Poly lock issue - Chevelle Tech
 6Likes
post #1 of 26 (permalink) Old Jul 11th, 20, 9:33 AM Thread Starter
Tyler
Poly lock issue
Can one of you explain why this is happening?
ID:	632654   Click image for larger version
Chebell is offline
post #2 of 26 (permalink) Old Jul 11th, 20, 1:29 PM
Mr Bill
Re: Poly lock issue
How about a picture of the cylinder head with the polylocks on it ? Is the valve lash correct ? Almost looks like the rocker arm has been bouncing up and down and hitting the polylock ????
More details would help to. What engine ? Cam ? Spring pressures ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #3 of 26 (permalink) Old Jul 11th, 20, 4:58 PM
Re: Poly lock issue
Installed with the round side of the roller bearing trunnion facing up, instead of down??
Someone on another board posted a lock that looked identical to that and he had put the roller trunnion on the stud upside down, so the poly lock wasn't on it's flat seat and was up against a curve surface....It looked just like that and had polluted the bearings in that rocker enough to make it stiff. to rotate.
Cheap grade of nuts without the proper hardening would be another possibility.
Look familiar?
Ericnova72 is offline
post #4 of 26 (permalink) Old Jul 11th, 20, 5:09 PM
Re: Poly lock issue
Originally Posted by Ericnova72 View Post
.....Cheap grade of nuts without the proper hardening would be another possibility.
That's what I was thinking too. I only use ARP brand for that reason.
BillyGman is offline
post #5 of 26 (permalink) Old Jul 11th, 20, 6:22 PM
Kerry
Re: Poly lock issue
If you have the trunions facing the correct way, side with the recess/flat surface up, then get a new set of knows quality locks. ARP.
pockets is offline
post #6 of 26 (permalink) Old Jul 12th, 20, 6:32 AM Thread Starter
Tyler
Thanks guys, yes they are correct with the flat surface up. These are a couple pictures I took just before it went in. Ironically it is right there (#2) that looks the worst. The studs should certainly be a little longer with less threaded area but anyway these are the pictures I have, didn’t take any of the assembly before I tore it apart.
ID:	632712   Click image for larger version
Chebell is offline
post #7 of 26 (permalink) Old Jul 12th, 20, 6:39 AM Thread Starter
Tyler
If memory serves open pressure is right about 320 pounds. Rpm performer cam, solid lifters. I had the lash set at .014 int/.016ex cold.
Chebell is offline
post #8 of 26 (permalink) Old Jul 12th, 20, 6:54 AM
Re: Poly lock issue
I thought the Edebrock performer rpm cam was a hyd cam? Damage may be due to using solid lifters on a hyd cam
77 camaro,
400 build-up in progress
400 0.030 over, AFR 195 heads 68cc chambers, SRP 16cc dish pistons, Scat I-Beam rods 7/16 bolts, Scat 9000 cast crank, Crane 296 hyd roller cam, hooker 1 3/4 headers, Holley 750, Richmond 4.10:1 gears
400sbc is offline
post #9 of 26 (permalink) Old Jul 12th, 20, 7:15 AM Thread Starter
Tyler
Yes, it is a hydraulic cam and I have solid lifters on it. If you have been seeing any of my posts you’ll see that I’ve had one hell of a time with Lunati cams......so long story short, after all the carnage, what I had laying around was this cam that was never ran and a new set of solid lifters. It was explained to me, and please correct the story if it’s wrong, that you can run solid lifters on a hydraulic cam but not so much the other way around due to the ramp profile. Just one issue would be a lash spec not being out there so I’ve been playing with that. I figured at this point I’ve spent so much it was worth a shot, if it blows apart I’ll just start over and go a totally different direction.
Chebell is offline
post #10 of 26 (permalink) Old Jul 12th, 20, 7:18 AM
rick
Re: Poly lock issue
It looks like the rocker arm is touching the top of the spring & retainer or maybe I just cant blow the pic up enough but could that cause issues ?
shovelrick is offline
post #11 of 26 (permalink) Old Jul 12th, 20, 7:28 AM
Re: Poly lock issue
Good catch. Yes it does look that way. Makes me wonder about those rocker arms, as well as the valve spring diameter used.
post #12 of 26 (permalink) Old Jul 12th, 20, 7:32 AM
Re: Poly lock issue
I thought that is only for using solid rollers on a hyd roller cam but I could be wrong
77 camaro,
400sbc is offline
post #13 of 26 (permalink) Old Jul 12th, 20, 7:38 AM
rick
Re: Poly lock issue
I thought the same, solid rollers on hyd. roller cams, my engine builder (mach. work & rotating ass. only) wanted to do that with mine.
post #14 of 26 (permalink) Old Jul 12th, 20, 8:04 AM Thread Starter
Tyler
No evidence of spring/rocker interference. I made sure to get the correct rockers so that wouldn’t happen, I’ve looked close and don’t see any witness marks. Maybe I got the solid/hydraulic thing backwards. What would have a slower “take up” ramp? I suppose it could be “pounding” them up as opposed to “pushing” them up.
Chebell is offline
post #15 of 26 (permalink) Old Jul 12th, 20, 9:19 AM
Re: Poly lock issue
I think when running solids on a hydraulic cam you typically run tight lash, like 0.006”-0.008” hot. If the rocker trunnion doesn’t have enough engagement on the shank or the stud it might be dancing around a bit.
71350SS likes this.
Roadknee is online now
