Drag Only Chevelle Build - Page 18 - Chevelle Tech
 160Likes
post #256 of 282 (permalink) Old Nov 21st, 18, 8:37 PM Thread Starter
Mac
Re: Drag Only Chevelle Build
Originally Posted by bracketchev1221 View Post
6.00 put mine right at 9.50 in the 1/4.
We might try to run some 1/4 mile stuff next year, but its a 180 mile drive to the motorplex or tulsa raceway,if they still run 1/4, we got kinda spoiled with our home track 35 miles away and two more within 75 miles still have not made it to extreme raceway, its brand new and a few miles from the motorplex.
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #257 of 282 (permalink) Old Dec 28th, 18, 7:58 AM Thread Starter
Mac
Now the "work" begins, I think this thing has been painted 3 times and sprayed with epoxy double tough primer and sealer and Imron paint,I think the bondo has diamond dust in it cause it is tough, and one layer of some substance not of this planet that mankind has never seen before ,
Gonna take a little work, the 48 year old body has a lot of waves in it, but we knew it wasn't gonna be a quick job before we started.
Cut an old scoop that we had laying around to cover the air filter, got it glassed on, and the progress you see on the sanding is TWO days, crew chief and myself, with 40 and 80 grit paper, some by hand and most with da's and orbital sander, like we always say, "if it was easy everybody would do it"
ID:	581744   Click image for larger version
ID:	581746   Click image for larger version
ID:	581748   Click image for larger version
ID:	581752   Click image for larger version
ID:	581754   Click image for larger version
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #258 of 282 (permalink) Old Mar 13th, 19, 10:40 PM Thread Starter
Mac
A few pics of new paint, still waiting on some vinyl decals, having decals made to simulate all the emblems.
ran at TVRP in Noble last weekend, went 6.23-6.20-6.22-6.17, also got the nitrous hooked up but sunday t and t was canceled due to weather, next t and t is two weeks. also had converter re-stalled to 5800 from 4800 , builds a lot more heat in trans, added bigger cooler with fan, also added delay box in hopes of running some super pro classes also.
ID:	588924   Click image for larger version
ID:	588926   Click image for larger version
ID:	588928   Click image for larger version
Wolfplace, aukai, badrad and 4 others like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #259 of 282 (permalink) Old Mar 14th, 19, 2:44 AM
Awesome!!!
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #260 of 282 (permalink) Old Mar 14th, 19, 7:35 AM
Thumbs up Re: Drag Only Chevelle Build
Car runs & looks great!
bigmachd likes this.
2000 Pontiac Trans Am WS6
6.0 LQ4, 4L80e, 9", Turbocharged
rel3rd is offline
post #261 of 282 (permalink) Old Mar 14th, 19, 9:22 AM
Nice job Mac car looks great
66 chevelle
New Combo
555
10.2 comp
Straub ProMaxx heads
Straub solid roller
TH400/373
3815lbs
1.31 60'
[email protected]
[email protected]
B433 is offline
post #262 of 282 (permalink) Old Mar 14th, 19, 9:58 AM
Looking good Mac!!!!!
Chris Straub
Mfg Performance Parts
cstraub is offline
post #263 of 282 (permalink) Old Mar 14th, 19, 2:54 PM
Mac, what silver did you use on the bumper?
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #264 of 282 (permalink) Old Mar 14th, 19, 5:51 PM Thread Starter
Mac
Mike, it's mid 90's or 2000's gm metallic silver, Ill get the exact color off of can in a little while, pics dont do the silver justice, overall turned out pretty good for a race car paint job, now just have to spend the next 2 years getting all the "body shop" dust out of the shop.
aukai likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #265 of 282 (permalink) Old Mar 14th, 19, 5:52 PM Thread Starter
Mac
Appreciate the complements and comments fellas, Thanks!
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #266 of 282 (permalink) Old Mar 14th, 19, 9:10 PM Thread Starter
Mac
Silver is Dupont Nason line, GM 09-19 Silver Ice code 636R
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #267 of 282 (permalink) Old Mar 14th, 19, 9:35 PM
Thank you
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #268 of 282 (permalink) Old Mar 28th, 19, 1:00 PM Thread Starter
Mac
Thank you
Not a problem.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #269 of 282 (permalink) Old Mar 28th, 19, 1:02 PM Thread Starter
Mac
T&T this Saturday, IF it doesn't rain.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #270 of 282 (permalink) Old Apr 3rd, 19, 7:17 PM
Jon
Twins are awesome Mac.
72BBMonte is offline
