Pump Gas 555 4.560 x 4.250... - Chevelle Tech
 16Likes
post #1 of 16 (permalink) Old Jul 31st, 20, 5:21 PM Thread Starter
BBC 555, 4.560 x 4.250" combo, AFR305 heads and Eddy 454R with port work. Custom Straub Solid roller, .690/.650 net.... 257/267 on a 108 with Morel Ultra Pro .842 Lifters. Customer wanted 750HP using pump gas, 10.9 to 1, and some octane booster. Was told he had to sell the AFR305 and get bigger heads. I told him no, keep the heads put a 2.300 intake and blend work, engine builder, Valley Performance Research, did the head work.
Going in a jetboat, but would make a nice street engine.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #2 of 16 (permalink) Old Jul 31st, 20, 7:51 PM
Lew
Re: Pump Gas 555 4.560 x 4.250...
Chris what would engine have done on say a 112 or so lobe separation for a little better idle characteristics.
Lew540 is online now
post #3 of 16 (permalink) Old Jul 31st, 20, 8:22 PM
What size carb?
sleeper is offline
post #4 of 16 (permalink) Old Jul 31st, 20, 11:24 PM
Spike
Sweet!
USMC_Spike is offline
post #5 of 16 (permalink) Old Aug 1st, 20, 3:27 AM
Darren
Very nice build Chris. By chance do you have the flow numbers after the head work? Does the 2.300" valve really make that much difference with these 540+ motors? What header size were you using? Thanks in advance.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems Venom VX 1050
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Moser axles
30x12.5 ET Street Radial
525+++ rwhp
71454Chevelle is offline
post #6 of 16 (permalink) Old Aug 1st, 20, 11:54 AM
Chris as usual nice work, motor will rip.
While I never have had Stubb’s motor on a dyno I suspect it would look very similar.😉
B433 is offline
post #7 of 16 (permalink) Old Aug 1st, 20, 12:58 PM
I was thinking how this sounded similar to your engine
dell72 is offline
post #8 of 16 (permalink) Old Aug 1st, 20, 5:45 PM
B433 is offline
post #9 of 16 (permalink) Old Aug 3rd, 20, 2:04 PM Thread Starter
My way of doing things, LSA is a sum of numbers....it is what it is. I try to satisfy demand by controlling the supply of air in and out with the events needed to open and close the valves. This is all done with math. I've got stuff that idles quite well on tight LSA's.
horton409 and pannetron like this.
Chris Straub
cstraub is offline
post #10 of 16 (permalink) Old Aug 3rd, 20, 2:05 PM Thread Starter
Originally Posted by sleeper View Post
What size carb?
Dominator 1050 modified to a 1450.
Chris Straub
cstraub is offline
post #11 of 16 (permalink) Old Aug 3rd, 20, 2:07 PM Thread Starter
Don't have the numbers handy. Yes the 2.300 valve does help and it is even limitation at a given rpm range with a given CID. You never want the intake valve to be your restriction.
Chris Straub
cstraub is offline
post #12 of 16 (permalink) Old Aug 3rd, 20, 2:08 PM Thread Starter
I would say yes Brian.
Chris Straub
cstraub is offline
post #13 of 16 (permalink) Old Aug 3rd, 20, 4:21 PM
Could similar results be had from a pump gas 540, Im looking for more power out my AFR 305 headed pump gas program.
dell72 is offline
post #14 of 16 (permalink) Old Aug 4th, 20, 5:44 AM
Darren
Chris, what size headers did you use?
Darren
1971 Chevelle
496
10.5 scr
525+++ rwhp
post #15 of 16 (permalink) Old Aug 4th, 20, 9:33 AM Thread Starter
Yes, without question.
Chris Straub
cstraub is offline
