OK, My Turn. How Much HP Do You Think My 540 Will Make? - Chevelle Tech
post #1 of 30 (permalink) Old Dec 18th, 12, 8:42 PM Thread Starter
jackie
My new 540 is ready to go over at USA Racing Engines in Houston, (The Wop Shop). All I have to do is take the carb and distributor off of my motor to Bruce so he can put her on the dyno next week.
540 cubes, Dart Big M Block, Air Flow Research full CNC 290 Heads, RPM Performer intake, port matched to heads, Edlebrock 800 carb, Hyd Roller, .675 lift, 234-238 at .050, 10 to 1 compression, zero deck, deck plate honed, Morel Lifters, Comp Cams Magnum Pro Rockers, everything assembled to the highest standards.
My goal is a big inch, hard hitting street engine that will run on what's in the pump, idle at 800 with 16 lbs of vacuum, have the torque come in quick and stay flat, and be perfectly compatible with my TCI 6X 6Speed Auto and 3,31 gear, reving to around 6500.
What do you all think?
jackie schmidt is offline
post #2 of 30 (permalink) Old Dec 18th, 12, 9:29 PM
Re: OK, My Turn. How Much HP Do You Think My 540 Will Make?
I don't know but that looks like a very well thought out combo for what you want. I hope you have plenty of money set aside for tires. Am looking forward to see what it does on the dyno. Gonna be alot of fun.
69ttop502 is offline
post #3 of 30 (permalink) Old Dec 18th, 12, 9:32 PM
Think you will come in around 650hp at 5600. With the dual plane, 800 carb and 234 intake lobe, will be interesting to see if power holds on much over 6000. JMHO
Status: Car-Less
GRN69CHV is offline
post #4 of 30 (permalink) Old Dec 18th, 12, 10:03 PM Thread Starter
jackie
I think you are right, I am hoping that the top HP comes in at a flat 6000, that is what I was shooting for with the head-cam combo.
I have a Victor jr intake, and a 950 carb, but it won't go under the hood with a large enough air cleaner to feed the beast.
The engine in the car now really gets my attention when I nail it through the gears. I am hoping the 540 scares me
post #5 of 30 (permalink) Old Dec 18th, 12, 11:20 PM
Jon
672hp at 5800 rpm
697 tq at 4400 rpm
72 Monte Carlo (3865 lb Street/sStrip Orange Monster)
6.09/113.75 mph 1.32 60 ft.
9.634/141.50 mph-best pass
79 Trans Am Super Street, Top Eliminator, Super Pro , Quick 16, Hot Rod
5.25 eighth mile
8's quarter mile
72BBMonte is offline
post #6 of 30 (permalink) Old Dec 18th, 12, 11:49 PM
That is going to be a torque monster. I really wonder if you're going to get enough air with the intake and that carb past 6000 rpm. Im going to agree with Joe, but I do think it's going to make like 700 ft lbs though. The torque at like 3000 rpm is going to be insane.
-SS454- is offline
post #7 of 30 (permalink) Old Dec 19th, 12, 1:00 AM
Ron
665hp
690tq
69 Camaro
491/AFR 315/Straub hyd roller/pump 91
TH400/GV OD/9" 3.50's/ 255/60/15 DR
10.86 at 124.8
3670 with driver
dirtlips408 is offline
post #8 of 30 (permalink) Old Dec 19th, 12, 6:17 AM
We never ran mine on a dyno, used the Rerher Morrison Street 540 as an example of the motor we built though. RM advertises [email protected], running Dart 310 head, single plane and a 244/254, .650, 114LSA cam. Few years back Jim dyno'd the 555 with hyd roller and tipped into the low 700's with a cam in the mid 250's. You run it and see what it does. Might be spot on for what you want. I think the intake will support it to 6000, just think the cam may need another 10* duration. These big motors just seem to swallow cam duration.
Status: Car-Less
GRN69CHV is offline
post #9 of 30 (permalink) Old Dec 19th, 12, 6:38 AM
Darren
I think you have a great street engine there, should be in the mid-600 range as far as HP, but IMO with the relatively small cam (for the displacement), carb and intake combo I think it will be done by 6k rpm.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems Venom VX 1050
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Moser axles
30x12.5 ET Street Radial
525+++ rwhp
71454Chevelle is offline
post #10 of 30 (permalink) Old Dec 19th, 12, 8:01 AM
Vince
I think that's a perfect street motor, and the cam is a nice choice for the street. Although these big motors do swallow cam, the dont seem to swallow all the bigger cam negatives as well. That motor will likely see 6000 rpms <5% during its use, so cam, air cleaner size, etc wont really be an issue.
Let's talk about that carb though...
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is offline
post #11 of 30 (permalink) Old Dec 19th, 12, 9:39 AM
yea the carb is going to be the problem, its gonna pull lots of vacuum in the upper rpm. with your cubes.
borrow a 1000 or dominator from Bruce to see what it does.
I'd also do a single plane to kill off some low end tq and help power.
I can see 650hp & 700tq, if everything is right.
67 camaro:
420 - 641hp HRcam 1.39, 9.79 @ 137.5
502 - 626hp 252/263HRcam 1.44, 10.08 @ 132.7
62 Nova
383/200-4R/12-bolt w 373s
224/224 HR cam
1.57 10.97 @ 121.2
69 chevelle 350, 200-4R 411s [email protected] (sold)
67RS502 is offline
post #12 of 30 (permalink) Old Dec 19th, 12, 10:43 AM
Brandon
Intake/Carb will bring the numbers down a bit IMO...but a great street engine for sure....cant hook that much power on the street anyways haha
640HP @5700 RPM
670TQ @4600 RPM
1971 Chevelle (LS Swap in process)
ATK HP ENGINES
Notalent is offline
post #13 of 30 (permalink) Old Dec 19th, 12, 12:34 PM
Davey
Originally Posted by 72BBMonte View Post
672hp at 5800 rpm
697 tq at 4400 rpm
^^^^this....
Chevelle
SloMo...
'67 Chevelle 516 hyd roller
4.11's
9.06 best mph 147.75
5.73 best mph 119.98
3520 lbs to 3570 depending on fuel
1.26 60 ft
Straub/Foxwell
Motor by Mark Jones
E-Store at
crazydaveyracing.com
Davey..
TC Gold Level Know it All
crazydavey is offline
post #14 of 30 (permalink) Old Dec 19th, 12, 4:24 PM
Willem
It'll be civilesed at part throttle/cruise, especially with that transmission.
But its gonna be torque city when you hit the loud pedal!
Helmet is offline
post #15 of 30 (permalink) Old Dec 19th, 12, 5:09 PM
I'm afraid your going to have a serious case of the Go Fast!
660HP
680TQ
1971 Chevelle Triple Black
VortecPro 496, 9.8:1 comp. 049 heads 2.25/1.88 valves, [email protected] Isky Hyd Roller, Eddy Air Gap, Holley HP1000, Doug's D316 Headers, Hughes TH400, ATI converter, GM 12 Bolt, 3.42 Posi, SEE DYNO VIDEO
Indiansprings is offline
This Thread is more than 2572 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
