Drag Only Chevelle Build - Page 15 - Chevelle Tech
 160Likes
post #211 of 282 (permalink) Old Apr 3rd, 18, 11:03 PM Thread Starter
Mac
Re: Drag Only Chevelle Build
Originally Posted by bracketchev1221 View Post
I miss the car. I don't miss headaches like this and the work that went with it. Not with my Chevelle, but I've been on the side of the road with broken hold downs and the car half off the trailer, and tire blowouts.
The comments of "as long as the car and trailer made it home in one piece was a good day" exist for a REASON!!!!
Along those same lines..... buddys will ask "how'd ya do this weekend", I USUALLY tell them "we didn't tear anything up so it was a good weekend",...........but not this time
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #212 of 282 (permalink) Old Apr 3rd, 18, 11:07 PM Thread Starter
Mac
Originally Posted by BigRed-L72 View Post
Ouch...Those pictures of the slick and rim are painful to look at Sorry that happened.
It`s crazy how things decide to act up once you get to the track !
Looking forward to better outings in the near future !
Yeah, sick feeling over that, Just bought that set last year, cheap, never got to run them, gotta try and find another 14x15 convo pro, there's one out there somewhere.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #213 of 282 (permalink) Old Apr 3rd, 18, 11:15 PM Thread Starter
Mac
tires and starter arrived today, got starter on, jerry rigged air bags on truck with a "T" and a valve stem, painted under rear quarters where crew chief fixed the rocks problem, will mount tires tomorrow and get them balanced Thursday, still got a lot of stuff to do, Tand T Friday and its supposed to rain, might only get the two time trials Saturday for that, have to wait and see, yippy ky yea cow pattie !!!!!
Still have not located time slip, don't even think I was in it the whole 60, but I would like to see it, never looked at it.
aukai likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #214 of 282 (permalink) Old Apr 6th, 18, 6:28 PM Thread Starter
Mac
Races called do to incoming weather,
On the bright side it gives us a little more time, can also go to the track while closed and make a few "tuning" passes, probably do that next weekend, have trailer to repair this weekend.
aukai likes this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #215 of 282 (permalink) Old Apr 16th, 18, 10:57 PM Thread Starter
Mac
Car is ready to go with new 32x16x15 goodyear slicks, new powermaster starter, (new Orileys lifetime warranty starter in trailer for spare) repaired most of the outriggers, frame rail, brake and tail light wires, trim and lower awning mount, mounted fuel jug racks on wall of trailer and got rid of the dragster ramps and built a 6x3 flip down ramp out of 1/4" aluminum that we had laying around, ramp would not fold completely over onto door due to the thickness of the material and rivets, ssooooooo........ we just made some stands that hook to the side of the ramp and are held on with the tie down strap. .
Could not get on track last weekend due to owners being out of town,(racing at motorplex) North Star Dragway in Sanger Tx. is having a tnt this sunday and we plan to be there so we can get some kind of tune in this thing. Just hope it works out better than the first outing.
Hopefully we keep a time slip
We Broke out the spool gun crew chief bought me 3 years ago, (been sittin on shelf in shop) not to bad we think for first time welding aluminum
Now we gotta build a box for a step
ID:	545441   Click image for larger version
72BBMonte and JBoggs like this.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #216 of 282 (permalink) Old Apr 19th, 18, 3:38 PM Thread Starter
Mac
Got dates mixed up, TnT at Sanger Tx. is NEXT Sunday the 28th, ....Gotta se if I can get some meds for CMS, I think its getting worse.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #217 of 282 (permalink) Old Apr 19th, 18, 8:33 PM
I used the Goodyear d1408 16x32ís on my car. I liked them. They seemed to 60í better than the Hoosiers for me but the car was also 3180 lbs.
bigmachd likes this.
Ray
bracketchev1221 is offline
post #218 of 282 (permalink) Old May 1st, 18, 6:00 PM Thread Starter
Mac
Finally made it to tnt at north star dragway in sanger tx, Saturday and sunday little small block 70 chevelle went 6.38 off the showroom floor,86 pill in barrel valve that came in it and 25* timing locked, straight as an arrow, crew chief said it has no or hardly no front end rise, little to none rear squat, "it just goes", nothing dramatic. tried richening it from a 86 to an82 pill and it slowed down, tried advancing timing to 27, no change, went back to 25* and leaned it with a 90 pill, 6.31, advance timing to 27, 6.25, and its 18:30 its time to go home. Overall very pleased with the performance of the car so far.
Power should be 55-75 with a 7800 shift point, never made it that far, did not nose over but just seemed to pull to a certain point and that's it, wound up shifting at 68-7 and all worked well, might rpm more with some more tuning, we will be racing at Ardmore dragway in springer ok this weekend, here's a rundown of the car; 70 chevelle full tube chassis with funny car cage cert to 7.50, weight ?,
408 iron ls, L92 heads with a mild bowl blend, 16:1 compression, straub hyd roller, edlebrock super vic , rons flying toilet manual fuel injection, glide with brake and 1.80 straight cut gears in a super case, transmission specialties 8" 5900, 9" with 4.86 gears, 32x16-15 goodyears out back.
Cam card is "somewhere", maybe Chris can post if he has time and some of y'all want specs.
Still more tuning to do, gonna run it like it is Friday, might make a change after racing and run that Saturday, then make a change and run that sunday, still have not made a trans brake launch and bottle is still on shelf in the shop.
AND, WE DIDN'T TEAR ANYTHING UP !!!
Sorry, no pics or vids, we will have some this weekend, you have my word, also have go pro coming next week for ride along video, AND so I can look at ALL the gauges at once
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #219 of 282 (permalink) Old May 1st, 18, 6:09 PM Thread Starter
Mac
forgot to mention in above post, runs on methanol, front shocks are set 1 click off of full soft extension and 1 click off full stiff compression, rear shocks are set 2 clicks off of full stiff both ways.....................................CMS again
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #220 of 282 (permalink) Old May 1st, 18, 7:46 PM
Good job Mr & Mrs
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #221 of 282 (permalink) Old May 1st, 18, 8:42 PM
You should be very proud that's a 9.90 runner right out of the box. Very impressive.
post #222 of 282 (permalink) Old May 1st, 18, 10:54 PM Thread Starter
Mac
We appreciate the kind words fellas, got a little to do before this weekend, gotta lower tach so as the steering wheel ring does not go through the middle of it, need a little more adjustment on harness, and some headlights, might even paint it this summer, have not decided on that one yet.
Thanks again.
brodix-rr rec 294
1.56-6.97-99.83
bigmachd is offline
post #223 of 282 (permalink) Old May 2nd, 18, 9:51 AM
Jon
Way to go Mac and crew chief.
72BBMonte is offline
post #224 of 282 (permalink) Old May 2nd, 18, 10:49 AM
Well out of the gate sir you have impressed. Congrats man to the beginning of what should be new best each week. If you want me to post the cam card I will sir.
Chris Straub
Mfg Performance Parts
cstraub is online now
post #225 of 282 (permalink) Old May 2nd, 18, 11:13 AM
Nice! I enjoyed the read. Congrats to you and your crew chief.
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
