Dynoed my 532 today - Chevelle Tech
 25Likes
post #1 of 29 (permalink) Old Jul 9th, 20, 11:36 PM Thread Starter
Gary
Dynoed my 532 today
Ran my 13.5 to one 532 today . It made a best of 917 at 7100 with my 2.125 headers into a 4 inch merge collector with a 3.250 pinch and around 8 inches of collector length. I knew this was too small for this engine.these were the headers that were on the old 505. The engine made 944 hp with 2.25 to 2.375 dyno step headers and 4.5 inch collectors at 7700 and was 20 up at the previous 7100. These are admittedly too big for this engine. We also had to add quite a bit of fuel with the bigger headers as the AFR went to 14 and 1/2 to 1 with the extra air flow. Guess I'm going to have to build some new headers. Prob 2.125 to 2.250 step or 2.250 primaries. Been meaning to buy the pipe Max program although I'm still using the stock front frame in this car which makes it challenging to package the dimensions they will call out
gnicholson is offline
post #2 of 29 (permalink) Old Jul 9th, 20, 11:39 PM
Re: Dynoed my 532 today
That's a pretty sizable gain with the headers. Did it lose any torque down low?
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #3 of 29 (permalink) Old Jul 9th, 20, 11:50 PM Thread Starter
Gary
The printer quit working and all I have is the last Dyno sheet but it basically was at least as good from around 6000 RPM which is about the stall speed of the converter. Should have all the copies tomorrow so I can study at a little bit more
post #4 of 29 (permalink) Old Jul 10th, 20, 6:42 AM
Guy
917 HP from 532 CI = 1.72 HP/CI
Very good numbers indeed !!!
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZ-Roll "Helix" Solid Roller Lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #5 of 29 (permalink) Old Jul 10th, 20, 7:33 AM
Jarad
Very nice numbers. How'd it carry past 7700? Bet it sounds good!
JBoggs is online now
post #6 of 29 (permalink) Old Jul 10th, 20, 8:00 AM
Those are some nice numbers. I ran 2 1/4 headers on my car with the stock frame, but I didn't have them made to any dimension. The driver side was made to fit in the chassis and the passenger side was copied to keep them equal. I had 1 tube go outside the frame on both sides. My friend had Lemons headers in his car and those had 2 go outside the stock frame.
Ray
bracketchev1221 is online now
post #7 of 29 (permalink) Old Jul 10th, 20, 10:13 AM
Lew
Sometimes it is a balance of what works fine and what works perfect along with just plain good fit vs bad fit. Also are you running an exhaust which also changes things. After having numerous set of headers I have determined unless you are all out racing it is not worth the hassle of: burned spark plug boot thus creating an electrical arch with header, having to take headers partially or all off to take oil filter out, burning starter solenoids all the time because the header tube is too close, removing the starter is next to impossible without pulling the header off, spending 20 minutes to take one plug out because it is easier than removing the headers, no power brakes because the number 5 tubes goes way up and over, leaks from the old tube over the frame connection, oh yes - how can we forget the steering column clown show, the headers are so low I cant go over speed bumps and when you do you hear it and the header tube dent-o-rama to get it to fit messing up you nice Jet Hot coating. I am sure I might be missing a few. In summary (if not a race car) it may not be worth the 20 hp to have a bunch of this going on.
Lew540 is offline
post #8 of 29 (permalink) Old Jul 10th, 20, 10:31 AM Thread Starter
Gary
I should have been a little more specific. This engine is 4 MI 70 Chevelle drag car that I generally use for NHRA Super Street. It had a 505 that generally ran 137 138 mph with a throttle stop. It would probably go 141 or so wide open and run 9.30. I was trying to get another five miles an hour or so without so much torque that it becomes inconsistent which is why I went with the 4-inch stroke 532. Those 30 hp more with the big headers are worth another 2 mph. I had lemons headers on it that I ended up making a couple of tubes and some different merge collectors and they work great on the 505 think I'm going to need some 2 and 1/4 tubes if I want to get all the power out of this thing
427L88 and Jebchevelle like this.
post #9 of 29 (permalink) Old Jul 10th, 20, 10:32 AM
Marcus
Nice nr’s congrats!
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #10 of 29 (permalink) Old Jul 10th, 20, 12:12 PM
Lew
BTW - Good power numbers on that 532. I have the Lemons 2 1/8 on my 1965 Chevelle less power than you pump gas job about 750 hp. I had some other headers on before these Lemons and pretty much all those comments above I ran into on the 2 1/8 on the 1965 which has a slightly narrower frame than the 1970 cars. The Lemons are great and fit well, tuck up nice and all the tubes fit in the frame - which can be good and bad. The 2.25 inch would probably get you there. Good luck on breaking 140 mph.
Lew540 is offline
post #11 of 29 (permalink) Old Jul 10th, 20, 12:15 PM
Nice piece...good work.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #12 of 29 (permalink) Old Jul 10th, 20, 2:14 PM Thread Starter
Gary
Lemons is the only company I know of that makes headers for a combination like this with a cylinder heads and everything and they are 4 months behind looks like I'm going to have to build them myself
post #13 of 29 (permalink) Old Jul 10th, 20, 3:51 PM
Durand
What do you have for cam and heads?
Jebchevelle likes this.
LaVelle is online now
post #14 of 29 (permalink) Old Jul 10th, 20, 4:29 PM
MARK
Same here! Seems like a lot to run 10.90 @ 2750
Machined GM production heads
Oil pan modifications
Red Line Camshaft
VORTECPRO is offline
post #15 of 29 (permalink) Old Jul 10th, 20, 4:47 PM
As I have said in the past....as long as the customer is happy that's all that matters...... Call me... I need to talk to you about an opportunity and see if your interested.
Chris Straub
cstraub is offline
