red one? Cool project.
70 Chevelle SS396 (496) Straub roller, 700r4
69 Malibu convertible (sold)
TC #54 Gold
ToocoolZ28 is offline
post #97 of 282 (permalink) Old Nov 9th, 16, 8:02 PM
Thanks for showing all it takes to get something like this done.
You talked me out of my fantasy of doing it myself. Probably saved me a ton of cash and untold hours of labor. I'll just settle for a roll cage in a factory framed ride.
Gary Adrian
Busted Knuckles is offline
post #98 of 282 (permalink) Old Nov 10th, 16, 4:54 PM Thread Starter
Mac
Yes, had two, was going to use the copper one but just wound up salvaging doors, glass and some moldings, found the red one in the mean time and is a better body, copper one had some rust issues, red one used to be a back half car.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #99 of 282 (permalink) Old Nov 10th, 16, 4:55 PM
You got speed parts coming you way Sir!!!!!!
Chris Straub
Mfg Performance Parts
cstraub is offline
post #100 of 282 (permalink) Old Nov 10th, 16, 5:06 PM Thread Starter
Mac
LMAO, You are very welcome sir !!!! And to think the red body we started with used to BE a back half car and HAD a cage already in it, go figure
On the bright side when we get through with it, it will be ours, and rite, wrong, or otherwise, we (wife and I) , can say that WE built this car from the ground up !!
But if we ever do another one we will probably do just what you stated above
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #101 of 282 (permalink) Old Nov 10th, 16, 8:04 PM Thread Starter
Mac
Thanks Chris, gonna be like early Christmas, wont know specs till I unwrap it !
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #102 of 282 (permalink) Old Nov 11th, 16, 8:17 PM Thread Starter
Mac
I have a question on driveline angle, will it hurt anything if the crankshaft centerline is below the pinion centerline, or does the crank centerline have to be above the pinion centerline. getting ready to cut motor and midplates and mock up engine and trans mounts.
Also have conflicting info on engine mounting, should it be level in car at ride hight or tilted slightly down in the rear.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #103 of 282 (permalink) Old Nov 13th, 16, 8:26 PM Thread Starter
Mac
And this pic is just for Jon, big green tractor car lift also doubles as wash rack
Oh and by the way, last race of season old heavy chevelle ran a new best of [email protected]
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #104 of 282 (permalink) Old Nov 13th, 16, 8:44 PM
Jon
I love to see JD green...
dtrubey likes this.
72BBMonte is offline
post #105 of 282 (permalink) Old Dec 4th, 16, 9:38 AM Thread Starter
Mac
A little more progress
ID:	405097   Click image for larger version
ID:	405105   Click image for larger version
ID:	405113   Click image for larger version
ID:	405129   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
