regular headers work with a tall deck engine? - Chevelle Tech
 9Likes
post #1 of 17 (permalink) Old Jan 30th, 07, 5:09 PM Thread Starter
Hoarder Deluxe
I am looking at a tall deck 427 engine that is for sale and I am considering buying it to put in a chevelle or nova. Will standard deck headers work and just be closer to the floor, or are special headers needed? This is a supposedly performance built engine, are there aftermarket forged pistons for these engines or just the factory style heavy 4 ring style?
66/68/70 chevelles
55/57/61 belairs
69 70 71 72 novas
37 Buick 47 Cadillac 51 Ford F1s
other money pits and projects
drptop70ss is offline
post #2 of 17 (permalink) Old Jan 30th, 07, 5:30 PM
paul
Re: regular headers work with a tall deck engine?
the answer depends on the car its used in,and the brand and part number of the headers used, even the cylinder heads, effect the results as some heads have the exhaust ports raised as much as 7/8" higher on the heads in relation to the block deck even on a standard block, Ive had standard headers fit with zero problems Ive also had them be totally un-useable, and its not just the floor to collector clearance at times its the stearing/suspension or frame , even the starter or oil filter or clutch linkage that became the problem.
if youve got a decent welder and some fabrication skills most problems are reasonably easy to work around, but you may want to build custom headers in some cases.
Im sure your aware that there header flanges and collectors available in kits to build your own custom headers and that you can cut/splice and recoat standard headers
GRUMPYVETTE is offline
post #3 of 17 (permalink) Old Jan 30th, 07, 6:16 PM Thread Starter
Hoarder Deluxe
This engine has factory style oval port heads so the exhaust port will be as normal, I am just wondering how much wider the engine will sit compared to a regular passenger engine, not sure how much extra room there is in a chevelle chassis for the bigger engine with headers.
My biggest concern is the pistons, the seller really doesnt know what parts are in the engine, only that they are forged pistons according to him..so I am just wondering if there are aftermarket pistons for this engine or just the factory ones..and if the aftermarket ones would need a longer rod to be used. Would a regular 427 piston work just by using longer rods?
66/68/70 chevelles
55/57/61 belairs
69 70 71 72 novas
post #4 of 17 (permalink) Old Jan 30th, 07, 6:31 PM
paul
the correct rod length depends on the deck height and piston compression height and stroke of the crank, normally tall deck blocks use a differant tall piston,you can use stock 427 low deck pistons WITH a longer than standard connecting rod in the tall deck block, you need to know 2 of the three to find the third, heres some calculators to play with, keep in mind the tall decks 0.4" taller deck, ie 9.8" vs 10.2" so if a standard deck piston for a 427 with its 3.76" stroke and 6.135" rod are used the added 0.4 " taller bore and the rod needs to be 6.535" or .4" taller
1/2 stroke plus rod center to center length plus compression height should be very close to deck height
http://www.kb-silvolite.com/calc.php?action=piston_comp
http://www.kb-silvolite.com/calc.php?action=deck
http://www.newcovenant.com/speedcraf...ssionratio.htm
http://www.kb-silvolite.com/forged.p...VY&EngSize=427
427L88 likes this.
post #5 of 17 (permalink) Old Jan 30th, 07, 6:32 PM
Dave...I have heard of a guy that runs a tall deck block in a 71 Elky, and has no clearance issues at all. Mr 4 speed knows who it is, maybe he will chime in. Im not sure about the pistons, but I looked into it one time past, I believe there are quite a few available. I have the name of a guy I know who has built several tall decks....if I can dig up his email, I'll pm it to you. John
The difference between intelligence and apathy?
I have no idea, and I couldnt care less.
Johnny O is offline
post #6 of 17 (permalink) Old Jan 30th, 07, 7:05 PM
Javier
Hi Dave , Johnny O is correct I am running one in a 1971 gmc sprint same as el camino with no clearance issues ,please read this old post .
https://www.chevelles.com/forums/showthread.php?t=159317
Ask all question before building one , I also got a Cowl hood with RPM AIR GAP with two 1/2" each spacers
71 GMC SPRINT
new 496, still tuning
11.44
1.56 60ft
116.8 mph
all steel car
HPseeker is offline
post #7 of 17 (permalink) Old Jan 30th, 07, 8:02 PM Thread Starter
Hoarder Deluxe
Thanks for the info guys, let me see how it goes, I should know by the end of the weekend if I end up with it.
