Camshaft company of choice? - Chevelle Tech
 33Likes
post #1 of 79 (permalink) Old Jun 30th, 20, 2:30 PM Thread Starter
Straub tech
Jones cams
Luanti
Crane
Comp
Crower
Bullet
Isky
Delta
Howard
Clay Smith
Did I leave anyone out?
Aaron is offline
post #2 of 79 (permalink) Old Jun 30th, 20, 2:44 PM
Re: Camshaft company of choice?
I prefer Comp but it would depend on the application and HP goal.
pannetron likes this.
69SS454 is offline
post #3 of 79 (permalink) Old Jun 30th, 20, 2:44 PM
Guy
I am using a custom grind Bullet thanks to Mike Lewis and Tim at Bullet.
Before that I had a UDHarold custom grind from Custom Camshaft Company,where Harold was working at the time.
I would use a custom grind over an off the shelf grind in any future builds.
Not a fan of Comp...
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is online now
post #4 of 79 (permalink) Old Jun 30th, 20, 2:52 PM
I'm pretty happy with the roller cam I'm running from Straub Tech.
jim
pannetron and rp930 like this.
Jim's69Ragtop is offline
post #5 of 79 (permalink) Old Jun 30th, 20, 3:11 PM
I used Cam Motion with great success. Hr 355 11.70's and SR for my 406 10.69.
My son has a custom Comp HR and it runs great also!
WHT/73 is offline
post #6 of 79 (permalink) Old Jun 30th, 20, 3:13 PM
My Straub cam set up is great.
461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, .050 229/241 .600/.569 109.
TH400, 3500 stall, 4.10 12 bolt posi
rp930 is offline
post #7 of 79 (permalink) Old Jun 30th, 20, 3:31 PM
I've ran Isky, Comp, Crower, Crane, Jones, and Lunati. To me, they were all quality pieces. If you are using them to help you spec your cam, then it comes down to who you seem to think is giving you the best guidance, who is most friendly, and then price could be a factor. Some people dog on the cam tech lines of some of the mfg, so it may just be if you can get to know your guy, talk to him more than once and build a relationship so you can trust what they tell you.
Alan F and Arch Stanton like this.
Rosinbluth is offline
post #8 of 79 (permalink) Old Jun 30th, 20, 3:39 PM
Greg.
I am very happy with this Howards Cam in my BBC
https://www.howardscams.com/hydrauli...cams-120255-12
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #9 of 79 (permalink) Old Jun 30th, 20, 3:48 PM
X2 for Howard’s
hessz24 is offline
post #10 of 79 (permalink) Old Jun 30th, 20, 4:12 PM
I've been very happy with the cams i've run from Bullet.
But the solid roller (blower) in my wife's car is a Comp spec'd by Steve Morris, i've been pretty impressed with the power the car makes and how easy it is on valve train parts.
WHT/73 likes this.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #11 of 79 (permalink) Old Jun 30th, 20, 4:21 PM
I would take for granted that each cam from a given vendor will operate reliably. The difference in incremental performance will come from using someone like Straub (whom I have used) or Jones (whom I would like to try) because of their ability to understand your build to give you the most optimal cam for your configuration. It's worth the money.
I put a Straub roller in a restored car of mine. It had tremendous mid-range torque. To make it more subdued, I replaced it with an HFT which would not run with the roller and that was the ONLY change.
I'm building a LT-1 clone motor and purchased a Summit factory replacement camshaft. It will do all it needs to for me but I'm sure it could do better with some camshaft scrutineering.
I'm planning a blower motor build for another car and wanted to talk with Mike Jones about that one.
427L88 likes this.
The biggest problem facing America today is that lies are so widely accepted as truths.
Alan F is offline
post #12 of 79 (permalink) Old Jun 30th, 20, 4:53 PM
George
Cammotion only does LS cams now.
WHT/73 likes this.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #13 of 79 (permalink) Old Jun 30th, 20, 5:33 PM
I recently built a 496 BBC with a Howard’s 275 @ 0.006”, 221 @ 0.050” HFT. Cam degreed in perfectly at advertised ICL. Valvetrain is dead quiet even with worn out lifter bores and Crower Enduro 1.7 full roller rockers providing 0.550” lift. Cam core appeared identical to the Jones HFT I have.
I wasn’t impressed with some of the documentation. They included the Morel roller lifter instructions recommending 0.0017-0.0018 lifter bore clearance, which exceeds GM spec for flat tappets. The cam card 0.006 events are wrong. They appear to assume the cam is symmetrical, which it is not.
Roadknee is offline
post #14 of 79 (permalink) Old Jun 30th, 20, 5:49 PM
Bullet and Howards.
68Chevele is offline
post #15 of 79 (permalink) Old Jun 30th, 20, 6:11 PM
They've been for a while now.
Geo71 likes this.
WHT/73 is offline
