Vortec Roller Block 383 Build? - Page 3 - Chevelle Tech
 5Likes
post #31 of 33 (permalink) Old Nov 4th, 16, 4:30 PM
Re: Vortec Roller Block 383 Build?
Originally Posted by CNC BLOCKS N/E View Post
The Mexican castings are not a 170 runner like GM advertises. I really doubt those heads are flowing 227 CFM at .050 lift ( 50 thousands lift ) Not even at .500 lift they will not flow that much.
They were on a calibrated flow bench operated by a reputable shop. My Mexican castings flowed that much (we only checked one cylinder). Maybe not all Mexico heads are created equal?
novadude is offline
post #32 of 33 (permalink) Old Nov 4th, 16, 8:06 PM
p40
butch
Originally Posted by Dave427 View Post
450 hp should be easy to get.
The GM Hot cam would not suit your build.
Look at the cam they use in the ZZ383 it would be better.
Camshaft lift (in): .509 intake / .528 exhaust
Camshaft duration (@.050 in): 222'c1 intake / 230'c1 exhaust
I would use a 3000 stall and a Holley 750 Street HP
dont think its going to be 450 with that set up. iv got 383 with 11 to 1 comp, 555 lift 306 dur cam, dart pro1 heads 200 cc, victor jr and 850 holly only putting out 425 at flywheel
p40 is offline
post #33 of 33 (permalink) Old Nov 5th, 16, 4:08 PM
CC The intake runners and you will find they are around 158/159 and they will not flow 227 CFM and every one of the Mexican castings I have seen have small runners.
Even the non- Mexican 170 runner heads did not flow 227 CFM from what I have seen !!!
Calibrated to what !!!
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is offline
This Thread is more than 1176 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