66/68/70 chevelles
55/57/61 belairs
69 70 71 72 novas
post #8 of 17 (permalink) Old Jan 30th, 07, 10:05 PM
I just picked up a tall deck block, brand new, prepped at 4.310 bore. Probably going to build it as a 6.8" rod 496 motor. Not sure what it's going in yet, but it was so reasonable I couldn't pass it up.
Status: Car-Less
GRN69CHV is offline
post #9 of 17 (permalink) Old Jan 31st, 07, 12:29 PM
A few months ago, I installed a set of Hooker Super comp headers ( the set with 2 1/8" primary tubes and 3.5" diameter collectors) into my 70 Chevelle with a tall deck 632 inch motor. The Passenger side only had to be dimpled with a ball peen hammer in one place for starter clearence ( and that was with a mini-starter at that), but the driver's side header had to be dimpled in five places to clear the frame, steering shaft ( on cylinders #3 and #5) and on cylinder #7 for control arm cross shaft nut clearence.
The steering shaft was the biggest obstacle.But I don't think that you engine will need the 2 1/8" primary tube diameter, so you can probably get the smaller Hooker headers and you might not have to dimple them as much as I did. I suspected that the tops of the collectors would be hitting the floor boards too, but on my car, they didn't, so that wasn't an issue.
BillyGman is offline
post #10 of 17 (permalink) Old May 24th, 20, 10:30 PM
What cylinder heads did you run on that 632?
408chevy is offline
post #11 of 17 (permalink) Old May 24th, 20, 11:23 PM
If you paid attention to your geometry and trigonometry classes in school, you'd know this is easy to figure out. Block is a 90 V, that makes each bank 45 relative to the centerline drawn between the crankshaft and the camshaft.
We know the block is getting .400" taller at a 45 angle, so we can use basic Pythagorean theorem of A + B = C, and the 45 bank angle means we can work from an equilateral triangle. This means A and B are equal to each other, and the hypotenuse (C) is .400", or .16.
Half of .016 is .08, so A and B both equal .08.
Square root of .08 = √.282842"
Head moves up relative to the ground .283", and outward relative to cam/crank centerline by the same .283" with the tall deck block.
Blown1932 likes this.
Ericnova72 is offline
post #12 of 17 (permalink) Old May 25th, 20, 12:27 AM
Rod
13 year old thread!
davewho1, 1968 and BillyGman like this.
Rmchevelle is offline
post #13 of 17 (permalink) Old May 25th, 20, 2:58 AM
Pete 67, rp930 and 1968 like this.
David
davewho1 is offline
post #14 of 17 (permalink) Old May 25th, 20, 5:12 PM
oldie but goodie. kinda nice to see somebody doing the math. I'd round off those numbers to .300 both ways.
Tom Mobley is online now
post #15 of 17 (permalink) Old May 25th, 20, 6:19 PM
Originally Posted by Rmchevelle View Post
13 year old thread!
Yeah!!! What the heck???? I just wrote a two paragraph reply thinking that I'm helping the guy out!!! LOL Thanks for pointing out the expiration date of this obsolete thread, because I definitely wasn't even looking at that!!!
Well it also looks like someone rounded off the original thread date by 300 months.
shovelrick likes this.
tall deck b/b headers forcd ind 2006 5 Feb 27th, 06 7:57 AM
tall deck big block questions greg_moreira 2005 3 Jun 21st, 05 7:23 AM
tall deck big block questions greg_moreira 2005 0 Jun 20th, 05 9:00 PM
Tall deck block performance questions Chevy454 2004 4 Jun 25th, 04 2:49 PM
Engine Frame Mounts - Headers Still Wont Fit !!! David Host 1999 -- 5 Jun 25th, 99 6:47 PM
