345NP pistons - Chevelle Tech
post #1 of 19 (permalink) Old Jan 30th, 13, 10:48 AM Thread Starter
345NP pistons
Anyone know a source for these pistons?
Seems Jegs and Summit are not listing them in the catalog.
Aaron is offline
post #2 of 19 (permalink) Old Jan 30th, 13, 10:55 AM
Davey
Re: 345NP pistons
these?
http://www.jegs.com/p/Sealed-Power/S...44636/10002/-1
Chevelle
SloMo...
'67 Chevelle 516 hyd roller
4.11's
9.06 best mph 147.75
5.73 best mph 119.98
3520 lbs to 3570 depending on fuel
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
crazydavey is offline
post #3 of 19 (permalink) Old Jan 30th, 13, 10:59 AM Thread Starter
Re: 345NP pistons
Yep, that is the line. I was looking them up to put in that vortec thread and saw they only list them for 30 over.
Im curious of they are still listing them for standard bore. They are not listing them if you type in the previous part number of 844-345np.
Aaron is offline
post #4 of 19 (permalink) Old Jan 30th, 13, 11:01 AM
Brandon
Re: 345NP pistons
Here you go, they keep changing the part numbers! This is the STD bore.
http://www.summitracing.com/parts/slp-h345acp
1971 Chevelle (LS Swap in process)
ATK HP ENGINES
Notalent is offline
post #5 of 19 (permalink) Old Jan 30th, 13, 11:03 AM Thread Starter
Re: 345NP pistons
Thats not it.
The ones I listed were about 12 to 15 bucks a piece and were cast.
Aaron is offline
post #6 of 19 (permalink) Old Jan 30th, 13, 11:12 AM Thread Starter
Re: 345NP pistons
I think these are them now.
http://www.summitracing.com/parts/stl-345np
Aaron is offline
post #7 of 19 (permalink) Old Jan 30th, 13, 11:18 AM
Brandon
Re: 345NP pistons
Originally Posted by Aaron View Post
Thats not it.
These are the updated version. Thats $88 a SET = $11 each piston, believe the wer doing away with the cast piston.
ATK HP ENGINES
Notalent is offline
post #8 of 19 (permalink) Old Jan 30th, 13, 11:23 AM Thread Starter
Re: 345NP pistons
Why would they want to stop making them.
They are good and popular!
Aaron is offline
post #9 of 19 (permalink) Old Jan 30th, 13, 12:46 PM
jeff
Re: 345NP pistons
that ZH345ACP they sure talk it up in the description..
I like the fact that they are cut for floating pin also...
Wonder what the weight of those are?
Be nice if they would make a cheap one like that with the thinner ring packs.
I bet the reason to stop the production of the old 345np was the bad rap they probably got when they quit making them here in the USA..
those looked like crap if you seen any of them...the tops had changed also..
more and more people going to the Hyper pistons...
Marketing hype if you ask me..kind of like fluiddamper ballancers..
lot of marketing..but terrible thing for your crankshaft...
I am not saying hypers are terrible ..but detonation and hypers sure do not get along.
So run the hypers and learn to tune basically...
If you are smart enough to replace pistons you should be smart enough to keep the engine out of detonation...
jeff swisher is offline
post #10 of 19 (permalink) Old Jan 30th, 13, 12:51 PM
& Administrator
Re: 345NP pistons
Thats not it.
Flatlander shows them for $14ea.
Mike is offline
post #11 of 19 (permalink) Old Jan 30th, 13, 12:52 PM Thread Starter
Re: 345NP pistons
I talked to Summit and they dont have anymore of them...discontinued.
They had changed the part number to the one I listed earlier.
http://www.summitracing.com/search?keyword=z345np&dds=1
This is the replace they are offering.
http://www.summitracing.com/parts/sum-17350-00
They also said these were replacements
http://www.summitracing.com/parts/slp-wh345acp
Aaron is offline
post #12 of 19 (permalink) Old Jan 30th, 13, 12:56 PM Thread Starter
Re: 345NP pistons
Im not sure those are it either...compression on the chart dont add up.
Aaron is offline
post #13 of 19 (permalink) Old Jan 30th, 13, 1:24 PM
Re: 345NP pistons
They have one P/N that cover 3 different pistons, The new ones are appox 70 grams lighter and the crank should be balanced.
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is online now
post #14 of 19 (permalink) Old Jan 30th, 13, 1:26 PM Thread Starter
Re: 345NP pistons
Carl
Who has one part number?
Aaron is offline
post #15 of 19 (permalink) Old Jan 30th, 13, 2:37 PM
Re: 345NP pistons
Carl
The new P/N is H345ACP which is a hyper, skirt coated and accepts locks for flaoting pins, I think they run me 9.50 a piece.
They are lighter as well so balancing is a must.
Machine shop tour
Monthly Specials
This Thread is more than 2526 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
