Vizard's adv overlap chart corrected for displacement - Chevelle Tech
post #1 of 3 (permalink) Old Nov 2nd, 07, 4:58 PM
540 RAT
Guest
Posts: n/a
The original thread on this topic was getting long in the tooth, so I went for a fresh one.
There were comments from some who said Vizard's chart should be setup for displacement, since a general chart makes no sense. I agree, so I did some simple math to do just that. Check it out:
Comparing the chart I made from real world engines, for the beginning of the truly bad mofo lope/chop (middle chart), to Vizard's original chart (immediately below), you can see that his chart matches up nicely for a solid roller 540ci motor at the top of the street/strip range, which makes sense:
Vizard's original chart:
10* - 40* towing
30* - 60* ordinary street
50* - 75* street performance
70* - 90* street/strip
85* - 100* race
95* - 115* Pro race
Min. solid roller adv overlap for that bad mofo lope/chop:
350ci………..77*
383ci………..78.5*
400ci………..80*
454ci………..84*
496ci………..87*
540ci………..90*
572ci………..92*
632ci………..96.5*
So then, matching up the lope/chop chart, with the top of the street/strip range for other displacements, and adjusting all other numbers by the same percentage as the original chart, you get the original chart adjusted for displacement, so………...
For a 383ci small block roller motor, you get:
9* - 35* towing
26* - 52.5* ordinary street
44* - 65.5* street performance
61* - 78.5* street/strip
74* - 87* race
83* - 100* Pro race
The same idea could be carried out for any displacement. Of course, the real world has a lot of gray areas, but the range overlaps try to take that into account. Though these charts may not be perfect, they do give you a general idea of what to shoot for, as opposed to only guessing.
post #2 of 3 (permalink) Old Nov 2nd, 07, 6:29 PM
pdq67
Guest
Posts: n/a
Re: Vizard's adv overlap chart corrected for displacement
May I add...
It's the point where the intake valve closes w/ respect to where the piston is in the cylinder that set's all this, imho
So therefore rod length play's a slight role in this too!
This is why short rod, long stroke engines can use a slightly bigger cam than a longer rod engine of like displacement. B/c the piston will be deeper in the cylinder at intake valve closing! (Or do I have this back-as-wards?)....
pdq67
post #3 of 3 (permalink) Old Nov 2nd, 07, 7:07 PM
Originally Posted by pdq67 View Post
May I add...
pdq67
Overlap is far away from the intake valve closing point. It's at the end of the power stroke, while the intake closes at the beginning of the compression stroke.
onovakind67 is offline
This Thread is more than 4396 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
