496 Compression build results.... - Chevelle Tech
 8Likes
  • 8 Post By cstraub
post #1 of 7 (permalink) Old Jul 31st, 20, 5:26 PM Thread Starter
Ported Dart Tunnel Ram By Foxwell Motorsports
AFR 301 Porters Castings with Straub VEPR335 CNC Port by Foxwell
Ti Intake and Stainless Exhaust Valves
Straub Custom Solid Roller Camshaft for Salt Flats Racing
Morel Lifters
Jesel Shaft Rockers
14 to 1 496 CID Short Block
Without Vac Pump
930HP at 7700
676#/ft at 6000
With Vac Pump
966HP at 7900
687#/ft at 6900
Will post sheets next week.
DragRacer, 66rat, 427L88 and 5 others like this.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #2 of 7 (permalink) Old Jul 31st, 20, 6:29 PM
Re: 496 Compression build results....
Impressive numbers!! Out of curiosity, how much would say 10.5:1 compression change the numbers
dell72 is offline
post #3 of 7 (permalink) Old Aug 1st, 20, 1:39 PM
Jason
What carbs? Ring package? BBC cam journals? .903 lifters?
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3370 lbs
1.36 - 60', 5.93 @ 116.7 MPH - 1/8th
DragRacer is offline
post #4 of 7 (permalink) Old Aug 3rd, 20, 2:09 PM Thread Starter
Down 120HP.
Chris Straub
cstraub is offline
post #5 of 7 (permalink) Old Aug 3rd, 20, 2:13 PM Thread Starter
Shelf Stock JE Piston short block built by customer, 1/16 1/16 3/16". Std bbc cam size. .842" lifters. Will have to get info on carbs.
Chris Straub
cstraub is offline
post #6 of 7 (permalink) Old Aug 3rd, 20, 2:57 PM
What was the lobe separation and what was the intake centerline?
sleeper is offline
post #7 of 7 (permalink) Old Aug 3rd, 20, 3:06 PM Thread Starter
Originally Posted by sleeper View Post
what was the lobe separation and what was the intake centerline?
113 lsa
110 icl
Chris Straub
cstraub is offline
