Drag Only Chevelle Build - Page 16 - Chevelle Tech
 160Likes
post #226 of 282 (permalink) Old May 2nd, 18, 12:32 PM
Re: Drag Only Chevelle Build
Outstanding first outing Mac, congratulation to you & the crew,,,,
bigmachd likes this.
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #227 of 282 (permalink) Old May 3rd, 18, 6:19 PM Thread Starter
Mac
Originally Posted by cstraub View Post
Well out of the gate sir you have impressed. Congrats man to the beginning of what should be new best each week. If you want me to post the cam card I will sir.
Chris you are more than welcome to post the cam card, I would have but don't know exactly where it is.
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #228 of 282 (permalink) Old May 3rd, 18, 6:23 PM Thread Starter
Mac
Thanks again fellas,
Rained out again this weekend,
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #229 of 282 (permalink) Old May 4th, 18, 9:44 AM
Camshaft Specs:
Intake Exhaust
Duration @.050 251 256
Duration @.006 301 308
Lobe Lift .3680 .3550
Valve Lift 1.7 Ratio .626 .603
Centerline 105 110
Chris Straub
Mfg Performance Parts
cstraub is offline
post #230 of 282 (permalink) Old May 4th, 18, 5:27 PM Thread Starter
Mac
Camshaft Specs:
Intake Exhaust
Centerline 105 110
Thanks Chris
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #231 of 282 (permalink) Old May 6th, 18, 9:12 PM Thread Starter
Mac
gonna try to run at thunder valley in noble ok next Saturday the 12th and see what happens.
JBoggs likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #232 of 282 (permalink) Old May 7th, 18, 10:01 PM Thread Starter
Mac
go pro was sittin under the carport when I got home today, ssoooooooooo, maybe some ride a long video this weekend, IF I can figure out how to operate it,
JBoggs likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #233 of 282 (permalink) Old May 13th, 18, 11:08 PM Thread Starter
Mac
Well we made it to thunder valley, 6.39 first pass, still not rpming like it should, go back for second time trial notice that its only idling at 1000 just before burn out box instead of 15-16, wack throttle couple times, no change and a very slight hesitation, I just figure I didn't push in the "lean out"cable soon enough, it'll clear up, do burn out, pre stage, stage, launch, for about 30 feet and it falls on its face and dies, pull over and try crank again, no start, get towed back to pit, pull front end off and us and some buddys are "lookin" at it, talk it over a little and decide to see if a fuel issue or ignition, four some fuel down its throat and crank it and it starts and dies, OK, its a fuel issue, pull line off of barrel valve and crank engine, NO fuel, dry as a bone, crack suction line off of pump a couple rounds and fuel pours out, crank again and make sure shaft on fuel pump is turning, it is, so only thing we think could be is maybe sheared key on one of the internal gears, waiting till tomorrow to talk with James before I open it up, maybe something else, and don't want to loose warrantee if there is one, might order a new one and keep this one, after it is repaired for spare, don't know yet, could have been the reason the little small block would not spin as fast as it should have, don't know yet, time will tell.
AND, we had one video of the aborted run, we tried to edit it just a few minutes ago as it was 9 minutes long, well we edited it rite out of existence , so the go pro is also a learning curve.
Gonna try and get a pump on this thing and find somewhere to make a few more runs this coming weekend, first points race of the so far rained out season is two weeks away, IF IT doesn't get rained out also.
Stay tuned folks, that's not all !!!!!
aukai and oliver69 like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #234 of 282 (permalink) Old May 14th, 18, 10:48 PM Thread Starter
Mac
Talked with James Monroe from Killer Rons today and after we talked for a while he says check and make sure pump did not back out of pump drive, and I'm like, huh?, come to find out the pump which I thought was one piece and a mount bracket is actually, pump, pump drive, and mount bracket, and sure enough it had backed out of the drive about 3/8-1/2", and it only engages about 1/4', took longer to get the front end off than it did to fix it,......... loosen lock bolt, push pump back into drive, tighten the s**t out of lock bolt, done, crank engine about 3 seconds and its rumblin'. Live and learn, wish I and some others would have known about the drive on Saturday, but that's racin'. Now we just might have to go to the motorplex at Ennis Tx, this weekend, not sure yet, wife not thrilled about a 2.5-3 hour drive, but need to make a few more passes before Memorial Day. Yippie eye aye cow pattie !!
ID:	553865   Click image for larger version
JBoggs likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #235 of 282 (permalink) Old May 15th, 18, 3:48 AM
Experience is something you get right after you needed it......
bigmachd and JBoggs like this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #236 of 282 (permalink) Old May 21st, 18, 9:30 PM Thread Starter
Mac
Well no passes this past weekend, well went bad so we were diggin' ditches and laying water line to get hooked up on rual water, no more well water , smells a little like bleach, but that's better than the funky smell it had when it went bad, we've been totin' drinking water for about 4 months, finally got a meter set a week ago, all good now I guess.
On to the performance part, we are going to run at Ardmore dragway this Friday through Sunday, if it doesn't rain us out again. Fingers crossed
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #237 of 282 (permalink) Old May 28th, 18, 2:45 PM Thread Starter
Mac
Well it didn't rain us out and we ran all three days, no new best as we left the tune as it was as this was a points race, best for the weekend was a 6.31 in the heat and humidity, which, should have slowed down but ran .07 FASTER than it should have, more to come on that PLUS we got a few vids which I will try to post later
cozmacozmy and JBoggs like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #238 of 282 (permalink) Old Jun 3rd, 18, 8:52 PM Thread Starter
Mac
Went a few rounds this weekend, very few, light kept turning red for some reason, still got more tuning to do, here's a couple of slips, (NA) from the weekend. Still working on videos, AND, today we forgot to get the camera out of the car before we loaded it
ID:	560841   Click image for larger version
JBoggs likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #239 of 282 (permalink) Old Jun 4th, 18, 1:18 PM
Jon
One day it will all come together and you'll be scratching your head saying why did it take so long for me to figure that out? You're like me, you tell it how it is, good or bad.
72BBMonte is offline
post #240 of 282 (permalink) Old Jun 6th, 18, 5:22 PM Thread Starter
Mac
I sure hope its some day soon, yeah, heck I'd rather tell off on myself than someone else do it, that way you get the facts, just the facts.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
