Drag Only Chevelle Build - Page 6 - Chevelle Tech
 160Likes
post #76 of 282 (permalink) Old Jun 13th, 16, 10:34 PM
Jon
Re: Drag Only Chevelle Build
Originally Posted by bigmachd View Post
Here ya go
looking good that a 4020?
72BBMonte is offline
post #77 of 282 (permalink) Old Jun 14th, 16, 1:55 AM
Hang in there Mac, good progress.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #78 of 282 (permalink) Old Jun 15th, 16, 8:44 AM
Dale
It's starting to look like a race car! Cool project Mac. I only did 1 of these years ago; it was a V-8 Vega. I did my own custom suspension front & back. Will never do that again. My hat is off to you!
Also- Most people don't appreciate a man and his JD. It is a friend that will do whatever you ask, doesn't talk back and will never leave you.
Name:	pullin stumps.jpg
bigmachd likes this.
66 Chevelle
1/8 mile
1/4 mile
Building more of a race car than driver but driving it more than I race. "simple old school shake, rattle & roll".
Monk is offline
post #79 of 282 (permalink) Old Jun 15th, 16, 6:47 PM Thread Starter
Mac
Yes Sir, '68 model
72BBMonte likes this.
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #80 of 282 (permalink) Old Jun 15th, 16, 6:59 PM Thread Starter
Mac
Thanks for the compliments and replies fellas, yeah the "lets build a tube chassis race car" from the ground up is a novel idea, but damn, I spent hours figuring this and that, this angle and that angle, this length and that, then when figured out takes about 15 minutes to cut, grind, fit, grind and weld in place, MOST all of that is done now, on chassis, don't know what were gonna get into on sheet metal work, have 40" tubs out in shop also, will install them after we de-rust and seal and paint inside of body and attach to chassis. Its a learning curve for sure . Like others have said, don't know if we will ever do it again...........................yeah we probably would, heck the next one should be a bbrreeeeeeezzzzzzzzzzzee
72BBMonte and b&b's69 like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #81 of 282 (permalink) Old Jun 15th, 16, 10:03 PM
Jon
They are almost always good stuff, I make a good living working for Deere. Pretty proud of the company and it's products.
72 Monte Carlo (3865 lb Street/sStrip Orange Monster)
6.09/113.75 mph 1.32 60 ft.
9.634/141.50 mph-best pass
79 Trans Am Super Street, Top Eliminator, Super Pro , Quick 16, Hot Rod
5.25 eighth mile
8's quarter mile
post #82 of 282 (permalink) Old Jun 15th, 16, 10:05 PM
Jon
Nice you are documenting your progress Mac.
post #83 of 282 (permalink) Old Sep 13th, 16, 10:29 PM Thread Starter
Mac
A few more pics. Chassis painted and body mounted, even got the crew chief in there
ID:	388513   Click image for larger version
ID:	388521   Click image for larger version
ID:	388529   Click image for larger version
ID:	388545   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #84 of 282 (permalink) Old Sep 13th, 16, 11:27 PM
Great to see the pictures, looking good.
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #85 of 282 (permalink) Old Sep 14th, 16, 6:27 AM
Marco
Looking good Mac .Your hard work will pay off in the end.
1964 Chevelle 300, all steel, full interior. DOT tires all around, through mufflers. TH400, 12 bolt posi 4.10
Old combo - 454 10-1 , 049 heads home ported 2.19,1.88,DP Intake,1050 4150,Comp XR294HR, 2''x3.5'' headers. 1.43 - 6.82 / 98.98 - 10.77 / 123.83 MPH
New combo - 454 .100 over 13-1, Afr 325, SR cam
1.39 - 9.96 - 134.71 MPH so far.
big block 64 is offline
post #86 of 282 (permalink) Old Nov 7th, 16, 6:24 PM Thread Starter
Mac
Couple more pics
ID:	399514   Click image for larger version
ID:	399522   Click image for larger version
ID:	399530   Click image for larger version
ID:	399546   Click image for larger version
Wolfplace likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #87 of 282 (permalink) Old Nov 7th, 16, 6:27 PM Thread Starter
Mac
engine, so far
ID:	399562   Click image for larger version
ID:	399570   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #88 of 282 (permalink) Old Nov 7th, 16, 9:48 PM
Don't ya just luv wheel tubs.....
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #89 of 282 (permalink) Old Nov 8th, 16, 12:40 AM
Jon
Truly from the ground up....
post #90 of 282 (permalink) Old Nov 8th, 16, 2:52 AM
Now that's a project.
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
4.11 12 bolt
Best e.t. to date [email protected] @115.31
1.315 60'
Stokerboats is offline
