Tall Valve covers and Brake booster (70) - Chevelle Tech
post #1 of 25 (permalink) Old Jun 25th, 07, 1:24 AM Thread Starter
Danny
Send a message via AIM to bluechevelless Send a message via Yahoo to bluechevelless
Will tall valve covers fit with a stock brake booster on a 70? I will be running a solid drivers side mount also so it shouldnt move much. I just installed roller rockers on my car and they are hitting the drippers in my vintage M/T valve covers and I dont want to cut them off.
1970 Chevelle SS 396
Originally Mist Green
Dark green Interior
AC PW PL
bluechevelless is offline
post #2 of 25 (permalink) Old Jun 25th, 07, 1:28 AM
Dave 383 now
Re: Tall Valve covers and Brake booster (70)
The valve covers will fit under the booster, but removing them can be a real chore. On my friends 69 Chevelle we took a booster off like a Sunfire or Cavalier. Then we took the brackets off the old booster and put on the new booster. We had to fab up a push rod off the brake pedal its a little different.
Dave427 is offline
post #3 of 25 (permalink) Old Feb 8th, 08, 3:32 PM Thread Starter
Danny
damn they dont fit, Im gonna have to find something else on a brake booster now...
Dark green Interior
AC PW PL
post #4 of 25 (permalink) Old Feb 8th, 08, 4:16 PM
I got my booster from MP Power brakes it was plated but I painted it black
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #5 of 25 (permalink) Old Feb 8th, 08, 4:34 PM
Danny. Did you try the double gasket trick with your M/T's?
Which tall covers are you using.
I'm using these. click part #555-50166. They clear rollers and Girdle, and have about an inch between them and my booster. Take quite a bit of fanageling to get the left one on but it does fit.
SCOTT
TC #3238
ACES #7490
To secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
The Declaration of Independence
furball8994 is offline
post #6 of 25 (permalink) Old Feb 8th, 08, 5:40 PM
how hard would it be to take a valvecover(alum) and cut it the long way..
mill in a reciever groove for a o ring like gasket
then make a bolt system. to hold the two halfs together ..
then you can unbolt it. and take it off..
can't be that hard with the manufactured(build) valvecovers that outfits sell..
bowtie6872 is offline
post #7 of 25 (permalink) Old Feb 8th, 08, 11:17 PM
Guys switch to hydroboost. It is a very small compact unit, not bigger then the master cylinder and easily twice as powerful as that weak vacuum unit. It runs off the power steering pump, cheap to pick up at the wrecking yards and very very powerful
norvalwilhelm is offline
post #8 of 25 (permalink) Old Feb 8th, 08, 11:32 PM
Walter
I am actually doing that. The short block is out for machining right now. While I am putting in a new motor, I am converting to hydroboost. I am having hoses made right now. Looking forward to all being done.
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 4000 Stall/4.11 12 Bolt
wildman926 is offline
post #9 of 25 (permalink) Old Feb 9th, 08, 1:23 AM Thread Starter
Danny
I didnt like my M/T covers, Im more into shiny stuff and I really dont want to double gasket them. The covers I have are some tall polished aluminum ones, no brand or part number on them so I dont know, I got them from a friend for $30 bucks with rubber gaskets and 2 moroso red breathers. They look exactly like these
http://cgi.ebay.com/ebaymotors/BBC-T...spagenameZWDVW
Dark green Interior
AC PW PL
post #10 of 25 (permalink) Old Feb 9th, 08, 1:40 AM
Yep,me too. But I bought a new set-up from CPP. Below is the link. I haven't installed it yet though. But I hear good things about them, and they do take up less space.
http://www.classicperform.com/NewPro...HydroBoost.htm
BillyGman is offline
post #11 of 25 (permalink) Old Feb 9th, 08, 1:42 AM
They are the same shape as my billet specialties without the engraving new they are about 169.00
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #12 of 25 (permalink) Old Feb 9th, 08, 2:25 AM
These are the valve covers i'm using on my 632 tall deck motor with a stock brake booster.
http://store.summitracing.com/largei...um-g3313_w.jpg
70 SS LS-5 is offline
post #13 of 25 (permalink) Old Feb 9th, 08, 3:16 AM Thread Starter
Danny
well got any pics? Im running the original frame pads, solid drivers side mount and a rubber passengers side mount.... My header gets into the steering shaft since the engine sets so low. With my M/T covers I have about 1" to 1-1/4" of clearance between brake booster and cover top.
Dark green Interior
AC PW PL
post #14 of 25 (permalink) Old Feb 9th, 08, 3:54 AM
If you're referring to me, I don't have a picture of it in the car. The motor is back out of the car right now so I can finish up some of my bodywork stuff. When I had the motor in the car I didn't try to take off the valve cover but it looked like there was enough room to do it. The valve covers I used are tall, but not as tall as some others like the Edelbrock Elites. Here's a picture of the motor out of the car with the valve covers on it.
These valve covers only come with one hole in each cover so I had to drill out an extra hole in the passenger side valve cover for the oil fill plug.
They're really nice valve covers and only $85 at that.
post #15 of 25 (permalink) Old Feb 9th, 08, 12:16 PM Thread Starter
Danny
are you sure your using an 11" booster? cause mine didnt even come close to fitting, I think itll still be close with a 9" booster
Dark green Interior
AC PW PL
This Thread is more than 4386 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
