Beef up a stock 454 - Page 2 - Chevelle Tech
 10Likes
post #16 of 22 (permalink) Old Jun 29th, 20, 10:03 AM
Re: Beef up a stock 454
Originally Posted by rp930 View Post
Call Chris Straub.
^ This ^.
Cam selection can be overwhelming, and that's why you need to speak to a pro. Whether someone like Mark or a Cam maker's "Tech Line".
Your can selection will depend on your rpm range, and that range will depend upon your rear end gearing.
I personally like BBC low/midrange torque with a highway gear (like 3.31), but my experience is strictly with Muncie 4 speeds.
Now there is a variety of transmission options (manual or automatic) that have over overdrive gears. Many folks are able to stay with a lot of gear (4.10 for example) while running a tranny with overdrive - getting the best of both worlds.
Good luck
67 Chevelle SS:
original paint, M20, & 3:31 posi.
Unrestored, but dreaming of doing so
guitargeak99 is offline
post #17 of 22 (permalink) Old Jun 29th, 20, 11:02 AM
Originally Posted by Lsukev View Post
Hey all, I’m looking to add a little more power and throttle response to my stock 454 in a 69 Chevelle. It has 2”inch aftermarket exhaust, but other than that, it’s all stock. What are some good additions for more power?
that 2 inch exhaust is choking your 454 you need to go to a 3 inch exhaust especially since you have a set of headers you want to install.
You may also want an H or an X crossover as it will increase the mid-range torque .
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #18 of 22 (permalink) Old Jun 29th, 20, 11:35 AM
Many people seeking performance fail to have their current setup tuned professionally by a local dyno shop. Best money you can spend in this hobby, IMHO.
BTW: a BBC should be fast with 2.73 or 3.08 rear gears. They make a LOT of torque in most configurations.
That said, I'd spend money on better exhaust/headers that not only match your current setup....but can be used without modification/additional cost on a 550-600 HP 468 with 781 or 049 heads, RPM intake, modest cam, etc.
Good luck!
blue_69_malibu is offline
post #19 of 22 (permalink) Old Jun 29th, 20, 3:35 PM Thread Starter
Kevin
Good luck!
What are your recommendations for exhaust, headers, and exhaust tubing?
Lsukev is offline
post #20 of 22 (permalink) Old Jun 29th, 20, 3:41 PM
headers: summit part# SUM-G9010 fit like a glove
Flowmaster exhaust kit 17107 and pick whatever 2.5" offset inlet/offset outlet mufflers you want.
blue_69_malibu and BRN2RUN like this.
mr 4 speed is offline
post #21 of 22 (permalink) Old Jun 29th, 20, 7:46 PM
I followed a lot of advice from guys here and I am more than happy!
First should be headers, Summit SUM-G9010
Your cam is a BIG limiting factor . I went with Comp XE 268 .
Those two things will make a WORLD of difference !
Edlebrock Performer 2-0
Holley 3310
HEI Distributor
The 3.31 gear choice will be fine .
blue_69_malibu likes this.
BRN2RUN is offline
post #22 of 22 (permalink) Old Jun 29th, 20, 8:06 PM
Kerry
First thing to do is the exhaust. 1.75"x3" headers and a 2.5" or 3" mandrel bent exhaust. 3" if in the future he is going to build a 500hp + engine. Good straight through mufflers like Dynomax Ultra Flow.
Performer rpm air gap intake, and for a carb pretty much any 750. If you are swapping to taller gears, a vacuum secondary holley based carb or 750 street demon. Have a look at the FST line of carbs for a holley based.
Then I would do a converter change to a tight 10" in the 2500 stall range, and tune the timing curve.
A cam change would be what I would do after all of the above.
pockets is offline
