Help - low comp bbc cam choice - Chevelle Tech
 10Likes
post #1 of 24 (permalink) Old Jun 30th, 20, 11:27 AM Thread Starter
Hi all,
I have a 1971 402 big block with 820 heads. Came from the factory with 8.5:1 compression. I have since added a weiand 8123 low rise dual plane (idle to 5500rpm), 750 holley, msd pro billet distributor and 6-al, 1 3/4 headers.
The heads flow:
71/52 at .100
145/105 at .200
227/144 at .300
260/176 at .400
279/190 at .500
My searches for a hydraulic FT cams has so far come up with Lunati Voodoo 10110701 .515"/.530" lift 213/219 at 050 duration 112 lsa basic operating RPM range:1,000-5,500
Im after plenty of torque and as much hp as possible as it is a 90% street car 10% strip. Is this a good cam considering my low comp? Do any of y'all have better recommendations?
moncam is offline
post #2 of 24 (permalink) Old Jun 30th, 20, 3:33 PM
Personally I like a 108 centerline with low compression big block. Summit sells a hydraulic flat tappet that’s like the old Crane 282.
I’ve run that cam before in set up like yours. Great cam. It’s 226/226 at .050 512 lift I think, cut on a 108.
Find some Delphi hydraulic lifters. They’re the best by far.
427Roscoe is offline
post #3 of 24 (permalink) Old Jun 30th, 20, 3:47 PM
Gary
Re: Help - low comp bbc cam choice
Low compression needs a small tight cam I agree with Roscoe. I certainly wouldn't run any bigger camshaft than that duration wise and I would probably suggest you go with a few degrees smaller. Esky is another good company
gnicholson is offline
post #4 of 24 (permalink) Old Jun 30th, 20, 5:12 PM
jimmyradford
I'd look at Isky's Mega 264, seems like a good fit. Summit house brand have a good rep for quality.
TC Member # 4431
'67 Chevrolet Biscayne- SS427 L-36/TH400 (Hers)
'67 Hell Camino-BB 427/TH400 (His)
'66 300 Deluxe 2 door-230/PG
"Good people sleep peacefully in their beds at night only because rough men stand ready to do violence on their behalf."-Orsen Wells
Strong people are harder to kill than weak people and they're generally more useful.
badrad is offline
post #5 of 24 (permalink) Old Jun 30th, 20, 5:48 PM
Isky Mega cams work really well. The 280 mega cam on a 108 is the best one.
71454Chevelle likes this.
68Chevele is offline
post #6 of 24 (permalink) Old Jun 30th, 20, 7:01 PM
The part number of the summit cam I referred to is 1796.
Really good cam. I think summit cams are actually Elgin grinds.
post #7 of 24 (permalink) Old Jun 30th, 20, 8:23 PM
Kerry
I know that you don't hear about them, but for stock heads Lunati's version of the Thumper cam should perform well in your 402. 224/236 @ .050", 269/296, .525"/.525" 108 LSA, 104 ICL.
Strong mid-range power. Great street cam. 2,500+ stall converter, 3.42+ gear and 9:1-9.5:1 compression recommended.
Use direct lube lifters Howards 91116.
68Chevele likes this.
pockets is offline
post #8 of 24 (permalink) Old Jun 30th, 20, 9:21 PM
What is your desired idle quality?
Roadknee is offline
post #9 of 24 (permalink) Old Jun 30th, 20, 9:48 PM Thread Starter
Thank you all for the responses, I will most definitely look into all the recommendations. From what I gather a 210-220 at 050 duration on a 108 lsa is somewhere around the mark.
My desired idle quality is that I want enough vacuum to run my power brakes, other than that I wouldn't mind a lopey idle (it is a classic muscle car at the end of the day).
I'm hoping that with the right cam, along with the other parts ive already added, I aim to run high 12s
moncam is offline
post #10 of 24 (permalink) Old Jun 30th, 20, 10:33 PM
Just as a reference point, I ran the k03072 cam from summit. 514 lift, 226 duration at .050 on a 108.
My engine was a 9 to 1 454 with L29 heads, 8123 weiand intake, Holley 780, stock converter, 3.08 gear with power brakes and steering. Ran, drive and stopped great.
Pleasure to drive and sounded great.
post #11 of 24 (permalink) Old Jul 1st, 20, 1:35 AM
Originally Posted by moncam View Post
...My desired idle quality is that I want enough vacuum to run my power brakes, other than that I wouldn't mind a lopey idle (it is a classic muscle car at the end of the day)...
I ran this cam in my 454 for over 10 years with peanut port heads and a little over 9:1 CR. Great street cam. Lots of low end torque and great vacuum. You wont get that lopy idle though or at least I didn't.
-Kevin
1965 Chevy Biscayne
<removed> 454cid, "peanut ports", Voodoo 60201
<coming soon> 460cid, Brodix RRO 270, 229/241 Hydraulic Roller
TH400, 3.36 Stock Rearend
65cayne is offline
post #12 of 24 (permalink) Old Jul 1st, 20, 8:48 AM
Hi all,
The heads flow:
71/52 at .100
145/105 at .200
227/144 at .300
260/176 at .400
279/190 at .500
Honestly I think the cam YOU picked is better than any of the other suggestions. With only 402 cubes, and 8.5:1 compression, any cam bigger than the one you selected is going to be a complete dog at low RPM. JMHO
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
post #13 of 24 (permalink) Old Jul 1st, 20, 10:52 AM
The was a guy on here that specd a custom cam for my 454 with low compression 781 heads.. I want the same as you, smooth idle with 20" of vac and torque right of idle.. After years of lumpy motors on the street, I've had enough.. lol
p40 likes this.
hydro462 is offline
post #14 of 24 (permalink) Old Jul 2nd, 20, 6:40 PM
p40
butch
with the flow numbers on your heads i would go with a hyd flat tappet comp cam 280 , no need to go more than 520 lift always match your cam to your heads 17 inches of vacume at idle
p40 is offline
post #15 of 24 (permalink) Old Jul 3rd, 20, 7:13 AM Thread Starter
Thank you all for the replies.
For this application, what does everyone think of the comp cam XE262 11-238-3 218/224 duration at .050 .504/.510 lift 110 LSA?
p40 likes this.
moncam is offline
