Drag Only Chevelle Build - Page 4 - Chevelle Tech
 160Likes
post #46 of 282 (permalink) Old Jan 16th, 16, 4:24 PM
Re: Drag Only Chevelle Build
Impressive build. Seen some great work from small gearhead shops. Keep up the good work. Does your cage need tig welding to be certified ? When you get the lower structure figured out the remainder will follow quickly. Good luck, will be watching picking up new details.
Joes-427-vette is offline
post #47 of 282 (permalink) Old Jan 16th, 16, 5:03 PM Thread Starter
Mac
no tig, its just mild steel. Have it all welded up now and trying to figure what ride hight we want when finished.
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #48 of 282 (permalink) Old Jan 16th, 16, 5:10 PM Thread Starter
Mac
anyone know what sprng weight would be best on this set up, going to be strut front end, probably going with strange units with a 3" stroke, 4 link rear, small block, and fiberglass front clip, figure it will weigh 2500+ lbs, buddy of mine has 250's on front of big block vega so I was thinking 200-225, or am I thinking wrong.?
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #49 of 282 (permalink) Old Feb 27th, 16, 10:56 PM Thread Starter
Mac
got front strange external double adjustable coil over struts with 300# springs coming from s&w race cars, (spring rate was recommended by them),also strange rear external double adjustable coil over shocks with 130# springs coming from them also, will be installing magnum 4 link from performance engineering, after lots of measuring as these are for a 3" tube and I am using a big web ford housing and the tubes are 3.250 and the round end of the web is 3.5" and the "rounded square" part of the web is 3.9**", we will also be adding a back brace, so that complicates it even more. we got a narrowing jig and wishbone from lead mine products, this will be our first attempt at narrowing a rear end. got body bolted to chassis for fitment, still have to bend rear frame rails and front uppers. Here's a few pics of slow progress.
ps. Wife's (crew chief and team owner) favorite new sayin is "Quit Overthinkin' it and JUST DO IT".
ID:	335889   Click image for larger version
ID:	335897   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #50 of 282 (permalink) Old Feb 27th, 16, 11:06 PM Thread Starter
Mac
A few pics of rear, gonna work on it some more tomorrow
ID:	335913   Click image for larger version
ID:	335921   Click image for larger version
ID:	335929   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #51 of 282 (permalink) Old Feb 28th, 16, 7:30 PM
130's may be a bit heavy but see how it works. I used 130's in my car at almost 3200 lbs.
Ray
bracketchev1221 is offline
post #52 of 282 (permalink) Old Feb 28th, 16, 10:13 PM Thread Starter
Mac
Thanks Ray, I thought the 300's were a little much and the 130's a little light, but I've never set one up either, went with those rates as that's what S&W recommended.
Thanks again,
Mac
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #53 of 282 (permalink) Old Feb 29th, 16, 12:51 PM
I have 138's in the car now since I replaced the springs with Hypercoils. They only sold 125 and 138. I HAD 130's in the car and was a little reluctant to go down to 125's. I know my car is heavy. It was 3170-80 last time I weighed it. So I felt more comfortable with the nominal number being 138. But the car had gone 1.266 in 60' with the old shocks and has been 1.242 with the new double adjustables. For the front, I have no experience with the coil overs. I know they are usually heavier due to the small spring.
Ray
post #54 of 282 (permalink) Old Feb 29th, 16, 3:10 PM Thread Starter
Mac
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #55 of 282 (permalink) Old Feb 29th, 16, 4:06 PM Thread Starter
Mac
Question; does anyone think I will need a rear anti roll bar, if so I can do that along with the rest of the stuff I am doing to the rear end at this time, got the 4-link brackets all trimmed and squared and level and partially welded yesterday, they were a pain to fit on the big web, had to trim them a little on one side and a lot on the other, I also cut the "square" to square, so now I have a little filling to do also , but ain't no hurdle we can't get over
ID:	336361   Click image for larger version
ID:	336369   Click image for larger version
ID:	336377   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #56 of 282 (permalink) Old Mar 1st, 16, 11:01 AM
I would run an anti-roll
As for hanging the tabs on the rear now.. I would say you need to have the bar mounted/located in the car to understand where the tabs on the rear will need to be mounted.
90lxracer is offline
post #57 of 282 (permalink) Old Mar 1st, 16, 12:27 PM
I agree. If its a 4-link yes.
post #58 of 282 (permalink) Old Mar 1st, 16, 4:08 PM Thread Starter
Mac
Thanks for the info fellas, yes its gonna be a 4 link.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #59 of 282 (permalink) Old Mar 16th, 16, 10:00 PM Thread Starter
Mac
A little more progress, two boxes in shop full of front and rear suspension parts, also got a pair of old centerline front runners with tires from racing buddy, got plenty to keep us busy now.
ID:	340922   Click image for larger version
ID:	340930   Click image for larger version
ID:	340938   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #60 of 282 (permalink) Old Mar 24th, 16, 10:10 PM Thread Starter
Mac
A couple more pics of sloooowww progress , between work and tractors and sprayers and cows and other stuff we got a little bit more done, a little bit.
Looked at springs and they are hypercoils, 300 front and 125 rear.
gonna make a crude jig to hold struts so we can get mounts in correct position on chassis, then when we get this about halfway done we will order parts to fill rear end and then start on rear 4 link suspension.
ID:	343369   Click image for larger version
ID:	343377   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
